Old 05-15-2011, 05:26 PM   #16
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,505
The HB bars are great. I only have to loosen them every 6000 miles for valve adjustment. But I ride with them everyday and chance having to use them for their intended purpose. Plus, it gives me one more opportunity to check that everything is snugged up proper-like. For me, it is a worthwhile trade-off.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 05-15-2011, 06:15 PM   #17
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
True enough. I have them as well and have to loosen them. By the bye, DO NOT loosen the bolt which Norsman highlighted in his photo-- there is no need and that bolt also holds up the subframe which makes installing and uninstalling that bolt a dangerous proposition.
Instead, remove your tank (one electrical connection, two QD's, two plug in hoses and a bolt-- one minute) and loosen the front mounting bolts instead. This allows plenty of spread and won't having you searching for a helicoil or timesert should you accidentally strip the threads out of that rear bolt Norsman shows.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 08-02-2011, 09:59 AM   #18
ErricZ
ErricZ's Avatar
Oddometer: 750
Not sure what the big deal is with these bars ... the left side was a bit of a bear but I put my jack under the footpeg for support and levered the subframe (and bolt) down GENTLY a tiny bit and it popped into the thread. Right side was even easier and nothing slipped out of alignment in the least, all three bolts in with ease -- just had to pull the front bar bolt hole and front frame mounting hole together whilst I got the bolt started.
I have the plastic valve cover protectors and the right side is snug up against that, so I'd imagine a bit of loosening is in order for service. I keep a large jar of CoppaSlip around like the Brits do, so that was an easy addition and very helpful I'm sure.
Torque is 40Nm for the (4) big M10 bolts and 25Nm for the (2) re-used M8s in the front.
Also, the middle bridge connector on mine has 2 bolt holes but only 1 bolt/nut was supplied. I'm sure a quick stop at Lowes/HD/Ace will solve that disparity in a jiffy.
2002 BMW R1150GS - Graphitan, PB riding
2000 Aprilia Pegaso - Blue, for the trails!!
02 Pagsta Choppa, 85 & 86 GSX-R 750 (projects)
2005 Ford F-250 Super Duty XLT 4x4, do-it-all Pine Barrens Beastie
ErricZ is offline   Reply With Quote
Old 04-02-2013, 03:49 AM   #19
GS Yinzer
Go Stillers
GS Yinzer's Avatar
Oddometer: 35
Crash Bars n At
Thank guys... Looking to pick up a set of crash bars today for the new 1150 GS. This forum helped a bit. In a way it's down to HB vs SW-Motech. Anybody out there feel they can sway me one way or the other?
GS Yinzer is offline   Reply With Quote
Old 04-04-2013, 07:34 PM   #20
redwing51
Oddometer: 115
I've had both,and they both are fine, but prefer the Hepco-Becker bars. Its easier to change the oil with the HB bars. But I only need to change the oil once or twice a year (synthetic oil) so its not really a big deal with the SW MoTech bars.
redwing51 is offline   Reply With Quote
Old 04-05-2013, 08:17 AM   #21
pjgrunt
Oddometer: 1
How about the TouraTech bars or the Altrider crashbars?
I traded my 2004 1150GS for a new 2012 GS last year and am in the market for crash bars. Wunderlich carries the HP bars, but for considerably more money you can get the Touratech (~$390) or Altrider ($457) crashbars and like the HP you can get them in black.
Does Anyone have any experience with this more expensive crash bars? Supposedly the Touratech are the bestselling crash bars.
thanks, paul w.
pjgrunt is offline   Reply With Quote
Old 02-03-2014, 07:48 PM   #22
czechyour6
czechyour6's Avatar
Oddometer: 143
I can confirm this also, my buddy just recently pulled this left bolt, tried to put it back in and it must have cross threaded and BROKE! now we need to pull shaft out and try to machine it out or spend 125$ for a new one
czechyour6 is offline   Reply With Quote
Old 04-08-2014, 10:47 PM   #23
turbojugend208
Oddometer: 103
Crash
SW Motechs are a bit soft,been through two sets. Last set twisted up like a wind blown owl in a barb wired fence... H&B are super solid and take a beating, hands down the top of the food chain.
turbojugend208 is offline   Reply With Quote
Old 04-11-2014, 09:55 AM   #24
czechyour6
czechyour6's Avatar
Oddometer: 143
Link to my recent thread in case you want to modify them to make them service friendly, even if ya find them used!
http://advrider.com/forums/showthrea...7#post23910307
Old 04-15-2014, 09:29 PM   #25
Bob
Formerly H20Pumper
Bob's Avatar
Oddometer: 2,669
Interesting mod, thanks.
Bob is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
