04-12-2012, 09:51 AM
#2836 | |
Back Home
Oddometer: 1,546
04-12-2012, 11:35 AM
#2837 | |
Deaf on Wheels
Oddometer: 2,048
Thank you....
Labrador Ride 2008: Alaska Ride with Sidecar- 2009: Newfoundland 2010 TAT 2011-2012 |
04-12-2012, 11:43 AM
#2838 | |
Web Adventurer
Oddometer: 547
Depends how you wire the mount. If it's wired to switched power then it won't charge. If it's wired to an always on source (like directly to the battery) then it will charge all the time.
IBA #33260 |
04-12-2012, 01:09 PM
#2839 |
Oddometer: 14
battery life
Does anyone have any experience with the battery life on the Montana? Is it really as advertised to be 22hrs for the AA and 16 for the lithium-ion?
04-12-2012, 01:29 PM
#2840 |
Oddometer: 623
Probably if you enable the battery save mode after the back light timing out but the screen will be black and of no use until you touch and wake it up. My Li battery went 12 hours without using the save mode and the back light timing set to 15 seconds. GH
04-12-2012, 01:55 PM
#2841 |
Oddometer: 14
Thank you for the quick response. I am trying to figure out if it will be possible to swap between multiple bikes just using the battery option, or do I just wire both bikes.
04-12-2012, 02:42 PM
#2842 | |
Long Haul Adventurer
Oddometer: 3,166
![]() Cheers,
Cheers, Dan DRTBYK screwed with this post 04-13-2012 at 08:24 AM |
04-12-2012, 03:33 PM
#2843 | |||
Oddometer: 2,491
looks like North America pay $65 for City Navigator CD, then search for world maps that's much better than Garmin. what about the lifetime renewal maps from Garmin?
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
04-12-2012, 04:06 PM
#2844 | |
What?!!!
Oddometer: 231
I'm still hot... it just comes in flashes now.
04-12-2012, 05:12 PM
#2845 |
Procrastinators
Oddometer: 5,768
You still need to buy the maps first before buying the Lifetime updates but with a Montana, I think the Lifetime Updates is worth getting. Odds are you'll have the Montana for quite a long time.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-12-2012, 05:28 PM
#2846 | |
Deaf on Wheels
Oddometer: 2,048
Cheers...
04-12-2012, 05:31 PM
#2847 | |
Oddometer: 1,122
or similar |
04-12-2012, 05:34 PM
#2848 |
Back Home
Oddometer: 1,546
+1
04-12-2012, 06:21 PM
#2849 | |
Rusty 2009 BMW R1200GS Adventure 1999 DR650 2007 DR200 |
04-12-2012, 06:38 PM
#2850 | |
Oddometer: 79
http://advrider.com/forums/showpost....45&postcount=7 The adapter has three wires -- you only use wires #1 and #3 (I think wire #2 is voltage-variable and used as a speed input for certain BMW GPS receivers). This post tells you the pin outs: http://www.advrider.com/forums/showp...8&postcount=15 The adapter plug is switched (i.e., it will shut off about 30 seconds after the ignition switch is shut off). Once the adapter circuit powers down, your Montana will display a message asking if you want to keep the unit powered on using it's internal battery. Otherwise, the unit shuts off in 30 seconds. |
