Thread Tools Search this Thread Rating: Thread Rating: 430 votes, 4.94 average. Display Modes
Old 06-06-2013, 07:05 PM   #8251
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,637
Originally Posted by dvmvm View Post
I assume you did the trip with firmware 4.90 or earlier,right?
As you already assumed, it has something to do with the "last known position" in .position.gpx. I have to elaborate a little deeper than earlier, for you to understand the issue.
The location in .posoition.gpx is updated about once a minute and it is filtered over some points, so it is much slower following your route. When you power-off the Montana shortly after stopping your bike, the last known poisition is a location about 1 minute ago. You can drive some miles easily in that minute.
At power on WHILE STANDING STILL, this wrong position is logged, together with a wrong timestamp (current time). The wrong timestamp causes speed spikes. The wrong position causes straight lines to a location somewhere a minute before the last tracklog position.
If you power-on the Montana while moving, this error is not occurring.
I just checked the 5.0 behavior: it is different.
It seems that the issue with the location from .position.gpx has been soved. I checked this while walking around with multiple power cycles. Several times I powered-on while I was moving, and several times while I was standing still. I observed the following:
  • When Keeping tracklog switched on, and power cycling the Montana, both power-on while standing still and power-on while moving resulted in track lines NOT being connected anymore on the Montana display. No different behavior anymore between standing still and moving.
  • No more speed spikes in Basecamp anymore with the tracklog being on while power cycling.
  • Tracks continue at the last tracklog point before the power cycle.
  • Basecamp still connects large straight lines if you relocate the montana while powered off with the tracklog still on.
    This connected straight lines might be expected as the tracklog is still on. But the Basecamp displays the track differently than the Montana does.
    Straight lines are drawn in Basecamp, because the Montana does not create separate tracks (trk /trk combinations) in the current track (current.gpx) at power cycling. Instead power cyces are recorded as track segments, just like lost-satellite conditions are.
    I would like consistent track display behavior between Montana and Basecamp.
    And I would like to have an option to automatically set the tracklog off/on simultaneously with power-off/on.
Can you check my findings?
Next i'm going to check the Montana and Basecamp track distance calculations with fw 5.0.
Yes I have not yet updated to 5.0 still on 4.90.
Awesome...I did not want to change to 5.0 till I knew what was going on.
I will do some more testing and will update to 5.0 in the morning.
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 06-06-2013, 07:09 PM   #8252
motoracer51
Oddometer: 659
Hey guys. Just got my Montana and see that it has 4.70 firmware. Should I update that first before installing maps?
Also, is there anything else I should do before loading maps.
Sorry if it has been covered in this thread, I just don't have the time to browse 500+ pages, so I apologize for possibly asking a simple question that has been answered already.
motoracer51 is offline   Reply With Quote
Old 06-06-2013, 07:12 PM   #8253
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
It makes no difference which firmware you have when you update your maps.
You might want to back it up first, though. Just copy everything to a backup drive somewhere.
I am running v 5.00 and it works perfectly for me.
Old 06-06-2013, 07:38 PM   #8254
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,637
Also for some of the other guys trying decide which Montana.
To me it's either 650 or the 650t.
I got the 650.
Which comes with the camera.
No its not a great camera but I use it as a visual waypoint marker.
Your out on the trail and you come across a cool waterfall.
#1 you could click on mark waypoint then edit then name it "cool waterfall".
Or #2 take a photo with the Montana.
The photos are geo tagged with GPS coordinates.
Also I have Topo 100k which I use mainly for hiking works great.
I also have a few custom (free) topo maps and they work great.
OSM FileDepot are great places to find free maps
Routing on the Montana is sometimes a little squirrely.
But I am still trying to figure this unit too.
But to me that's the fun in it.
I am still on the lower part of the learning curve.....but starting to feel the hump.
Fred
YouTube feed
Old 06-06-2013, 08:01 PM   #8255
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Fred
What? You never flew the Hump? How about your Dad?
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 06-06-2013, 08:11 PM   #8256
Rocky TFS
Rocky TFS's Avatar
Oddometer: 589
Well, that IS a gold recommendation!
Maybe I'll have to modify my cynical posts!!
On second thought, maybe I ought to wait a couple weeks...
2010 Yamaha TW200
Old 06-06-2013, 08:46 PM   #8257
Chip Stevens
Oddometer: 118
650t memory
After reading the last few days posts I would like to correct a miss conception of the 650t. Acording to JaVaWa device manager I have a total of 7.24 GiB of memory. I have no data card in the 650t. It brakes down as the following.
Topo U.S. 100k 3.1 GiB
Worldwide Autoroute DEM Basemap,NR 49 MB
Other files 584 KiB
Free space 1.81 GiB
I addeded CN North America NT 2013.4 1.8 GiB
I still have as much free space as CN took. Garmin advertises that the 600 and 650 models have 3 GiB of memory. From what I see my 650t has 3.5 GiB plus the topos. The topos can be removed from the 650t. If that is done the 650t would have more then twice the memory of the 600 and 650. chip
Chip Stevens is offline   Reply With Quote
Old 06-06-2013, 09:04 PM   #8258
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Other files 584 KiB
Free space 1.81 GiB
All documented for easy reference right here.
atlas cached is offline   Reply With Quote
Old 06-07-2013, 06:48 AM   #8259
motoracer51
Oddometer: 659
Quick question.
How do I send my CNNA on micro SD card to the internal memory on the Montana? I've tried via Basecamp, and loading both the Montana and CNNA in a MicroSD to SD adapter, and it wont copy to the device.
Can I only use the microSD in the Montana, and am not able to copy it to the internal memory?
Old 06-07-2013, 06:56 AM   #8260
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
Quick question.
You can move the file to the alternate location through Windows Explorer or Finder on the Mac once it's on the device. Makes no difference to the gps.
Old 06-07-2013, 09:27 AM   #8261
motoracer51
Oddometer: 659
Any specific folder I should send it to on the Garmin?
Old 06-07-2013, 09:44 AM   #8262
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
The x:\garmin folder.
Old 06-07-2013, 11:06 AM   #8263
iustin
Oddometer: 8
Quick question.
I'm not 100% sure, but almost so: maps on the micro SD card are copy-protected, and won't work on anything else than the original card…
iustin is offline   Reply With Quote
Old 06-07-2013, 11:08 AM   #8264
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,839
You're right. If they were bought on sd, then they are locked to the card. I missed that in the original post.
Old 06-07-2013, 12:42 PM   #8265
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,637
Well I updated to 5.0
Went for a 50 mile ride made several stops turned the Montana off then on everything look good till about mid way thru the trip than this------------
580 854 ft 2.6 mi 0:00:01 9509 mph 343.7° true 6/7/2013 2:05:04 PM N39 00.331 W84 36.990
And then a straight lint on the track.
So looks like this bug is still there ..better but still there.
Just to clarify this I stop turn the Montana off then turn the Montana back on and continue on my way (I did not move from my location) and yes the unit was all up and running before I moved.
I wonder why I don't see more people reporting this?
I mean it shows my speed as 9509 mph between points.
Fred
YouTube feed
Times are GMT -7.   It's 01:28 AM.
