Old 07-20-2011, 01:15 AM   #46
jake28
Riding to the horizon.
jake28's Avatar
Oddometer: 391
The caliper mount is effective, though inelegant: well done. With your spacer/slleve solution, is there any concern with lateral torque on on the long allen bolt under braking? I'm sure it's fine, I'm just trying to visualize and understand all of the mounting points.
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS
jake28 is offline   Reply With Quote
Old 07-20-2011, 02:18 AM   #47
ontic OP
Oddometer: 1,070
Thanks for the comment,
and a very fair question, exactly the sort of critique I am looking for.
Honestly, I don't know and hadn't put much concern into that specifically (yet). I see what you mean though. I've just gone out to the shed again and tried to simulate as much braking load type forces as I can. The bracket assembly feels as solid as a rock. Literally. No matter which way I push, pull and tweak on it, as hard as I possibly can, I can't get it to move in the slightest detectable amount. Of course real braking load will be a much higher force than anything I can simulate with my two hands, so I am just going to have to keep an eye on it when road testing finally begins. I am also going to make a very well fitted sleeve for that bolt.
So yeah, my feeling is it will be perfectly fine, but thank you for raising that concern and I will keep an eye on it. This is all-seat of the pants stuff for me, so I could be very wrong.
The caliper itself on the top and bottom sort of floats on the caliper bracket on two rubber bushed pins that would probably experience similar 'lateral torque' as this allen bolt in question. There is actually a fair bit of play or wobble in the caliper on the bracket.
These are very heavy duty strong allen bolts as well. Beemer bits from my parts- not sure of original application.
Cheers,
P.S.
I spoke to Paul Rooney this afternoon about frame reinforcing and swing arm lengthening, amongst a bunch of other helpful details. Going to have to start a new piggy bank with his name on it
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 07-20-2011, 02:25 AM   #48
Sibbo
Oddometer: 355
A good thought on the allen screw .It would be good to have a very good fit on the sleeves so all the load is all shear rather than a combination of shear and bending .How does that sound ?
Sibbo is offline   Reply With Quote
Old 07-20-2011, 02:34 AM   #49
ontic OP
Oddometer: 1,070
Thanks mate, it sounds good, and is what I was thinking without putting the correct terms to it
I'll probably measure it all up precisely and get something turned up.
Cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 07-20-2011, 07:31 AM   #50
jake28
jake28's Avatar
Oddometer: 391
Note: I am not an engineer, but I have built a couple of bikes. Front end swaps, supermoto conversions, and a substantial application of baling wire and duct tape is fine but when braking is concerned, I often take the straight and narrow path.
A second look at your photos has me more convinced. If the lower mounting point has the bolt running through both brackets and the fork leg, it should take a good bit of the flexibility out of the system. As a precaution, I would get/make a sleeve for the upper bolt that with an ID that matches the bolt and an OD like that of the fork lug. This sleeve should then have enough clamping surface area between the brackets to reduce the amount of lateral force that the bolt is subjected to.
Old 07-20-2011, 08:29 AM   #51
ontic OP
Oddometer: 1,070
neither am I
Yes, the lower mounting point has the bolt running through both brackets and the fork leg. I just happened to have a wide selection of allen head bolts (bmw parts) that perfectly fit the thread on the brackets and the holes in the fork legs.
In the outer bracket holes I have drilled out the threaded holes and the new middle hole so that the bolts are a perfect snug fit.
The lower bolt threads into the inner bracket. The middle bolt threads into a beefy nylock nut on the back of the upper mounting point on the fork leg, that I will also threadlock (and that sticks out no further towards the rotor than the inner bracket does). The upper bolt again threads into the inner bracket. There is no, absolutly NO, flex in the system (at leas at 'human induced' loads).
I hope that makes sense.
Excellent. That was pretty much my plan and I think what Sibbo was intending as well. The current two piece sleeve (shimmed with an extra couple of washers) I have on the moment is actually a perfect ID fit for the bolt, but is a little narrow OD for my liking (and is just there for mocking up anyway so I could acurately position the whole thing and drill the middle hole). The upper threaded holes in the brackets that this bolt goes through has a slightly raised area (as you can see) kind of like a cast in washer... what I was intending to do is turn up a sleeve that matches this OD. I could actually take it a bit wider to match the fork lug OD but I would then want to shim it or recess the face of the sleeve so that it also made contact and fitted perfectly over/around this raised area - otherwise there would be less point in making it wider than this area.
Does that makes sense?
About the straight and narrow path.
Yeah, This solution simply arose from working with parts and materials I had at hand. I didn't actually plan on doing it this way, I just realised that I with what I had I could get it done.
Out of my spare brembo caliper and bracket parts I also got a little magnetic sender thing thing that threads into that spare hole above the lower bracket hole. I believe this must have been for a speedo? So, if my stock speedo ever packs it in again, I shouldn't be too hard at all to get a digital speedo set up.
Cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 10-31-2011, 05:58 AM   #52
ontic OP
Oddometer: 1,070
An overdue update with not a lot to add, but a few questions if anyone is reading,
sorry for the ramble, its just my style,
Basically I am slowly building up the parts pile.
A growing pile in the US will probably be shipped over soon, and I am just about to put in the big motobins order.
About the motobins order-
I know I need to do the timing chain (realy noisy)- so I am getting the complete timing chain kit, and I figure I might as well grab new camshaft and crankshaft sprockets for while I am in there.
If I am changing the sprockets is there anything else I need?
Is it standard to re-use woodruff keys or is it just cheap?
About the motobins carb rebuild kits- are the original (slightly more expensive) nitrile kits recommended, or are the pattern 'hydrin' ones which are described as lasting longer recommended?
A new issue I just noticed is that when I shake my swingarm from the side there is a little bit of play in the swingarm- no it is not just play in the final drive (I have that too) the swingarm nuts are torqued up very tight- within the swing arm I am not sure where this play would be coming from..
New swing arm bearings? Will that solve it? Any thing else likely to be required?
I am getting the single seat that motobins sells, which is (in their words) a siebenrock seat. Interestingly motobins sells it a lot cheaper than siebenrock does (175 Pound verses 275 Euro), but siebenrock sells the luggage carrier cheaper than motobins...
Anyway, I'd prefer a black single seat, but motobins only has the red, and for a 100 quid cheaper not counting extra postage by using both suppliers I'll take the red one!
In the mean time I've bought an ac/dc tig welder with the plan to make my own panniers and rear racks and have been practising a lot on a lot of scrap aluminium and steel... more practice required.
Although I quite like the look of the stock G/SPD luggage carrier and rear rack it seems to me like there is probably a lot of doubled up unnecessary metal and complexity there- subframe, luggage carrier, rear rack, pannier frames bolting to rear rack- overly complicated IMO and for my intended use.
also while the luggage carrier looks particularly good to my eye- for space and weight distribution it seems to sit a little bit higher than it could or should? I don't like wasted space like that and I would prefer the load to sit as low as it can.
Anyway, I am going to make my own simple one piece luggage carrier/rear rack that sits as close as possible to the top of the rear fender (as in sitting low). I need to get the single seat in hand so that I can measure up and make everything fit properly. I am going to add a little to the subframe itself so that the rear of the pannier frames mounts to the subframe instead of to the rear rack.
This all sounds complicated- hopefully the final images will show simplicity and make sense!
I made a hell of a lot of work for myself shortening my exhaust,
its used to stick out quite far from the back of the fender, after a lot of cutting, tigging, grinding, cutting, tigging, etc, etc, now it sits in nice and neat (and finally airtight) and I am lot happier with it.
Because of the 'custom' headers, Y-piece and non-G/S staintune, and how they sit, I was able to bring in the stock left side pannier frame about 25mm- which is another 25mm wider that the left side pannier can be. Good news.
Cutting and re-welding the pannier frame lug made me realise what crappy potmetal these stock pannier frames are made from I am also going to be adding a wrap around rear bar to join both pannier frames together.
I have also started mocking up some subframe reinforcements
right side
I have had to make two subtle bends here- one to get proper clearance around the Ohlins spring and another to get around back under the pannier frame- a bit hard to see how the slight bends are sitting but it looks OK in the flesh.
left side is going to be a lot tricker and bendier. Up and around the exhaust and then back in.
at the moment I am just mocking these up with mild steel. I am assuming I should try to get some chrome molly steel for the final version? Really?
I've tried googling but does anyone know what steel our frames/subframes are made of? They are cro-mo aren't they?
Although I am happy to tackle a custom luggage carrier (and anything else that bolts on... and off) I don't think I am going to trust my tig welding for the actual subframe and will take it into a friends metal fab shop where he has a 'tig artist' working for him.
When the time comes the frame itself is going to be sent up to Paul Rooney for one of his frame reinforcement jobs.
And that's about it for the moment.
Motobins order is going off as soon as I can finalise it,
Cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 11-01-2011, 12:49 AM   #53
Sibbo
Oddometer: 355
Gawd you're a neat and tidy fella Ontic ! My pannier mounts on the ST are 12mm solid mild ,there not that much metal ,they're strong and I can weld them up at any farmers shed if I break them . That said , yours will be beautiful!
As to those swing arm and carb questions, they sound like a good reason to drop into Boxerworks .
Old 11-01-2011, 04:31 AM   #54
Beemerboff
Oddometer: 2,332
The play on the monolever could be because the bearing has been turning on the "adjusting " pin and has worn it.
Motoren Israel has slightly oversize pins which get a better grip of the bearing, and they are cheaper than OEM from Motobins too.
OEM pins are a loose fit in the bearing so if you are going to reinforce the frame it makes sense to tighten up the bearing fit too.
The frame tubes look and work like mild steel to me, you shouldn't really need much better.
My old man used to make a few pannier frames, and he used a thick wall pressure pipe, which was a bit better alloy then stock mild steel and worked/ bent easily too. But that was 50 years ago.
The stuff they currently use for petrol lines in servos is similar and is good gear too, but I dont know if it comes small enough for you.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 11-01-2011, 05:32 AM   #55
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,763
For the brake caliper mount couldn't you weld a tab to the inner mount on the same plane?
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley is online now   Reply With Quote
Old 11-01-2011, 04:21 PM   #56
igormortis
igormortis's Avatar
Oddometer: 1,374
Can’t believe I only just found this! You’re doing the old girl proud, and I loved your mini ride report with the rum and fishing.
PM’d you with a couple of questions.
igormortis is online now   Reply With Quote
Old 11-01-2011, 08:18 PM   #57
mungo57
mmm Beer
mungo57's Avatar
Oddometer: 15
pannier frame material
HI, I have been following your progress for a while now.In the past I have used hydralic seamless tube for various racks/frame rails etc.Comes in assorted diameters,bends and welds easily,strong, and is cheap as chips.All good things.I buy from a local hydralic shop.Would be obliged if you could PM me Paul Rooneys contact details.Ta
mungo57 is offline   Reply With Quote
Old 11-02-2011, 01:48 AM   #58
ontic OP
Oddometer: 1,070
Sibbo mate,
my tig welding is currently terrible! As a tig welder, I make an average brazer!
I didn't make those pannier frames, I've just narrowed the left one a little. Cut the tab off, shorten the tube and weld the tab back on. It sounded simple until the potmetal pannier frame tube just kept curling back and blowing through- I ended up having to drill through the tab, insert a steel dowel, weld it in, slide the tube over the dowel, weld it all up and call it good. It is good now, and it is strong, but it aint no 'stack of dimes'.
With my AC tig theoretically I could do that, but I have no idea how that might affect the temper of this cast alloy caliper bracket? Honestly, after seeing this system of bracket rellocation I am not too worried about my solution- I think it should work just fine,
Thanks mate, PM replied, hopefully there will be a lot more progress on this thread soon.
PM replied, thanks for the Hydraulic tube tip- I'll check it out.
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 11-02-2011, 01:56 AM   #59
ontic OP
Oddometer: 1,070
Thanks a lot, some good tips. I am going to go out to the shed now and see if I can get the swing arm off and actually understand what you are talking about (I've never pulled the swing arm off and don't know how it actually works inside there). I'll try to check the adjustment pin for wear.
Interesting to hear about the mild steel thing- I will try to make it into a friends metal fab workshop again tomorrow morning and see if I can source some better pipe/tube. He just gave me this last bit I am playing with currently and doesn't even know what it is. It has a seem. It bends well and quite easily and it welds very well. Assumed to be simple mild steel.
Maybe more later,
Cheers guys,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 11-02-2011, 02:55 AM   #60
Sibbo
Oddometer: 355
On the mild steel solid round versus tube thing .. the weight difference is an interesting calculation ...there's not much in it and as for braze ... if you have manganese bronze rods and tig , go for it .It's very strong and durable .Neat too and nice with tube if you go that way .( Old bicycle frames from the tip are a good tube source ).
Times are GMT -7.   It's 12:23 PM.
