Thread Tools Search this Thread Rating: Thread Rating: 432 votes, 4.94 average. Display Modes
Old 08-24-2013, 07:21 AM   #9256
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,994
Originally Posted by FireDog45 View Post
It wasn't just the icon that changed, it now starts the find intersection search. It's a different shortcut that I can't find in the shortcut menu to even edit. What's weird is the same type I use for finding fuel was left untouched but since I can't find where that one stored I can't reverse engineer it.
I'll try to post a picture of what they look like.
The Icon you are talking about is not a custom shortcut. It is a WhereTo? app. You put it there by going to Setup->Main Menu->Add->Application->WhereTo?->Intersections
If you do have a custom Shortcut that the Icon has been changed on due to the update, just do the following: Setup->Shortcuts->pick yours->Edit->choose your Icon and back out.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 08-24-2013 at 07:35 AM
DRTBYK is offline   Reply With Quote
Old 08-24-2013, 07:43 AM   #9257
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 817
Bingo! I knew it was different from a regular shortcut but couldn't remember exactly how.
Still not sure why it changed though. Where the "Intersection" icon is now is where the "Fuel" icon was before. I initially thought it just changed the icon but it changed it to search for intersection as well.
FireDog45 is offline   Reply With Quote
Old 08-25-2013, 11:45 AM   #9258
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,641
I put together a few wallpapers images for the Montana.
If anyone would like them go here to download free.
Not trying to make any money just doing it for the fun of it.
Just click on the picture and then the little arrow bottom right of the page to download.
Remember you need 4 images per set so if you like the one called "Map" then you need all 4 pictures.
Once there are download put them in the folder ---- Garmin/profiles ---on the Montana
Map_landscape_day
Map_landscape_night
Map_portrait_day
Map_portrait_day
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 08-25-2013, 11:52 AM   #9259
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,646
Those are really cool, Fred. Thanks!
Old 08-25-2013, 11:58 AM   #9260
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
Fred
Cool...of course if you want to save battery when you are handheld, a black background is best (those pixels are off).
Cheers,
Dan
All Things GPS
Old 08-25-2013, 12:08 PM   #9261
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,641
Good to know I'll keep that in mind of future sets.
YouTube feed
Old 08-25-2013, 12:31 PM   #9262
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,830
Thanks for those man. Those are pretty cool and I will certain make use of them.
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 08-26-2013, 08:14 AM   #9263
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,980
What folder would you put these in???
Love the Yamaha ones....
EDIT - Found it...
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc screwed with this post 08-26-2013 at 08:53 AM
mbabc is offline   Reply With Quote
Old 08-26-2013, 10:30 AM   #9264
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
Not sure if this is a troll, but...
Black background makes no difference in power consumption. Individual pixels are just liquid-crystal light "valves" letting the backlight through and the backlight power which is orders of magnitude more then the "valves", doesn't change reagardless of what the pixels are doing. The "valve" power change between black and white is almost non-existant (often it takes very slightly more to be black!)- switching the valves takes much more power than just sitting at one level so the power consumption of the "valves" is higher if they're switching a lot but they'll still be way, way less than the backlight...
SteveAZ is offline   Reply With Quote
Old 08-26-2013, 10:59 AM   #9265
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
Just got back from 800+mi trip through the AZ Mogollon Rim on through the White Mtns... not quite to NM but like Sarah, I could see it from my easternmost stop.
Aside from the "acquiring satellites" when map set to fast (with all the aerial imagery it was too slow at "fast" so I didn't feel like running it "normal") I didn't have any big bugs biting.
I ran 5.1 with logging set to one track point per second, about 7.5GB of BirdsEye and like mentioned, "fast" map updates. Arghh, all the BirdsEye reeeeeeeally made for incredibly long boots and the resolution even at "high" just isn't good enough for picking out the trails when the ground cover gets more than thin. Fortunately I had loaded some much higher resoltution .jpgs copied from Google Earth for a couple of the areas I explored.
The "acquiring satellites" bug only hit twice. It seemed like it may have been shortly after either losing the satellites (tunnel) or poor reception (deep canyon) and then reacquiring, but without a satellite log I couldn't tell ya! With SD's I really wish I could log a lot of different things, but I digress...
Old 08-26-2013, 01:37 PM   #9266
BruceWA
Oddometer: 575
Am I correct to assume then that the "acquiring" issue is still present? You are using 5.1 and not 5.3?
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 08-26-2013, 03:24 PM   #9267
SteveAZ
SteveAZ's Avatar
Oddometer: 1,212
I thought about loading 5.3 but didn't feel like doing verification testing on this trip since I knew I'd have very little down time and it would be hard to do PC access if I ran into larger annoyances, so I don't know if it's present with 5.3. It definitely popped up while I was on the trip using 5.1 but it wasn't much of a big deal - only twice in all those miles (at least that I noticed) and both while doing two-lane highway on the way home. I was sort of lucky and noticed right away and just power cycled the unit both times although like mentioned power-ups take minutes with a lot of BirdsEye...
Old 08-27-2013, 04:11 AM   #9268
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,845
Montana's working perfectly with 5.3 and my auxiliary 78s works nicely to show geocaches along the way.
Old 08-27-2013, 04:35 AM   #9269
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,845
Originally Posted by atlas cached View Post
Looks promising, but I shall wait a bit longer before declaring this issue resolved :)
I heard from a guy on Facebook who says Garmin asked him to test 5.3 specifically wrt the problem. He had reported it to them back in 5.1.
Old 08-27-2013, 08:39 AM   #9270
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,818
I went ahead and loaded up 5.30 but haven't had time to try it out. Right in the middle of a motor swap on my Strom.
Times are GMT -7.   It's 12:00 AM.
