05-15-2011, 07:39 AM
#31 |
bikes, booze, broads...
Oddometer: 8,303
...,yeah, that's what I was thinking too...?
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
05-15-2011, 07:47 AM
#32 | |
the thread-killer
Oddometer: 4,297
Done it. wirewrkr screwed with this post 05-15-2011 at 07:58 AM |
05-15-2011, 07:51 AM
#33 |
+/- V TDSPP
Oddometer: 19,936
good idea!
What to do... What to do... |
05-15-2011, 08:00 AM
#34 |
Oddometer: 3,734
all you need to do is turn the cam once it will then push the followers up out of the way or drop the sump and do it with your fingers.
05-15-2011, 08:24 AM
#35 |
Oddometer: 8,303
...now you guys got me thinkin' again.
I just didn't want to undo my nice sealed jugs. Drop the sump? I don't see any access to the lifters in there...
05-15-2011, 10:24 AM
#36 | |
Oddometer: 3,734
I've swapped cams without taking the jugs off before. With the pushrods out just turn the cam and the lifters will be pushed up out of the way. |
05-15-2011, 10:47 AM
#37 | |
Lost In Place
Oddometer: 15,982
05-15-2011, 10:54 AM
#38 |
Confirmed Curmudgeon
Oddometer: 3,899
I 've not done that because I've heard that the magnetic wand can magnetize the followers and make them attract every magnetic chip in the oil flow. I've not seen it one way or the other, just sayin'...
'73 R60/5 Toaster |
05-15-2011, 10:58 AM
#39 | |
Oddometer: 740
05-15-2011, 11:29 AM
#40 |
because I can
Oddometer: 6,080
Yea, the duplex cam sprockets wear. They often need replacing if you want your chain to last anywhere near as long as it should. The crank sprocket just about always does.
The lifters won't hit you in the face after you take the sump off but you can get to them from there. The problem in my view with replacing the cam without removing the cylinders is that you can't check the condition of the lifters which very often is not good. There is no way I would run a sport cam without first checking the lifters for pitting. |
05-15-2011, 12:40 PM
#41 | ||
yeah - what he said...
Oddometer: 9,051
Just finished doing rings/heads on the rig too - the old Airhead has a noticeably improved performance with ~104,000 miles on the clock (purchased @92k). Oh yes, and that frigkin master link... ![]()
Tony ![]() Quote:
05-15-2011, 02:44 PM
#42 |
Justa Venturer
Oddometer: 1,245
Most of the BMW lifters I have seen that have some miles on them are starting to show at least the first signs of pitting. FWIW I think a new cam should have new lifters.
also: If you put a dab of sticky grease on the end of a pushrod the lifter can be withdrawn.
___________________________________________ So much riding-so little time |
05-15-2011, 02:55 PM
#43 |
because I can
Oddometer: 6,080
From what I can tell, I think a lifter that is in your bike and not pitting has just as good or better chance of not pitting in the future versus a new one.
05-15-2011, 03:13 PM
#44 | |
Coyote's Brother
Oddometer: 3,299
OTOH, the word on the street for the last um-teen years says that if you're installing a new flat-tappet cam, you install new lifters. Always...
Hawkdude Hate rots the pocket that carries it. |
05-15-2011, 05:11 PM
#45 |
Oddometer: 8,303
....I'll do the cam some day when I'm sure I've replaced everything else. I've only done about 70% so far...
