Old 05-13-2011, 03:53 PM   #1
men8ifr OP
Oddometer: 383
I have 2 leaking GPR dampers - is it possible to service them myself?
Anyone else done this and was it successful?
I don't think there is a rebuild kit for the GPR's i.e. seals but they are all plain O rings.
Sending both of them off is a bit $$$ () for some-one else to replace the orings.
Both of the dampers are a few yesrs old but I'm a bit miffed they are both leaking.
men8ifr is offline   Reply With Quote
Old 05-13-2011, 07:27 PM   #2
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,193
Mate had one leaking - he contacted them, not sure of the exact details but I am pretty sure they replaced it with a new one.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-13-2011, 09:32 PM   #3
Treewakr
throttle junkie
Treewakr's Avatar
Location: land of cheese,trees, and 2nd gear singletrack
Oddometer: 33
I've rebuilt my GPR damper a couple of times. They are pretty simple and straight forward. Just find the right size o-ring and you're good to go. Refilling the unit with oil is the most time consuming part. Add oil slowly and move the lever back and forth to work all the air bubbles out.
Also, changing oil viscosity just a little lighter or heavier makes a big difference in performance!
Treewakr is offline   Reply With Quote
Old 05-13-2011, 10:34 PM   #4
KTM450SX
Oddometer: 369
Don't GPR's have a lifetime warranty?
I only owned one but I thought it did. ( I don't use any stabalizers anymore )
2014 KTM 500 EXC
2007 KTM 950 Super Enduro
KTM450SX is offline   Reply With Quote
Old 05-14-2011, 05:06 AM   #5
YamWOW!
YamWOW!'s Avatar
Oddometer: 460
First service is free after that it is $25.00. http://www.gprstabilizer.com/files/GPRServiceForm.pdf
YamWOW. It's made in Japan, you know the Japanese make good stuff!
Check out the WR250R/X forum: CLICK HERE
Check out the Pacific NW DualSport Forum: CLICK HERE
KTM 530 EXC-R
BMW F800GS
YamWOW! is offline   Reply With Quote
Old 05-14-2011, 11:27 AM   #6
men8ifr OP
Oddometer: 383
Yeah we get screwed over here (UK) a service is 55 ($80-90) in the US it's $25.
I've never seen any mention of a first service free so I don't think we get that either.
Better get the O ring kit out - I've tried once to repair one damper but it's still leakign though may be from the adjuster shaft - i did not replace the O rings on that i did not think it would leak there.
It was a pain to get all the air out - I was going to try and submerge the unit in oil and re-assemble it should hopefully be easier.
Old 09-05-2011, 06:58 PM   #7
malsin
malsin's Avatar
Oddometer: 82
possible DIY unless too late
My GPR is leaking yet again, after two free redos by GPR after I paid for service (with me paying the shipping so not really free). Unit lasted two years before it leaked. Now it leaks on day one of riding after getting it back. Each
Here are two items that may help anyone else that comes across this thread.
Picture of a GPR disassembled and barebones instructions. I'm less nervous about trying the service myself. I figured I would open the top and have springs flying everywhere ...
http://www.georgiaoffroad.com/forums...p?f=17&t=47520
GPR refill and bleeding instructions that they used to have on their site. I saved a copy way back when and now it isn't posted anymore. So here is my copy of their document:
http://home.everestkc.net/malsin/Mot...edingInstr.pdf
01 F650GSD / 02 400 EXC
malsin is offline   Reply With Quote
Old 03-13-2012, 03:02 PM   #8
luv2lean
not lost til out of gas
luv2lean's Avatar
Oddometer: 982
Thanks Malsin for the useful instructions. It looks fairly simple. Anybody found a good source for the o-rings?
luv2lean is offline   Reply With Quote
Old 04-12-2012, 06:27 PM   #9
ndrordr
Oddometer: 6
Anyone that's done this know what the size of all the little allen screws is? I am in need of re-oringing mine, but none of my metric or sae allen wrenches fit.
Any help is appreciated.
Rob
ndrordr is offline   Reply With Quote
Old 06-05-2012, 10:20 AM   #10
men8ifr OP
Oddometer: 383
I will have to try again - I'll try to take some pics and let you know O ring sizes etc.
Re the allen bolts all I know is it's a U.S size and was standard in a small set of allen heads I got in the UK so should be very easy to find in the U.S. Also re the O rings a $10 O ring kit with say 20-30 different sizes should have all you need.
Regarding the re-filling and getting air out all I do is fill as much as possible and re-assemble then turn the unit upside down, remove the 2 small silver cross head screws and pour a bit of oil in each then move the damper arm slowly left to right adding oil at each screwhead for 20min and all teh air should be out. Check by setting the damping to max and moving the arm by hand left to right - you should feel no free play in the arm around the centre.
Old 06-05-2014, 02:22 PM   #11
de Razendebol
de Razendebol's Avatar
Oddometer: 6
did mail gpr directly
Okay, it is easy diy but they don't sell the o ring kit, just measure the seize with a calipher,
all standard seize, fill oil with a syringe, good examples on you tube how to do it
got mine gpr 4v dirt 2 years and start leakingwill take it apart and post the seize
one turn at the time
de Razendebol is offline   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
