Old 02-15-2005, 04:46 PM   #1
SRG OP
SRG
SRG's Avatar
Oddometer: 1,325
640 Adv. Carb ?
My '02 640 carb - BST 40 - has 2 shim washers under the needle (part 36 in the exp. drawing on pg.14). One is silver and a little smaller (and thinner) than the other which is not silver. It also has a little step in the bottom of the slide where these shims sit which makes them sit off center/misalign w/ the hole in the slide. Is this set up correct? The clip is on the forth groove. Slide is drilled to 0.125". M. jet is 142.5 (stock) - change to 152.5? 155? KTM screen airbox sideplate installed. Exhaust is SXC. Central Va. +_ 500'.
Thanks,
SRG
SRG is offline   Reply With Quote
Old 02-15-2005, 04:52 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Thanks,
SRG
Sounds like someone decided they wanted a richer needle... I wonder why?
I'd start with a 152.5 and go from there. Leave the needle clip on the 4th groove and remove the non-stock washer, sorry I can't remember the correct "color".
Shimming is a common thing, but in this case I can't see the advantage.
Of course... if you say it has a killer mid-range... I may have to shim my needle.
So... how's tricks?
creeper screwed with this post 02-15-2005 at 04:57 PM
creeper is offline   Reply With Quote
Old 02-15-2005, 05:00 PM   #3
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Daymn, Creep, ya find the right girl ya won't haveta shim yur needle anymore
Rad is offline   Reply With Quote
Old 02-15-2005, 05:04 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
When the mood strikes... sometimes it's easier to shim your own needle than look for a helping hand, ya' know?
So... how's tricks?
Old 02-15-2005, 05:12 PM   #5
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Spoke'n by a guy do'n head work for a live'n
Old 02-15-2005, 10:05 PM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Oh quit it you big brute... yer' gona' make me all verklempt.
So... how's tricks?
Times are GMT -7.   It's 10:17 AM.
