08-05-2012, 09:18 AM
#4576 | |
OX Ambassador
Oddometer: 419
08-05-2012, 09:39 AM
#4577 | |
What?!!!
Oddometer: 236
Working on it now. I will report back shortly.
I'm still hot... it just comes in flashes now.
08-05-2012, 09:57 AM
#4578 |
What?!!!
Oddometer: 236
Preliminary test results:
I loaded up 2 routes from and to the same points. Both created in Basecamp; one with motorcycle profile (interstates ok, no dirt roads) and one with dualsport profile (no interstates, dirt roads ok). The motorcycle route followed the interstates as routed in Basecamp. The dualsport route created a completely different route than what I created in Basecamp. It did not follow interstates but it wasn't the route I created. I think I just wasted a ton of time and effort creating my routes in Basecamp if the Montana is going to do something else with them.
woodsatyr screwed with this post 08-05-2012 at 10:08 AM |
08-05-2012, 11:03 AM
#4579 | |
OX Ambassador
Oddometer: 419
08-05-2012, 11:12 AM
#4580 | |
What?!!!
Oddometer: 236
I get now. No matter what I do in Basecamp, Montana is going to do its own thing based on the profile settings in the Montana. So in order to deviate from that, I'll have to add in waypoints to force it to go where I want. This is really no big deal. It's doing what it's supposed to do. In the routes that I created for this test, I only had start and end points. In Basecamp, I just clicked out my route using the route tool. But the click points are NOT waypoints and therefore, when transferred into the Montana, they basically don't exist. If I want it to go to those click points, I need to create waypoints and add those to the route. This is good. I'm learning and can now adjust my routes as needed.
woodsatyr screwed with this post 08-05-2012 at 11:37 AM |
08-05-2012, 12:11 PM
#4581 |
ED RN Adventurer
Did you change the profile in the Montana from the Automobile (with avoidance setups) to the "Dualsport" (Offroad with avoidance setups)? I am sure that would make a difference on the routes you created in Basecamp. The Montana is still going to do what YOU tell it to do, through those different profiles and setups, no matter what Basecamp profile you used.
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me? “When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama Life is Risk Management '09 BMW F800GS-Fate Honeyed GSabelle |
08-05-2012, 12:25 PM
#4582 | |
What?!!!
Oddometer: 236
08-05-2012, 12:27 PM
#4583 | |
Long Haul Adventurer
Oddometer: 3,178
Cheers,
Cheers, Dan |
08-05-2012, 12:52 PM
#4584 | |
What?!!!
Oddometer: 236
Hmmm. That's not how mine is working. If I go to route PointA_to_PointB and I'm in my motorcycle profile (as described above), it will route along the interstate. If I change the profile to dualsport (as described above), it will recalculate the route and route me away from interstates. Both profiles are "along road" routings. Each time I switch profiles, it recalculates based on the profile settings.
08-05-2012, 12:53 PM
#4585 | |
Procrastinators
Oddometer: 5,798
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
08-05-2012, 12:56 PM
#4586 |
What?!!!
Oddometer: 236
That's exactly what they are. One avoids interstates and the other doesn't.
Perhaps I'm not understanding what DRTBYK was saying re: direct routing. I thought he said that no profile setting would change the calculation unless one was along road and the other was direct routing.
08-05-2012, 12:58 PM
#4587 | |
Oddometer: 3,178
Cheers,
Cheers, Dan |
08-05-2012, 01:12 PM
#4588 | |
What?!!!
Oddometer: 236
All my routes are created in Basecamp. Once transferred to the Montana, the routing will change based on my profile settings.
08-05-2012, 03:29 PM
#4589 | |
OX Ambassador
Oddometer: 419
08-05-2012, 03:33 PM
#4590 |
What?!!!
Oddometer: 236
Haha! Yeah, so I found out. Got it all under control now. A tweak here and there and I'm good to go. I have 22 routes for the trip - some are side trips or scenic options off the main one.
