Thread Tools Search this Thread Rating: Thread Rating: 396 votes, 4.93 average. Display Modes
Old 04-20-2013, 08:18 AM   #7576
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,847
Originally Posted by atlas cached View Post
Sounds like you are using Mapsource?
If you use BaseCamp (and you should), you will not have the issue of overwriting maps on the uSD Card.
Everything you need to know about loading maps on your Montana can be found here.
Thanks, I'll check out that link. And I am using Basemap rather than Mapsource.
After reading through that link it looks like maybe I should be setting the 600 interface to "Spanner" for easier map loading verses the Basemap Mapinstall program. Does that make sense?
2012 wr250r
You don't know what you don't know
findLadukebob
Ladukebob screwed with this post 04-20-2013 at 08:33 AM
Ladukebob is offline   Reply With Quote
Old 04-20-2013, 09:41 AM   #7577
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,847
So with the interface set to Spanner and Mass Storage selected when I open MapInstaller with my device selected and dropped down, in my case "H drive" which is my SD card when I open that up it shows nothing stored there. The storage gauge on the right shows 16 gigs of available space on the drive. But when I open the H drive and click properties in "My Computer" it shows the 24k west map as using about 3.4 gigs.
When I clicked on the 24k north central map to install to the H drive I got a warning that I exceeded 4 gigs which to sounds like it's looking at the internal storage of the 600. Not sure if I'm missing a setting in the 600 somewhere. It looks pretty straight forward so its pretty confusing why MapInstall isn't showing whats on my SD card (H drive)
2012 wr250r
findLadukebob
Old 04-20-2013, 10:40 AM   #7578
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,082
Ladukebob, I am an amateur compared to a lot of folks who post in this thread, but when I wanted to upload 24k topo maps to my memory card, the view in basecamp looked like the image below. No setting anything to spanner or anything to anything else. Maybe I am misunderstanding your issue, so apologies if so.
I simply had the map set I wanted as the selected one at the top of BaseCamp:
Then, with my Montana connected, I right-clicked on User Data, and selected Install Maps on Memory Card.
Old 04-20-2013, 11:12 AM   #7579
bighopper
Oddometer: 190
Originally Posted by cablebandit View Post
OK, before downgrading to 4.6 (the last stable, glove friendly firmware) I think I got most of my major issues with 4.9 resolved. I ended up installing 4.9 and then doing a master reset. As a result I now have distance to next (with lane assist) as well as the speed limit. The indicated speed also now changes to red again when exceeding the limit. I'll poke along some more with 4.9 and reserve final judgement for a little longer.
I guess the key here is to always do a master reset after any firmware update.
Well I have checked mine after the 4.9 upgrade & the 'Speed' doesn't change to RED well exceeding the speed limit, either while navigating a route or just plain display map mode. But on bringing up the Trip screen (touch 'Speed') the 'Speed' is showing RED when I exceed the speed limit!
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 04-20-2013, 11:21 AM   #7580
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,847
Thanks, yes I'm doing the same as you just posted. That all works great. It's when I get to the MapInstall page that is the issue. If you open MapInstall does it show everything that's on that drive? Mine doesn't. No matter what's actually on it it doesn't show up. And with a 16 gig card I should have lots or room on it. But when I tried loading the North Central 24k it warned that I had exceeded 4 gigs, which leads me to suspect that I'm actually looking at the 600 internal memory rather than the sd card
2012 wr250r
findLadukebob
Old 04-20-2013, 12:33 PM   #7581
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Which OS, which version of BaseCamp, and which Version of MapInstall, please :)
The 4GB warning is because you can not save files that large on any device formatted in FAT32. Both the Montana and the uSD card use FAT32.
When you get to step 4 of installing maps with MapInstall, do you not have any maps listed in the left column? Is it completely blank?
atlas cached is offline   Reply With Quote
Old 04-20-2013, 12:44 PM   #7582
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,082
Mapinstall page? Where does that come from? When I do the steps I mentioned above, the maps get installed. I go to map setup in the Montana later (without it being connected to the PC) and see what my choices are for which maps I can enable or disable in order to check that it loaded.
When it is installing after I make the choices as shown above, the little green line that shows loading is clearly associated with my memory card.
ETA: With the Montana attached to the PC, I can use Windows Explorer and look in the Garmin folder on the Montana and on the memory card.
Map file on Montana internal memory:
Map file on memory card:
Perhaps I am missing your point.
Emoto screwed with this post 04-20-2013 at 12:55 PM
Old 04-20-2013, 01:05 PM   #7583
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,847
The 4GB warning is because you can not save files that large on any device formatted in FAT32. Both the Montana and the uSD card use FAT32. How do I go about fixing this?
Did not know about the FAT32 thing. Basecamp version 4.1.2 and yea when I get to step four that section where you would see the programs is blank. How do I go about fixing the FAT 32 thing?
Well that's what's confusing. When I open the sd card in Explorer I do see the same GPX folder and the 24k West map that I have loaded. But in MapInstall nothing. And I can only load one map. Meaning that if I try to load a second map the first map gets deleted.
2012 wr250r
findLadukebob
Old 04-20-2013, 01:32 PM   #7584
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 488
Using Topo maps in Basecamp sans GPS?
Need a little help. Here are the facts:
Destroyed my last GPS
Am going to purchase a 600 by the summer but have no GPS currently
Have Basecamp
I want to purchase Topo maps now to start planning and to overlay in Basecamp on some saved tracks(again for planning).
Question:
1) At the time of purchase, I have to state the model of GPS I am going to purchase(Montana 600, 650 or 650t), and does this lock me into the model I stated? Example, if I say I'm purchasing the maps for a Montana 600 could I actually purchase a 650t and still be able to use these maps?
2) Can I load these maps into my computer(Mac) and use in Basecamp for planning, without having the GPS in hand yet?
Thanks for any help.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 04-20-2013, 01:38 PM   #7585
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,844
Have Basecamp
Question:
You can purchase the Garmin US Topo 24K maps anywhere independent of the GPS they will reside on. They are not locked to a single GPS. If you are purchasing form Garmin and they are asking this question, it is most likely so they can determine if the maps will actually work on that device.
Yes, purchase them now and install them on your Mac-BaseCamp. Then when you get your GPS, you can install them onto a µSD Card and us it in your GPS.
See answer in quote:
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-20-2013, 01:42 PM   #7586
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 488
Cheers,
Thanks, thats what I needed! Corporate crap just confused me.
Edit: Just tried to purchase the "TOPO Canada: Northwest" download via Garmins site and it would not allow me to do so unless I first registered a device complete with serial number. Is there a workaround?
MitchG screwed with this post 04-20-2013 at 02:12 PM
Old 04-20-2013, 01:52 PM   #7587
atlas cached
OX Ambassador
Oddometer: 688
Did not know about the FAT32 thing. Basecamp version 4.1.2 and yea when I get to step four that section where you would see the programs is blank. How do I go about fixing the FAT 32 thing?.
How many maps installed in BaseCamp?
All maps installed on your computer should show up there.
What OS (again)?
Perhaps re-install MapInstall and try again?
Old 04-20-2013, 02:16 PM   #7588
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,847
What OS (again)?
Loaded US 24K West and US 24K North Central maps from disk onto PC running Windows 7. BaseCamp installed when I downloaded one of the maps. They both show up fine in BaseCamp. What I'm trying right now is I moved one of the maps into the GPX folder on the sd card while I'm installing my other map. Once this second map is finished loading onto the sd card I'm going to move the first map back out of the GPX folder. Not sure why I think that will work but what the hell.
2012 wr250r
findLadukebob
Old 04-20-2013, 02:30 PM   #7589
DRTBYK
DRTBYK's Avatar
Oddometer: 5,844
Sorry, I was following the pervious 24K Topo discussion and just inserted the thought that you wanted them. The Garmin TOPO Canada: Northwest map is a "LOCKED" product = Licensed to a single unit. Some maps are Locked and some are not. You may be able to find a free Canada Topo map.
Cheers,
Cheers,
Dan
All Things GPS
Old 04-20-2013, 02:33 PM   #7590
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 488
Cheers,
Again, many thanks for the reply. Understood, I need to find "unlocked" maps.
Times are GMT -7.   It's 08:50 PM.
