Old 11-30-2013, 09:50 PM   #61
CheckerdD
CheckerdD's Avatar
Oddometer: 1,284
46,000 miles. Tires, headlight bulbs and chain as one would expect. I replaced the steering head bearings at about 30k. In response to an earlier post, your steering head bearings need replacement if you put the bike on the center stand and there is a notch or rough spot when you turn the wheel slowly back and forth. I also replaced a sidestand switch which was failing intermittently. This 2010 has been to South America and Alaska. RTW next year after I replace stator, fuel pump and filter, and wheel bearings which have not failed, but I don't want to risk them failing in Siberia. Dave
P.S. Installed Ohlins shock at 30k too. I consider this normal wear out time for the stock shock on a bike that has seen a lot of off pavement.
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 12-05-2013, 04:52 PM   #62
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
12,000 miles... At the 6,000 mile service, the dealership changed the rear wheel bearings and steering head bearings “as a preventative measure” under warranty. Other than that, I’ve only needed to replace rear brake pads and, thanks to an arrogant employee at a tyre shop followed by 20 miles of rather severe off roading, I had the pleasure of paying for a new chain when the original was stretched causing 4 links to fuse.
Can’t complain, absolutely love the bike although it has had more garage time lately as I supplemented it with a 2014 R1200GS in September. Once they local councils start salting the roads in about a month’s time it will be back in daily use...
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs screwed with this post 12-05-2013 at 05:05 PM
duffs is offline   Reply With Quote
Old 12-05-2013, 06:34 PM   #63
Snowy
Oddometer: 1,730
60,000 odd kms in 2 and 1/2 years. Most of that was in the first year.
Almost all of it has been 2 up, on trips mostly involving 50/50 highway/full off road
For a total of:
Rear wheel bearings - replaced twice
Front wheel bearings - replaced 3 times
Steering head bearings - replaced twice
rear upper shock bolt - who knows...I bought 6 new high grade bolts , the 2 kits I bought had new bolts, I think there are 3 bolts left....that means I've bent...thinking...about 5...I dunno, I gave up counting, I just change them every time it's apart.
Indy kit - failed
The other kit (Best rest...whatever it's called) - still going strong, modified.
Ohlins shock revalved and resprung 3 times. Needs rebuild now.
Forks - replaced completely at 45,000km from memory. Working fine to date.
New chain, sprockets. Front sprocket I think I'm on number 3...or 4...can't remember. Rear on number 2 still. I have a couple of spare fronts in different sizes that are part used.
New power outlet socket.
New battery
New regulator/rectifier
I think I'm on about the 10th set of tyres...
About the 5th set of HD tubes.
I complete headlight assembly failure (due to immersion)
Fuel filter blockage and subsequent replacement with alternative filter
On my third set of bash plate rubber mounts.
2nd set of of the under seat bridge rubber mounts (yes, I accidentally locktighted some fixtures that I shouldn't have)
About 12 genuine oil filters
On my 4th set of rear brake pads.
the service warning has been on for nearly 50,000kms. I just change the oil and filter every 5000 and ignore it.
Fuck...this is getting expensive. I've paid as much in parts and consumables as I have for the bike so far....that's depressing....
Snowy is offline   Reply With Quote
Old 12-05-2013, 07:43 PM   #64
runnin4melife
Oddometer: 804
Snowy, my check engine message is on all the time too. I figure if it goes out I am in trouble ;-)
runnin4melife is offline   Reply With Quote
Old 12-06-2013, 02:04 AM   #65
Snowy
Oddometer: 1,730
Yeah, the dealer wont switch it off unless I get it serviced there.
I've seen their guy at work. No thanks.
Old 12-06-2013, 05:58 AM   #66
roadspirit
Oddometer: 136
75,000 kilometers
45,000 of them on long trips (greece to pyrenes, greece to nordkapp, south america crossing)
the rest commuting and weekend rides
  • replaced leaking head gasket under warranty (at 16,000 kilometers)
  • replaced front fork springs with hyperpros (at 20,000 kilometers from memory)
  • servicing the bike due to the upcoming trip to south America, when it had 43,000 klms:
    • replaced rear shock with hyperpro, what an improvement it was!!
    • replaced front and back wheel bearings, preventative
    • replaced clutch disks and kit, preventative
    • replaced battery with DEKA, preventative, it still goes strong even after having been totally drained due to ...
    • ... burnt stator, at ~ 55,000 kilometers while in Ecuador. Replaced there in local BMW dealer.
    • replaced chain and sprockets, then and after the end of the trip.
  • brakepads, once front and the second time is near, twice back
Also, after the south america trip I had to replace the front rim. Put an Excel with hardened spokes. Should have done that before departing, now the OEM rim is badly beaten.
That's it so far, I can't think of anything else. I love my bike.
John
south america trip
roadspirit is online now   Reply With Quote
Old 12-09-2013, 05:23 PM   #67
sarathmenon
Oddometer: 940
Another data point:
15k miles so far. Things I had to change:
  1. Rear and front tyres
  2. Fuel pump (under warranty)
  3. Water pump (under warranty)
  4. New chains and sprockets on it's way
It's been mostly trouble-free, and the bulk of the miles were on highway. I don't think there is a more versatile and nicer bike on the market right now.
sarathmenon is offline   Reply With Quote
Old 12-10-2013, 07:29 AM   #68
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
22,000 some odd kms. But the you have been what I call big kms. Mostly weekend trail riding. Putting on 4 the set of knobbies. Rear wheel bearings just popped in set 3 or 4. Can't remember. Fronts are about the same. Too much stupid water. 3rd set of chain and sprockets. On my second skid plate. Snapped a windshield off but it was a tall one and my face got in the way. Had to replace the headlight bulbs after a little tip over in a lake where they got submerged. Worst part was that a buddy filming forgot to hit record! Bent the shock bolt a little but the Indy kit has solved that. Have gone through quite a few sets of brake pads. Sand and mud just eat them up. Ordered the headset bearings to do this winter. Also have that valve cover gasket to swap as it is weeping pretty good. Bike runs great. All issues my fault.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 02-15-2014, 04:05 PM   #69
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,554
67,000
Still on factory everything, even tires.
Kaw4Life is online now   Reply With Quote
Old 02-16-2014, 08:33 AM   #70
BlueRidgeKat
Daily Commuter
BlueRidgeKat's Avatar
Oddometer: 259
Originally Posted by Kaw4Life View Post
67,000
So that's 67,000 tenths of a mile = 6700 miles
BlueRidgeKat is offline   Reply With Quote
Old 02-16-2014, 09:42 AM   #71
sarathmenon
Oddometer: 940
67,000
Man, at that mileage, the steel in the tires must be showing? Please tell me that you at least changed the oil
Old 02-16-2014, 09:55 AM   #72
nelsonov
nelsonov's Avatar
Oddometer: 11
Wink Working on it...
Got my 2011 3 months ago with 1943 miles, turned over 4000 yesterday.
I'm not a dealership guy, but it's made two trips to the shop. One for the obligatory 35-month warranty fuel tank replacement, and the second to fix the fuel tank leak caused by improper tank installation (creased gasket).
I'm guessing I'm good now for quite a while...yes, my service light will remain on until I pick up a GS-911
nelsonov is offline   Reply With Quote
Old 02-17-2014, 04:51 AM   #73
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,554
13.4 oil changes
Would have been 15 sets of TKC's but I gave up on them after the third set. Run K60's now, make a lot of noise at first but they wear like iron and get the job done.
Old 02-17-2014, 05:00 AM   #74
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,554
Wouldn't that be 40,200 miles?
Truth be known I have gone thru ....
Water Pump
Clutch (my fault, bar risers without longer clutch cable)
Head Lamp (reflector burn)
Rear Wheel Bearings (again my fault, did not know about replacing spacers now and again)
4 Sets of Rear Brake Shoes
Just now Replacing Front
4 Chain/Sprocket Sets
Left Heated Grip
4 Sets of Rear Wheel Spacers
All Very Much Worth It !!!!
Love this bike!
(although I would love more HP)
Old 02-17-2014, 08:20 AM   #75
BlueRidgeKat
Daily Commuter
Oddometer: 259
It would be if it were 67,000 km which was not specified.
I was just trying to find a formula where at 67,000 anything you could possibly still be on the tires that came on it as you stated and that was the only one I could come up with.
Times are GMT -7.   It's 05:18 AM.
