Old 05-17-2011, 03:30 PM   #1
Kytann OP
Kytann's Avatar
Oddometer: 177
How to waterproof my leather jacket
I'm asking. I've never done it before, and I've been caught in a few rainstorms where the jacket seems to soak up the water, not repel it.
It's a First Gear, not that that detail matters much, that I got used several years ago, so it's probably 10 years old now.
I know the best waterproof gear is Aerostitch stuff, but I'd really rather just spend $20 on some waterproof oil or something for my jacket than buy another jacket. Not to mention Aerostitch stuff is really expensive..
Kytann is offline   Reply With Quote
Old 05-17-2011, 03:34 PM   #2
T
stay classy
T's Avatar
Oddometer: 5,397
I've used the Nikwax for leather on boots and gloves; works quite well. Never tried it on an entire jacket but it should work...
Inconsequential Adventurer
T is offline   Reply With Quote
Old 05-17-2011, 03:35 PM   #3
P B G
Oddometer: 10,001
Variety of products are available, I've used a nikwax product before on leather boots. You basically cannot waterproof the seams and zippers if they are not designed to be so, but you can overall reduce the amount of water that gets into the leather in brief drizzle.
Get a rain suit to throw over your jacket.
Old 05-17-2011, 03:40 PM   #4
Kytann OP
Kytann's Avatar
Oddometer: 177
Yeah I actually own a rainsuit, for when there is an actual deluge of water.
I'm more talking about how the jacket seems to soak up water like a sponge, and get really heavy. So I suppose water repellant is more like what I'm looking for. Something where a medium rainshower won't bother the jacket.
The leather feels pretty soft when dry. I've oiled it a few times, usually using the stuff made for car seats. Seems like that should be fine, right?
Old 05-17-2011, 03:50 PM   #5
SF_Rider
Oddometer: 449
Treat it...
There are a lot of products out there to clean and 'treat' the leather. Bottom line, all leather needs to be treated. Since it's dead and not receiving the natural oil it would when alive you need to do this for it.
One of the better products I've used on leather is called bag balm. Comes in a square green container (http://www.google.com/products/catal...322#ps-sellers)
Stuff works great on condition leather and will help with repelling water. Not good for suede however. This stuff works great and is something you should use on leather often.
SF_Rider is offline   Reply With Quote
Old 05-17-2011, 04:04 PM   #6
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,089
back in the day, regular treatments of mink oil
I'd probably still lean that way unless it was a really technical newer leather.
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 05-17-2011, 04:16 PM   #7
TexanInSeattle
TexanInSeattle's Avatar
Location: Somewhere around Barstow on the edge of the desert
Oddometer: 323
sno-seal
http://www.campmor.com/sno-seal-orig...ci_sku=10603WC
this stuff worked great on my boots...does darken the leather a bit
TexanInSeattle is offline   Reply With Quote
Old 05-17-2011, 09:19 PM   #8
squish
Out of the office.
Oddometer: 6,263
No really, you can try things like sno seal or the like but lots of them aren't even good for the leather.
But i've found that the best way to waterproof a leather jacket is either a rain jacket over the top or break down a buy a textile jacket.
On vacation for a spell
squish is offline   Reply With Quote
Old 05-18-2011, 09:58 AM   #9
Kytann OP
Kytann's Avatar
Oddometer: 177
Not helpful in the slightest bit.
I'll give you a clue, we sometimes have huge downpours of rain that cover the entire state. If it's going to be like that, I'll take the car. Sorry, I ride for fun, and if it's no fun than why bother riding?
We also have days where it'll be absolutely beautiful over most of the state, with pockets of scattered heavy storm, usually no bigger than a city. So you'll be riding along and bam, you're in a downpour for five minutes, then you're past it and you can move on. This is the situation I'm asking about.
In that situation, I could:
1. Stop and put on my raingear. Which is the no shit sherlock response, but is still kinda a pain in the ass when the rain is past five minutes later and you gotta stop again to remove the raingear. This is what I currently have to do and was looking for alternatives.
2. Add some sort of oil to the leather so it mostly shrugs off the water. Not worry about it and just keep going. Maybe some water will seep in the sippers in those five minutes, but that's not a big deal. This is what I asked a question about
3. Buy a textile jacket. I already said earlier in my post that I was not interested in getting a textile jacket, aerostitch or otherwise. Did you fail reading comprehension or something? No money for it and frankly they're fucking ugly and uncomfortable. Whereas my leather jacket I wear as a street jacket all fall, winter and spring in addition to wearing it on the motorcycle.
Old 05-18-2011, 10:01 AM   #10
Kytann OP
Kytann's Avatar
Oddometer: 177
I've gotten three good responses.
Ph0rk - I've used Mink oil in the past on boots. Since that's the most natural option I'll probably go that route.
SF_Rider - that Bag Balm stuff looks like it's for living skin. It's always been my understanding that lotions and things meant for living skin can be alot harsher than the stuff meant for leather because living skin will replenish itself, whereas dead skin (leather) will not. Thanks for the suggestion but I'll skip that stuff.
TexasInSeattle - Snoseal? Never heard of it, but that's not a surprise. I haven't heard of alot, which is why I'm asking. Looks like it's meant for boots, which alot of this stuff probably is going to be meant for boots. They probably even have it at the local REI. I'll check it out, thanks.
Old 05-18-2011, 10:37 AM   #11
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,106
you won't like it, but you cannot waterproof a leather jacket . . .
you can't even make it highly water resistant, without clogging the pores and basically taking years off the life of the jacket.
if you are treating it with a quality leather food/treatment, it should not immediately soak up water in a drizzle. In deluge, though, you will be SOL.
If you insist on waterproof leather, see Aerostich Transit.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 05-18-2011, 12:05 PM   #12
Kytann OP
Kytann's Avatar
Oddometer: 177
I have very water resistant leather pants. Whatever they applied at the factory is still new enough to be effective, so I'll take your comment as uninformed.
I should know better than to ask this site for leather questions. You all wear your space suit textiles, not leather, therefore what would you know about leather? I gotta ask people that actually wear leather.
Mods please delete this thread, it serves no purpose other than frustration.
Old 05-18-2011, 01:14 PM   #13
Sport
Oddometer: 350
Sno Seal
Sno-Seal Original Beeswax Waterproofing protects leather from rain, sun, snow, and salt. The beeswax formula dries to a solid wax that "stays put" in the surface of the leather so it lasts longer.
Our competitors' greases, oil, and animal products are able to migrate through the leather till they clog all the pores. These waterproofing products fill the natural spaces that are supposed to absorb perspiration and insulate.
In addition, animal fats weaken and rot leather. The tannery worked hard to remove the fats and preserve the leather, so it's hard to imagine why you'd put it back on.
Sno-Seal will help you feel more comfortable in Gore-Tex® fabric lined boots because it allows the Gore-Tex®-absorbed perspiration to escape out of the leather.
And not only will Sno-Seal keep you warm and dry, it'll also help you from getting tired. A typical leather boot can soak up to a pound of water. That means you lift an additional 2,212 lbs. to walk one mile. Sno-Seal keeps the whole boot dry, warm and light.
SNO-SEAL
  • Enjoy dry feet all day!
  • Prevents water from penetrating leather.
  • Lubricates and conditions leather without softening.
  • Preserves and lengthens the life of leather.
  • Does not interfere with the natural breathability of leather.
  • Extremely resistant to salt stains and spotting.
  • Does not soften heel counters or box toes.
  • Will not damage seams or welts.
  • Maintains flexibility in freezing temperatures.
  • Will not crack during continual flexing of leather.
  • Does not deteriorate like other products containing animal fat.
  • Contains no silicone.
Works well on leather boots but have never tried it over a leather jacket but for less than $10 or less than $20 for a whole quart, you can give it a try.
Sport is offline   Reply With Quote
Old 05-18-2011, 02:34 PM   #14
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
You may not feel he's being helpful, but he's correct. You're never going to make that jacket "waterproof". All you're going to get with "treatments" are varying degrees of "water-resistant".
Ah, so you're not interested in the right answer, you just want someone to tell you what you want to hear.
Yeah. You may want to try another site.
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux screwed with this post 05-18-2011 at 02:41 PM
Xeraux is offline   Reply With Quote
Old 05-18-2011, 02:39 PM   #15
Kytann OP
Kytann's Avatar
Oddometer: 177
Yes, and that's the goal I said I was trying to achieve, as I stated before
Therefore by not reading the question I was asking, his comments were not the slightest bit helpful. And neither were yours for that matter
The Snoseal suggestions is a good one. From what I've learned in the last day and a half Beeswax is one of the best things to use for waterproofing leather.
Times are GMT -7.   It's 01:11 AM.
