Old 05-12-2011, 01:05 AM   #1
GreaseMonkey OP
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,766
Dirty Sanchez, I have a threadlocker issue
I managed to get some permatex 27100 (red high strength) into a place where I didn't want it and now it is causing a small part to bind. I have movement in everything, it is just sticking when a spring should cause it to return.
The parts are all steel, and will be a moderate but not impossible PITA to disassemble.
Is there a solvent I can use? I've tried lacquer thinner, brake cleaner, and rubbing alcohol.
I am hoping there is a solvent I can use to dissolve it, the return spring is a little smaller than a ball point pen spring and I suspect it has gotten in the coils too. Soaking it for a day or two is preferable to disassembly and cleaning it that way.
Any suggestions?
GM
GreaseMonkey is offline   Reply With Quote
Old 05-12-2011, 06:39 AM   #2
Motomedic
Motomedic's Avatar
Oddometer: 1,849
Acetone or carburetor cleaner?
Feike
Said James to Red Molly, Now Nortons and Greeves and Indians won't do- they don't have a soul like a Vincent '52
Motomedic is offline   Reply With Quote
Old 05-12-2011, 06:56 AM   #3
74C5
74C5's Avatar
Oddometer: 759
Naptha. Works great on polymerized rubber.
R1200RT (R1100RT gone)
KLR650
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 05-12-2011, 09:02 PM   #4
Benesesso
Benesesso's Avatar
Oddometer: 8,506
Any suggestions?
GM
Chisel that sucker clean! You don't even need a hammer. Check this out.
http://www.idealvac.com/files/brochu...ripperTech.pdf
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 05-12-2011, 09:03 PM   #5
BtoV
FNG
BtoV's Avatar
Oddometer: 286
Acetone
BtoV is offline   Reply With Quote
Old 05-13-2011, 05:25 AM   #6
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,097
Methylene Chloride.
It'll remove the protective slime coating on your eyeballs, fingerprints, and paint off of the hood of a persons car who has wronged you.
If you can't find plain old methylene chloride, we have a product called Loctite Chisel. It's a shake it up, spray on gasket and paint remover which contains methylene chloride.
I'm having a tough time visualizing the part you buggered up, so a pic or two would help.
Once you're able to source either product, pour or spray a few thimblefuls onto a small cup made from tin foil. Then with a cheap metal bristled gun cleaning toothbrush, carefully work the wet bristles around the bunged up part/pieces until the parts are free. While methylene chloride won't dissolve a theadlocker that is captured in between a nut and a bolt, it will soften anaerobic, silicone, old indianhead shellac-type gasketing products to the point you can wipe them off with a paper towel, or popcicle stick scraper.
Rinse off the fingerprint eating product with a degreaser, acetone, gasoline, or diesel, but DON'T wipe it on your britches or get any on your skin.
Don't ask me how I know.
Dirty
No, really, the mustache means I love you.
'09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167
dirty_sanchez is offline   Reply With Quote
Old 05-13-2011, 10:58 AM   #7
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,286
Dirty
I used to work in a graphics business. The screen printing process used methylene chloride is some of the paint mixes. The guys that worked the paint booth used to dip their cigarettes in the solvent and smoke them. They gotta be dead by now...
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Old 05-13-2011, 11:09 PM   #8
GreaseMonkey OP
Oddometer: 4,766
Methylene Chloride.
Dirty
I replaced a barrel on a 22 magnum rifle I have, the barrel is press fit and held in with a pin. In addition to the pin I used the threadlocker on the barrel as well. When I was setting the headspace some of the threadlocker traveled down one of the extractors (there are two extractors) and that is where this all started.
Here is a breechblock similar to what I have:
If you look at the bottom edge of the block carefully, you can see the retaining/pivot pin for the extractor. On the side you of course see the hole where the spring goes that provides the pressure to snap the extractor over the edge of the cartridge rim. Right now the extractor can expand but binds too much to grip the case when pulling it out of the chamber.
The pivot pin is really stuck, I've tried a couple of punches and I am worried about marring the finish if I get any more aggressive.
Hence my question of what solvent can I use to soak this in to dissolve out any remaining threadlock compound. If you say MEK, then that's what it will be...
Old 05-14-2011, 12:54 AM   #9
Benesesso
Benesesso's Avatar
Oddometer: 8,506
Don't you read the posts? No one has said anything about MEK (methyl ethyl ketone). It's methylene chloride, which is the main ingredient in Loctite's Chisel. Damn----.
Old 05-14-2011, 05:31 AM   #10
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,097
Given the configuration of the parts, Chisel will be too thick.
Yep, MEK is Methyl ethyl ketone. Entirely different than Methylene Chloride. None of the other chemicals mentioned so far will soften or remove a thermoset plastic like a cured threadlocker.
If you spray it on a part or the hood of a very nice automobile owned by a person who has wronged you it's to thick (somewhat gelatinous) to wick into the tight spaces. You're going to need to source the plain old liquid version of this chemical, brush it on, or soak it at your own risk and see what happens.
Go to the local science supply store, or even the local university lab/general store.
This is an oddball chemical for us mere mortals to attempt to source, but given the nature of my job, I buy things at the LSU Lab Store all the time without a hitch. I bet they'd have it.
Dirty
Old 05-14-2011, 08:37 AM   #11
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,057
Dirty
I believe that Ambroid ProWeld is mostly Methelyne Chloride. It's a solvent glue used in model building, and widely available in small quantities from any number of online sources, and from local hobby/model shops.
Based on the MSDS, 3M's Mar-Hyde(r) Tal-Strip(r)II Aircraft Coating Remover, 3711 and Kleen Strip's Klean-Strip Aircraft Remover are both mostly methelyne chloride, mixed with alcohol and some other stuff.
I can tell you that ProWeld will most certainly wick into very, very small gaps. It's also relatively cheap.
hpsVFR is offline   Reply With Quote
Old 05-14-2011, 08:40 AM   #12
GreaseMonkey OP
Oddometer: 4,766
Today 01:09 AM
GreaseMonkey
Goddam Benesesso cut a guy some slack for a brain fart posted at 1 in the morning, and a Saturday morning at that!
Old 05-14-2011, 08:46 AM   #13
GreaseMonkey OP
Oddometer: 4,766
Today, 02:54 AM
Benesesso
Oh, I see you were at the same party.
Old 05-14-2011, 08:51 AM   #14
74C5
74C5's Avatar
Oddometer: 759
Have you tried heat? I'm guessing either a tool or a 4000 series steel. Maybe even a carburization but, that won't get damaged by low heat. You're good to at least 500 deg F.
Heat it then try the punch. Stick it in the oven at 350. You won't do anything to the heat treat. Gloves may help.
The only possible damage will be to springs. Forgot the name of the spring for all guns shop.
KLR650
Old 05-14-2011, 08:52 AM   #15
GreaseMonkey OP
Oddometer: 4,766
Thanks for the info Hps.
Times are GMT -7.   It's 02:52 AM.
