Old 05-13-2011, 12:42 PM   #1
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,453
Question Airhead Timing Chain - Who's done it?
While I have the bike torn down (again) to replace the ME timing module I was thinking about replacing the timing chain. The weeping coming from between the block and the housing isn't getting any better .
Anyone done this?
List of parts I think I'll need:
11141255011 SHAFT SEAL - 28X47X7 $8.64
11311335934 TIMING CHAIN $35.58
11311338185 CHAIN TENSIONER $6.06
07119951480 WOODRUFF KEY - 5X6,5 $1.00
So with that in mind I was thinking maybe I could do the 336 cam as well. Had one on my '91 GS, it really spun up good!
11311336393 CAMSHAFT - 336DEG $167.38
Anything to be wary off? Suggestions?
Maybe the cam is more than I should tackle...
Rapid Dog is offline   Reply With Quote
Old 05-13-2011, 12:52 PM   #2
batoutoflahonda
Oddometer: 1,383
Check it:
http://www.advrider.com/forums/showthread.php?t=663714
Also, ton's of info if try this:
Let me google that for you
Not being a smart ass, just a cool tool.
So, if you type in 336 cam site:advrider.com it will come up.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda screwed with this post 05-13-2011 at 01:03 PM
batoutoflahonda is offline   Reply With Quote
Old 05-13-2011, 01:14 PM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,594
Watch those 336 cams. According to a good source the latest ones were made in China and have now been withdrawn.
Swapping the cam on a post 81 machine is pretty easy. You can leave the oil pump in place and do it from the front. Earlier machines had a woodruff key and needed the flywheel removing. Just take the pushrods out one at a time putting the rockers back in place after you take each one out. Turn the engine to move the cam followers out the way and away you go.
Rob Farmer is offline   Reply With Quote
Old 05-13-2011, 02:09 PM   #4
dduelin
Oh boy that was close
Oddometer: 1,457
I did the single row cam chain on my '81 five years ago and it was easy. I called Hucky's and he sold me a kit with everything I needed. The only part that was frustrating was getting the master link installed but I didn't know about this forum then and had to figure out myself to come at the back of the chain with the link super glued to a piece of stiff wire. If I had asked ADV back then I would have had a thread of helpful comments. I did not change cams.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 05-13-2011, 04:22 PM   #5
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,239
Snowbum has a bit to say on this & also suggests consideration as to whether the tebnsioner & spockets are changed.
I changed the tensioner & smaller sprocket on my '78 R100RS.
I've a '91 R100GS. The cam chain was replaced not long before I bought it. I can hear it now & see the flicker in timing markls when I attempt to time it. I suspect that just the chain was replaced then, and other worn parts have contributed to its early demise.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 05-13-2011, 04:35 PM   #6
supershaft
because I can
Oddometer: 9,116
You just about always need to replace the crank sprocket. Single row cam sprockets seem to last just about forever. Dual row cam sprockets need to be replaced as well as the crank sprocket a lot of the time.
Old 05-13-2011, 04:53 PM   #7
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,453
Everything looks prety goo in there wear wise.
So I figure I need the chain, gasket, and seal.
Anything else I'm missing? Tensioner? is that a necessary item?
What about the gasket, Hylomar? I can see it was glued on before.
I can only assume that the thing was weeping between the block and the timing chain cover due to the crispness of the gasket. I want to make damn sure this is addressed!
The camshaft seal had the very slightest bit of weeping.
I'm gonna pass on the cam swap, faggedabouddit!
Old 05-13-2011, 05:31 PM   #8
supershaft
because I can
Oddometer: 9,116
That crank sprocket looks like it needs to be replaced to me. Your new chain will last about half as long as it should running that sprocket. You have to look closely for wear. See where the rollers have gotten into the right side of the teeth?
You can't tell how the tensioner is until you can see it.
Gasket? Clean and dry. Don't forget the donuts around the top two bolts. Don't gouge up your gasket surfaces cleaning off the crap that it never really needed. Man I have been seeing a lot of that lately! Permanently F'ed up stuff with no good cause for it.
Camshaft seal? That is the bean can's O-ring. Replace it. They are cheap.
Old 05-13-2011, 07:57 PM   #9
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,453
Eh?
I'll go with the cam tensioner, it looks worn.
Gears, I'm not going there.
My bet is someone has been in here before, cuz #10 nuts were on the inside...
Probably didn't need to do this at all except for the leaky gasket. Chain looks pretty good.
Donuts? I don't see no stinking donuts.
Seal is #8....guess that's the crank seal.
Rapid Dog screwed with this post 05-13-2011 at 08:04 PM
Old 05-13-2011, 08:19 PM   #10
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Sorry Dog but you need to look again.
That crank sprocket absolutely shows wear. How bad it is I can't tell from here but you know the rule. "Do it now or do it a lot sooner."
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 05-13-2011, 08:54 PM   #11
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,453
...so big wrenchers, how do I get the sprocket off, it looks pretty decent form what I can see.
Old 05-13-2011, 10:30 PM   #12
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Well, lets see....
You'll need some beer, a bottle of Single Malt, one pizza, several BF Hammers, a good three-jaw puller, a butane torch and at least one friend whose pulled a sprocket before. After that, you'll need some new parts...
Call around and see if you can source a Pre-China 336 cam. I've had one sitting on th shelf for three years or so but for all I know, it's Commie crap too.
Come on.... Put a cam in it!
Hawkdude
Old 05-13-2011, 11:51 PM   #13
fishkens
Further...
Oddometer: 5,147
Geeze, that pic of the crank sprocket is great. Unfortunately, those pointy teeth sure do look worn.
Next time I'm in there I'll ask you to take pics of mine so I can see mine as well as I can see yours. If I'd have done that last time I replaced the timing chain I probably would've seen the wear as well as i can see it on your bike.
fishkens is offline   Reply With Quote
Old 05-14-2011, 12:53 AM   #14
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,594
Looks like somebody has filled the edges of the teeth on your sprocket. I know it's not what you want to hear but I'd agree with the other guys that sprocket is goosed.
It's not just the tip of the teeth that wear. The bottom of the teeth loose their profile and elongate.
Photographs seldom show what the eye can see:-
I use an air impact driver on the end of a three jaw puller. The snatches from the impact hammer make for a nice steady pull and keep the sprocket moving. Just warm it up before starting to pull.
Rob Farmer screwed with this post 05-14-2011 at 01:01 AM
Old 05-14-2011, 02:54 AM   #15
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,628
Classic photos of a worn crank sprocket.
One theing that has puzzled me is why the double-row crank sprocket wears more quickly than the single-row. "In theory", the double-row sprocket ought to have half the load on each tooth that a single row sprocket does, so it should wear less. Metallurgy problem?
'73 R60/5 Toaster
Times are GMT -7.   It's 01:46 AM.
