03-23-2012, 09:59 PM
#601 |
ADVENTURE RIDER
Oddometer: 9
I have found that new Mitas E07 tyres seem to be very slippery on tar roads wet or dry when new & take several hundred km to improve.
Cheers GM. |
03-27-2012, 05:47 PM
#602 |
Oddometer: 250
Mitas E10, E09 Dakar or E07's?
Hey Guys,
So Im looking at a set of Mitas for my F650gs, but which ones? Alot of my riding is commuting to work, but I want something that if i point to a dirt/muddy road I can take it. I got the tourance EXP's on atm and I will probably switch back to them when I dont have any trips planned for a while so they will be more used for the trips on asphalt to wherever and dirt/mud/clay/sand, thats wher i want msot of my grip so i can fling it round like the motoX bike without the tourance EXP's slipping out with zero grip. So whats your thoughts on these tyres? I was contemplating TKC80's but $500+ a set compared to about $300 fitted. I heard the E09's had a manufacturing issue where they split down the seem, anyone else had that problem? |
03-27-2012, 05:53 PM
#603 |
GOMOB.
Oddometer: 1,590
Well.. I have E07 on my KLR. I used to have 606 and they amazed me by the way they could hang on when I was on the black top.
When I went to Birdsville last year and it was 90% bitumen.... I changed to E07. They amaze me by how well they work in the dirt. In fact now I have replaced them with another set of E07. I love them! First time ever I have replaced tyres like for like. I am always wanting to try something new.. but not this time. Hope this helps a bit.
Happy Snapper They have cradled you in custom, they have primed you with their preaching, They have soaked you in convention through and through; They have put you in a showcase; you're a credit to their teaching -- But can't you hear the Wild? -- it's calling you. www.clayfieldstudio.com www.australianminingphotography.com |
03-27-2012, 05:54 PM
#604 |
Grumpy Adventurer
Oddometer: 3,241
http://www.advrider.com/forums/showthread.php?t=289725
http://www.advrider.com/forums/showt...ighlight=Mitas Google is your friend
Sleepy John '10 R1200GSA Big Pig, '10 DR650SE Piglet Don't shoot... It's only me! Women and cats will do as they please, and men and dogs should relax and get used to the idea. |
03-27-2012, 07:29 PM
#605 |
Oddometer: 250
Thanks guys. Ive actually found the Metzeler Karoo's to be cheaper than Mitas and without the quality issues Ive read about. Has anyone else had this issue?
Whats your thoughts on the karoo's vs the E10's? |
03-27-2012, 07:48 PM
#606 | |
Oddometer: 1,757
BTW,slightly OT but, if you want cheaper have a look at Shrinko 705 Radials Have 1500 klms on a set and cant fault them for general 80% tar 20% dirt tracks riding.
JohnG. JohnG. screwed with this post 03-27-2012 at 07:56 PM |
03-27-2012, 08:20 PM
#607 | |
Oddometer: 250
Cheers. |
03-27-2012, 10:29 PM
#608 |
Grumpy Adventurer
Oddometer: 3,241
E10 should be okay on the F650GS. The main problem was Fogo's KLR. Just too much power to the back wheel. You don't have that problem.
03-27-2012, 11:46 PM
#609 | |
All round nice guy
Oddometer: 5,921
Fogo's was an e o9 I think and its not just the power hes a hooligan to go with it ![]() ![]()
F5 is for wussies Command R is where the actions at! |
03-28-2012, 01:58 AM
#610 | |
Armature speller
Oddometer: 6,763
They go a lot better than you'd think by looking at them. They're my tyres of choice for anything short of off road racing on my TT350 and DR650. Similar to the E07 on the rear in my mind. $ to km ratio about the same. E07 slightly better off road and 705 slightly better on road. |
04-01-2012, 09:42 PM
#611 |
Good ol days my arse
Oddometer: 317
Long term E07 report
OK, 7500km in 3 weeks is long term isn't it??
Fitted an E07 on the rear of a 2012 KLR650 and then took it for a little ride to Sth Oz, the result..... The bike was like most on a long trip, heavily overloaded !!!! Pressures were run at 25PSI offroad and 35PSI onroad Gravel performance was good Bitumen grip was good, as a matter of fact you could corner quite hard Blacksoil mud was acceptable (did just as well as a Dunlop 606) White clay surface was good Red clay surface was down right dangerous (had to stay 20kph under the speed of other bikes running 606's) Sand was good Flat tyre at 100KPH on gravel (puckering moment) after a large nail made it's way through the tread near the centre bar. I hate tubed tyres, they go down like a new bride!!! At the 5000km mark it developed lateral cracks (the tyre that is) either side of the centre bar. These cracks do not seem to have increased since they first appeared Tyre is just worn down to the centre bar, looks like plenty of life still left Would I buy one again? Why not, that's a good compromise for an allround tyre Glen
Live every day like it's your last, one day you'll get it right!!! |
04-01-2012, 11:56 PM
#612 |
Kicker Brother
Oddometer: 3,048
Got a c-17 front and a c-02 rear
we will see if there ok this weekend ......price was right tho 220 fitted |
04-02-2012, 02:41 AM
#613 | |
I Bleed Green
Oddometer: 955
![]() KLX + E09 Dakar + Hooligan = ![]() ![]() ![]() ![]() ![]() H |
04-02-2012, 05:02 AM
#614 |
Oddometer: 250
top effort on those tyres..
I just did close to 600km on the E10's and only sh*t myself when i pulled out of the tyre shop n almost ended up on its side.. forgot about the slime shit on the top until they are worn in.. after a couple of hundred K's they were fine and even grerat in the loose stuff!! so far, top marks.. already starting to chip though.. but u get that when u realise at 100km/h if u open it up it fish tails across the dirt/gravel :P |
04-02-2012, 06:00 AM
#615 | |
Chronic Noob
Oddometer: 2,291
Sure looked the goods. No C17 in stock The extra $50.00 would have looked better on the bar but all good I can let you be the guinea pig and buy you a beer anyway.
If the Earth is flat why are my tyres round? |
