Thread Tools Search this Thread Rating: Thread Rating: 428 votes, 4.94 average. Display Modes
Old 01-21-2014, 06:12 PM   #10276
kbroderick
Oddometer: 1,087
Originally Posted by NickW909 View Post
OK, so I have loaded four OSM map files onto the SD card and renamed each of the files.
If I remove the map file that is working then one of the other map files works correctly, I can see the roads etc, but the others remaining only display the contour lines.....
I've tried editing the map name with a Hex editor, that doesn't help.
There's a map ID encoded separately from the name, and all OSM maps from the same source default to the same map family ID. The Javawa tools can change this, I believe.
kbroderick is offline   Reply With Quote
Old 01-22-2014, 06:39 AM   #10277
True North
True North's Avatar
Oddometer: 20
Originally Posted by atlas cached View Post
Please try this and report result:
I will try this and report back on Saturday.
True North is offline   Reply With Quote
Old 01-22-2014, 08:23 AM   #10278
NickW909
NickW909's Avatar
Oddometer: 584
Originally Posted by SteveAZ View Post
Try the javawa device manager if you haven't already. It identified the source of some of the problems I had...
OK, thanks for the info about javawa, it found the problem....
The problem is indeed a conflict in the name of the tiles.
All the regions created by osm2garmin share some tile names that are the same, in the format of 70000001.img etc
Can't see anywhere to change this within osm2garmin??
Nick.
NickW909 is offline   Reply With Quote
Old 01-23-2014, 12:32 PM   #10279
NickW909
NickW909's Avatar
Oddometer: 584
Nick.
Just in case someone else has this problem.......
Osm2garmin creates all maps with some of the map tiles using the same name sequence starting at 70000001.img, so having several maps loaded onto the GPS at the same time is not possible if you created them using osm2garmin.
The developer will look into changing this in a future release. I have used osm2garmin a few time now and it works well, a few teething probs getting it going, but I like it.
Solution: Have several map files in the root directory of the SD card and only one at a time in the /Garmin directory. Use a laptop or phone to move the map files around.
I suppose I should really get into the command line of splitter and mkgmap etc., but can't be arsed with that....
Thanks for the replies.
Nick.
Old 01-23-2014, 04:10 PM   #10280
ramz
Professional Trail Rider
Oddometer: 2,018
Will OSM Combiner make maps correctly?
http://www.javawa.nl/osmcombiner_en.html
ramz is offline   Reply With Quote
Old 01-25-2014, 12:41 AM   #10281
JD
JD's Avatar
Oddometer: 400
Question Sun visor?
Just wondering if anybody has found a sun visor that fits the Montana while it's in the rugged mount, or made one?
The last ride I did was a bit of a struggle to see the screen at times, so just looking for ideas to take off some of the glare.
JD is online now   Reply With Quote
Old 01-25-2014, 04:41 AM   #10282
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
Did you use one of the screen protectors which came with the Rugged Mount on your Montana? I find with the screen protector, there's very little glare most of the time.
I haven't seen a commercially produced shade for the Montana, though it wouldn't be hard to make one.
Emmbeedee is online now   Reply With Quote
Old 01-25-2014, 05:46 AM   #10283
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,810
For the simple fact that people use the Montana in both portrait and landscape modes, it would be a bit difficult to come up with a commercial shade that would be able to accomodate both and not look like ass.
Old 01-25-2014, 06:50 AM   #10284
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
I don't know about you but most people run their Montanas either in Landscape or Portrait, and not alternating between them, so making two different shades would make sense.
Old 01-25-2014, 10:32 AM   #10285
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,810
That's what I mean someone would have to make two different shades. Having been in the manufacturing business I can tell you, I'd prefer NOT to have to make two items for something, when I can make one item for another. Much better ROI. I'm guessing that's the reason why no one is making em ATM.
Old 01-25-2014, 11:02 AM   #10286
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,978
I suppose that depends upon what your definition of "correctly" is.
The folks at JaVaWa have done a very nice job of creating an application that will enable you to combine OSM Garmin compiled map tiles into a single map. You still have the device limits as to how many tiles the device will support and total map file size. Combiner just eliminates duplicate map tiles (among other things) which can and usually do cause issues.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 01-25-2014, 11:05 AM   #10287
DRTBYK
DRTBYK's Avatar
Oddometer: 5,978
The Montana display is highly optimized to use direct sunlight to brighten the display. If you are having glare issues, try using one of the Anti-glare screen protectors as Emmbeedee has suggested. Shading your display will just decrease visibility in direct sunlight.
Cheers,
Dan
All Things GPS
Old 01-25-2014, 06:22 PM   #10288
JD
JD's Avatar
Oddometer: 400
Yep, got one of the glare protectors fitted that came with the rugged mounts.
It's probably more pronounced at the moment because it's the height of summer here and very dry, so as a film of dust builds up on the display it gets even harder to read in the bright sunshine.
There doesn't seem to be anything commercially available so I might try reshaping a couple of old visors I have lying around from car GPS units.
Old 01-25-2014, 06:59 PM   #10289
Rocky TFS
Rocky TFS's Avatar
Oddometer: 587
....It's probably more pronounced at the moment because it's the height of summer here and very dry, so as a film of dust builds up on the display it gets even harder to read in the bright sunshine......
Hey, it's waterproof! just spritz the screen with some distilled water and wipe dry with a microfiber cloth, like the one for your glasses.
Oops , don't wear glasses? Just go to an optometrist and beg for one.
Or use a piece of chamois.
I clean mine after every ride in the dust, which is just as bad in Idaho as in Oz.
2010 Yamaha TW200
2014 BMW R1200 GS WC
Rocky TFS is offline   Reply With Quote
Old 01-25-2014, 07:03 PM   #10290
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
You could also try changing the angle you have it set to. Sometimes a couple of degrees makes a difference.
Times are GMT -7.   It's 03:26 AM.
