Old 05-13-2011, 09:50 PM   #1
bondatomic OP
friend of motorbikes
Oddometer: 45
Thumb Triumph oil? For Tiger 800...
Rapidly coming up to my 500 mile oil change... What are you guys using in Tiger 800s or any Triumph triples? Castrol synthetic?
bondatomic is offline   Reply With Quote
Old 05-14-2011, 08:47 AM   #2
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,489
Mobil Racing 4T Syn 10-W40 is what service manaul recommends for Tiger 1050.
blk-betty is offline   Reply With Quote
Old 05-14-2011, 09:11 PM   #3
RodT
Oddometer: 352
Castrol
Triumph has a deal with Castrol, there's a sticker by the oil plug, at least there was on the XC I saw. Rod
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT is offline   Reply With Quote
Old 05-15-2011, 10:37 AM   #4
jphish
Oddometer: 622
AMS 10-40 for mine. Let the oil wars begin !!
jphish is offline   Reply With Quote
Old 05-15-2011, 11:47 AM   #5
brad1098
/\ dumb
Oddometer: 852
Just put somthing in it. Probably wont own it long enough for motor to fail due to poor lubrication
Rotella somthin or other synthetic.
brad1098 is offline   Reply With Quote
Old 05-16-2011, 04:53 PM   #6
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,662
Triumph used to have a deal with Mobil 1, now they have a deal with Castrol. I guess Castrol pays more $ for the name drop.
However, the owner's manual makes it real simple and non-brand-specific:
"Semi or fully synthetic 10W/40 or 10W/50 motorcycle engine oil which meets specification API SH (or higher) and JASO MA."
The emphasis exists in the original text. They then go on to name-drop the Castrol Power 1 Racing 4T but the Mobil 1 Racing 4T works just as well.
So either of those two or any other oil of the specified weight which meets those specs will do just fine.
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 05-16-2011, 06:21 PM   #7
Dmarino
Dmarino's Avatar
Oddometer: 205
Rotella 5w40 syn
11' Triumph Tiger 800 ABS | 04' DRZ400E
Dmarino is offline   Reply With Quote
Old 05-19-2011, 08:45 PM   #8
acody49
acody49's Avatar
Oddometer: 39
rottela 5w40 for my tiger 955i,it comes in a 4 litre jug,perfect amount of oil with filter change and half price of the 4t synth
acody49 is offline   Reply With Quote
Old 05-20-2011, 07:14 PM   #9
N9921X
Wins
N9921X's Avatar
Oddometer: 149
Thumb Shell Rotella 5w40 synthetic
Shell Rotella 5W40 syn will get you a few more mpg.
I run it in my Tiger 1050 and have perfect performance. 23,800 miles, no consumption and easy starting in the cold weather.
N9921X is offline   Reply With Quote
Old 05-23-2011, 12:39 PM   #10
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,563
Manual doesn't specify how much? 4 qts? 3? 15?
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 05-23-2011, 12:56 PM   #11
Evomx971
Wave as you fly over
Evomx971's Avatar
Oddometer: 306
It holds just shy of 4 quarts with a filter change.
I changed out the original oil at about 100 miles with Rotella non-syn to finish breaking it in. I'll run this for 1500-2000 miles, then start running 10w-40 Motorex fully synthetic. Great oil. On my Bandit 1200 and my XR650L, I was really suprised when I went from Mobil 1 to Motorex... could easily tell a difference in shifting and actually had to turn the idle down just a bit on both bikes after making the switch.
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln
'11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125
Thanks to my 2015 Sponsor: Motorex
What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663
Evomx971 is offline   Reply With Quote
Old 05-23-2011, 06:46 PM   #12
The Jerk
The Jerk's Avatar
Oddometer: 2,662
Manual does specify how much, 3.6L on an oil/filter change. Page 120. You're welcome.
2000 Kawasaki W650
Old 05-24-2011, 06:25 AM   #13
MOYZF
Oddometer: 11
Spectro Platinum Full Syn. 10W-40
I use Mobil1 Full Syn 10W-40 in my R1. The Spectro is arguably better, and it's only $10/liter vs. $12/qt.
Use what you want, change it properly, and you're OK. Triumph specs a 6,000 mile oil change interval, which is likely why they spec semi or full synthetic. I'll probably change it much sooner as 6,000 miles is a very busy season for the cold of IA.
MOYZF is offline   Reply With Quote
Old 05-24-2011, 10:37 AM   #14
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,563
Thanks Jerk
Old 06-08-2011, 08:47 PM   #15
-lurkster-
Oddometer: 24
Oil condition at first change
Anyone care to share their observations on the state of the oil drained at the first change? I have just changed the oil and filter after 380 miles, and it was darker than I was expecting, and opaque with very fine dark particles.
Because of the early change I stuck with Castrol 10W 40 semi-synthetic, will be keeping an eye on the sight glass but will probably go full synthetic in a few hundred miles.
-lurkster- is offline   Reply With Quote
Times are GMT -7.   It's 05:04 AM.
