Old 12-29-2011, 05:14 AM   #106
Sibbo
Oddometer: 355
Hi Ontic,
mate I reckon your welding is pretty damn good ... I NEED a gas shielded welder !Your bracing is great ...overwhelming but great .It is NOT going to break bend or deflect . It's built like a tank !
Pannier to diagonal braces ...... much as I like the clan aerodynamic lines of those tubes I'd weld some matching brackets on or at the very least make up a few clamps ...two sections of 12mm x 25mm x 30mm steel or aluminium clamped together and bored to suit the brace tubes but with a stud to connect to the pannier frame.You might be surprised how much you hang on them one day half way up a mountain in Nepal.
Seat frame for the ST ? Thanks for the offer but I've got the GS 100 seat, the one that someone cut in half ...not me! But I have a cover for it and as soon as I get my very slack act together I'll make up a base frame for it with an integral rack behind . it should come up OK then I have to get the dents out of the GS100 tank ..bugger ! Do you have any idea what Ross would charge for a GS100 tank ...daggy paint but no (serious) dents ? The local panel shop quoted me $500 to knock out the dents, they're big with some wrinkles higher than the surface then paint it . I could paint on myself without any trouble but these dents are beyond me .
and ..... an excellent job !
Sibbo is offline   Reply With Quote
Old 12-29-2011, 05:41 AM   #107
ontic OP
Oddometer: 1,070
Originally Posted by Sibbo View Post
Hi Ontic,
Thanks mate,
I just got back in from the shed and had dinner,
another update next post.
I think I understand what you are saying about the extra bracing between the pannier frame and the new subframe brace- I'll think a bit more about it but after todays work it may not be required.
You mentioned built like a tank... well..
Oh thats right- I remember that story about the half seat now. I couldn't remember if you were trying to find one or not.
Ross and the 100GS tank? It was quite a while ago that I was looking into it but I think the GS tank (average condition) IF he had one at the time was going to go for $4-500-ish.
If it were me I'd be inclined to just beat it out (and in) as best you can and then fair and paint it...
better get typing the next post so I can go to bed again,
cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 12-29-2011, 06:19 AM   #108
ontic OP
Oddometer: 1,070
Ok,
another long day in the shed (ahh, summer holidays)
It took me many hours to actually figure out how to proceed this morning.
I wanted to brace the rear of the pannier frames together and I wanted to make a rear luggage rack.
I played through many options of pannier frame bracing but in the desire to cut down on doubled up metal they kept leading me down the path of making the bracing as-one with the rear rack...
This is something I wanted to avoid. The stock G/S stuff anoyed me how if you wanted the single seat you needed the luggage carrier- if you wanted the pannier frames, then you needed the rear luggage rack.
I forked out $100 for the stock G/S pannier frames only to discover they were no good to me without the rear rack or heavy modification... I should have just built my own from scratch. Lesson learned.
anyway,
I googled-imaged around for inspiration... I scratched my head and dug through scrap metal.
Here is what I came up with.
That rear piece is a very beefy bit of 4.5mm stainless plate. It was a bear of a thing to bend and beat into shape.
We'll call that my rear bumper bar
Once I decided on it it began to make sense- it is just right for some unlucky bugger to grab and lift and push the bike (if the need ever arises).
With those new beefy pannier frame braces connecting to it the whole thing is rock solid. Seriously strong.
Making that took me ages.
Next was the rear rack and again I was pretty stumped. I was also very close to running out of hydraulic tube and this shortage began to decide things for me.
trying out a new (to me) technique for getting a nice bend (and the mess I have to put up with). Everything else is just bent in the woodwork vise with a hollow breaker bar but I didn't think I could get a nice 90 degree bend that way.
here is the rear rack, not finished yet
These vertical supports (my very last bits of hyrdraulic tube) aren't done yet- just sitting there to give an idea- there will probably be bends involved to get them to hug the fender a bit closer and impede less with the vision of the indicators.
I think I'll make an aluminium plate something like this, a little wider, that can be put here in solo mode,
or here in two-up mode
one more shot where you can kinda see how the rear rack attaches. Captured nuts again, inside the tube of the of the rear rack where it meets the pannier frame. A tab welded on the pannier frame for the bolt to go through. The bottom of the vertical supports will bolt to the stainless bumper. There are sharp edges, more welding to do, and all sorts of things to clean up, but that is the gist of things.
That's it for the moment.
Not sure how much I'll get done tomorrow as unfortunately I've actually got other things to do instead of locking myself in the shed.
Then I've got to get the R90 ready for its week away... it is kinda pulled apart a bit right now.
Cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic screwed with this post 12-29-2011 at 06:24 AM
Old 12-30-2011, 01:49 AM   #109
Sibbo
Oddometer: 355
What size is the tubing you're using Ontic? OD and thickness? You're getting some nice bends. I like those rear braces on the pannier frames, bracing one side against the other is the way to go .
On mine I've lifted the indicators up and above my Mermite panniers. It's necessary if you want to get the bottom of the panniers far enough off the ground, you may be building smaller panniers but a couple of card board mockups might be good at this stage . Something you can hang there and look at them .
More please!
Old 12-30-2011, 03:00 AM   #110
_cy_
Oddometer: 6,183
nice project...
_cy_ is online now   Reply With Quote
Old 12-30-2011, 05:51 AM   #111
ontic OP
Oddometer: 1,070
More please!
Most of the tubing is 15mm OD and 1.5mm wall thickness. Most of this stuff especially anything critical (subframe, seat frame, etc) is the ('cold drawn' I think) seamless hydraulic tube- which is really nice stuff- but there are also a few bits of the plain old seamed mild steel tube I was mocking up with thrown in. I've beat the hell out of some of this stuff with a big hammer and it is pretty good too- I can't get the seam to split- its just not as nice as the Hydraulic stuff.
Interestingly this dimension, 15mm OD, 1.5mm WT, is exactly the same as the stock pannier frame tubing- however that stuff is soft and weak as butter- I don't what steel they used for that but it seems like it was meant to be soft and bendy.
On top of this I've also used a couple of bits of thicker tubing from a /6 subframe I cut up- those rear pannier frame braces that connect to the stainless bumper are made of these and also that curve on the back of the seat frame where the seat lock is welded on.
And we are thinking along the same lines- it is coming up time for cardboard pannier mock-up. I am also thinking that I will need to move the indicators- we'll see how that goes but I'll probably plan to hang them off my rear luggage rack somehow.
One thing that has me a little confused is my tail light... it is a huge thing and doesn't match other images I see looking at stock G/S' (which seem to have much smaller tail lights). It is however a bmw Hella light and seems to perfectly fit. Maybe it was an Australian market thing?
Now, as far as 'more'- I didn't get anything done on the G/S today unfortunately- so as this is my only real thread you'll have to do with some substitue stuff.
I gave the R90 a quick oil and filter change, brake bleed, and finally made a permanent fix for my smoke escaping from the wires episode, then got things back together so it is ready to ride away for a week on Monday. I could really do with a new rear tire again but it looks like I'll just have to squeeze a bit more out of this one. There's tread on there still, you just have to lean over a bit to feel it It was getting a bit squirrely in the wet on the way back from the last ride..
Also,
out with this horrible thing
and in with this
Along with a new throttle tube and cam gear thing I got a new housing as well because a) they really weren't stupidly expensive and b) when Airbear replaced his throttle tube and cam gear the problem quickly returned as the housing itself was worn.
I can't wait to give this new throttle a good workout- that last one was seriously tainting my airhead experience and this one feels beautiful!
I've also got an oil change issue-
on my 90/6 this filter and my last filter have both looked like this when they came out is that normal?
On my last oil/filter change when I first saw this I thought that I had torqued that outside nut down too hard which was why the rubber O-ring thing was split like that, so I did it a bit lighter. It happened again,
This time I actually read the manual
It asks for 30 foot pounds! I don't think I was giving near to that much- this time I did....
btw, this is the system on the /6 and the non-hinged filter I have used this time.
I thought that maybe that one of those rubber O-ring things (not really proper O-rings) on the filter had gotten stuck in the filter housing and was causing the splittage- so I took this photo because I couldn't see anything in there and I hoped that the flash and uploading to the computer would reveal it to me...
still can't see but the photo is kinda cool.
Lastly I bit the bullet and gave the garage a good tidy and clean.
It may be small, it may be packed to overflowing, even after a 3 hour clean it may look messy, and due to the christmas day flood I did have to just wash that carpet and hang it on the line for a couple of days (it was starting to really smell).
It is not much but I love it this little place
Cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 12-30-2011, 06:29 AM   #112
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,392
Sorry couldn't resist. bereahorn made me do it. Looking good, Hans!! That sucker is built like a tank!!!! By the way, got in contact with HE and pulled the trigger on a 320mm and adapter. 216 euros. Not cheap, but fair.
Old 12-30-2011, 07:23 AM   #113
ontic OP
Oddometer: 1,070
Thanks Jenna
bereahorn loves his popcorn doesn't he
I'm glad HE worked out for you. Is there a pic online you could link to of the rotor you are getting?
216 euro may not be cheap... but it is a lot cheaper now than it used to be
And yeah, this does seem be being built kinda strong.
I hope I am not overdoing it. When it is all complete I'll have to weigh some of these components and hopefully someone with the stock set-up can get a few weights too (if it hasn't already been done somewhere... airhead wrangler maybe??)
My thoughts so far- compared to a stock GS, with single seat and luggage rack, rear rack and pannier frames: (assumption here is that the stock stuff is made of the same gauge tube as the pannier frames and as what I am using)
subframe, with the braces and two extra gussets obviously a little bit heavier.
Seat frame/luggage rack due to a significant amount of tubing reduction on mine compared to the stock one- mine should be a fair bit lighter- and I don't imagine a little alloy plate will tip the scales too much out of my favour.
Rear rack- not finished yet, but by looking at images of the stock ones I think mine will have a bit more tubing thus will come out a bit heavier (though of more benefit for 'tank building')
Pannier frames: a little bit heavier with the addition of the rear brace to the fender and to each other, the top rear braces that I cut off and re-made should be a pretty even trade-off.
Rear fender. Heavier obviously. Quite heavy in fact. I would have used something lighter than that gauge of stainless but it was all I had on hand that would work and I didn't want to use mild steel because in that spot I could see it just getting trashed and rusting. (the bumper will be polished- I could always remake that part out of some beefy aluminium plate... hmmm... time to check out my favourite metal scrap yard again).
Aside from the seat frame/luggage rack, in comparison to stock, the only thing that could be lighter with my set-up is that unlike the stock set-up, I can run the pannier frames without having to run the rear rack (probably how I will use it most of the time for lighter touring).
In that situation I think I might come out even or possibly in front, but for a true comparison with the rear rack on as well, I rekon I've gained a bit... but a hell of a lot more strength...
cheers,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 12-30-2011, 07:34 AM   #114
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Hey mate, this is worth a read: http://largiader.com/tech/filters/
Rapid Dog is offline   Reply With Quote
Old 12-30-2011, 09:27 AM   #115
_cy_
Oddometer: 6,183
now that's a solid rear sub frame/rack... nice job!!!
a really good looking tank. much nicer than a stock PD tank.
here's what's coming in a few days... also an 81 R80G/S with factory PD tank and rear sub frame.
bike was disassembled with every seal, bearing replaced including engine and transmission internals. Pistons balanced to 1/5 gram, etc. etc. it's like starting with a zero mile bike.
wish I could claim the work, but it was done by beemerguru. who's really got an eye for details.
his projects typically take about a year to complete.
Old 12-30-2011, 04:06 PM   #116
ontic OP
Oddometer: 1,070
Thanks, it was a good read for a general refresher but it hasn't really answered my worries.
I am guessing that I simply wasn't torquing the big single nut on the cover down hard enough- being torqued down to the spec the Clymer calls for (30 ft-lb) aught to squash those rubber o-rings a lot flatter... and then maybe with more pressure they cook kind of flat instead of splitting like mine have?
Thanks again,
I'm really enjoying this Tig welding- I'm pretty happy with everything so far, except after a little pondering I am am not yet entirely happy with the (unfinished) rear rack and how it mounts. I won't get it finished by the time I go for holiday so by the time I get back my hydraulic tube supplier will be open again- I might start from scratch again.
I need to figure out if I am going to use this massive tail light, or get something a little smaller, as I am kind of building the rear rack around it.
I suppose this light is at least more visible with the large lens.
Does anyone with a G/S have this same tail-light as me, all the images I've seen of G/S's appear to show much smaller lights.
And yeah thanks, I really like my tank, it was a lucky buy I think. It is freakin huge, but being alloy it is light and considering I don't actually have to fill up its (claimed) 45 liters all the time, it has the capability to carry its weight a bit lower I guess...
your G/S is a beauty. Congratulations.
Gotta run,
Cheers all,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 12-30-2011, 08:12 PM   #117
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
That's just depressing......
I am at this stage and I am a cheap bastard, so it will never look like yours.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-31-2011, 03:08 AM   #118
Sibbo
Oddometer: 355
Here's a quick pic of my indicators and tail light , as you say yours seem big but that's good. I made up a couple of little brackets to lift them up, it seems to work just fine.
and the obligatory pic of an ST remarkably improved by the addition of a GS100 tank .Ain't Tilly sweet ?
Old 01-01-2012, 06:05 AM   #119
ontic OP
Oddometer: 1,070
Great indicator alteration Sibbo,
I never thought of putting them vertically
Adios everyone
I'm off tomorrow morning for a week or so. The R90 is full of oats and ready for another good run- and I'm almost ready- still packing, feeling a bit disorganised, but it always seems to sort itself out..
I've got tomorrows route planned- a very nice run over some favourite roads and also some new (to me) roads I've been meaning to do, somewhere over 500km, with predicted temperatures somewhere over 40 degrees C (104+ for you F'rs), and a predicted very refreshing swim in the Hume Dam when I get there
Definitely a day for air-conditioning tomorrow- I'll be stopping regularly to fill up with water internally, and externally (dousing my gear in water).
Happy new year,
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 01-02-2012, 02:00 AM   #120
Sibbo
Oddometer: 355
Lucky (well organised ) bugger !
Times are GMT -7.   It's 04:28 AM.
