Old 05-25-2011, 09:02 AM   #1
g r a n t OP
g r a n t's Avatar
Oddometer: 640
1150GS tools for seating seals
Hi. I am using my iPhone today for this forum. Thus, I am finding it tricky to do a proper search.
I am about to delve into replacing the input shaft seal and main seals on my 1150Gs.
I have seen a few ideas for DIY tools for seating the seals. Does anyone have specific dimensions or illustrations of their tools to share?
Alternately, does anyone have the BMW tools they could sketch up and dimension? Thanks in advance!
g r a n t
g r a n t is offline   Reply With Quote
Old 05-25-2011, 10:20 AM   #2
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,585
Which input seal ?.
Which main seal, the rear crank seal ?
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 05-25-2011, 11:03 AM   #3
Pekkavee
Oddometer: 326
If you are talking about FD input seal you need a KD Tools 2467 socket or a similar socket to take the old seal out.
http://shop.ebay.com/i.html?_from=R4...All-Categories
Pekka
Pekkavee is offline   Reply With Quote
Old 05-25-2011, 12:17 PM   #4
g r a n t OP
g r a n t's Avatar
Oddometer: 640
Originally Posted by Steptoe View Post
Which input seal ?.
Hi.
Transmission Input Shaft seal (facing clutch)
The two main seals at the crank. I understand there is an outer and inner seal on my '00 GS.
Thanks.
g r a n t
Old 05-26-2011, 12:21 AM   #5
bone13
bone13's Avatar
Oddometer: 280
Originally Posted by g r a n t View Post
Hi.
Thanks.
Dont know about any "cheap do it yourself tool builds" on the rear mains but here's my experience:
I've used the BMW tool to do the job right the 2nd time after not using it the first time.
First time without bmw's tool I ending up finding out that inner seal didn't seat properly and was leaking oil again (which was why i was there the in the first place). I didn't get to discover this till after the test ride once it was all back together
Re did with the BMW tool: easier and did the job right.
That being said considering the work involved in having to do it over.... It's WELL worth the price of the tool.
The Trouble with Trouble is it usually starts with Fun
www.ridgerunneradventures.com
bone13 is offline   Reply With Quote
Old 05-26-2011, 02:55 AM   #6
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,585
l.
Coke can with the end cut off. The perfect diameter, slides inside the seal, insert into the engine, remove can.
Gearbox Input shaft seal just requires a long socket of the correct diameter
www.gsshop.biz
Old 05-26-2011, 05:23 AM   #7
PETDOC
User Awaiting Email Confirmation
Oddometer: 1,212
Steptoe,
Does the input shaft seal seat on something or do you need to mark the socket to achieve a specific depth when inserting the new seal?
PETDOC is offline   Reply With Quote
Old 05-26-2011, 10:09 AM   #8
Grok
Grok's Avatar
Oddometer: 3,567
Originally Posted by PETDOC View Post
Steptoe,
Transmission input shaft seal doesn't have a seat, so you need to install it square and to the right depth. When I do it, I measure the installation depth of the old seal and install the new one (with plastic pipe or equal) to the same depth. Your installation tool isn't critical, it just needs to allow you to tap the seal in without cocking it or scratching the shaft.
P.S. I put a little tape on the spline teeth to prevent nicking of the seal surface. I don't know how critical this is, but I do it anyway out of paranoia.
You can't go backward if you are facing the right direction
Grok is offline   Reply With Quote
Old 05-26-2011, 03:58 PM   #9
PETDOC
Oddometer: 1,212
Thanks Grok. Any tips on the easiest way to remove the old seal?
Old 05-26-2011, 07:20 PM   #10
Grok
Grok's Avatar
Oddometer: 3,567
I just used a small allen key held with vice grips (not the best idea). Anything you can get in there and hook the outer lip and pull will work. Just be very careful not to scratch the shaft or bugger the bore. You probably could modify the otherwise worthless tire plug installation tool to do the job
Old 05-26-2011, 07:26 PM   #11
PETDOC
Oddometer: 1,212
So the approach is from the outer rim versus the inner rim next to the shaft?
Old 05-26-2011, 07:30 PM   #12
Grok
Grok's Avatar
Oddometer: 3,567
No you install the tool next to the shaft and rotate it so it catches the outer rim before you pull. You need something smooth with a bend or hook on the end. Honestly you could probably just push on the seal (on one side) and it would rock enough to grab it. But it's probably better to use a hook.
Old 05-26-2011, 08:22 PM   #13
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,878
7 Piece Pick and Hook Set - $8.99
http://www.harborfreight.com/7-piece...set-93958.html
4 Piece Mini Pick and Hook Set - $2.99
http://www.harborfreight.com/4-piece...set-66836.html
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 05-27-2011, 07:32 AM   #14
PETDOC
Oddometer: 1,212
Poolside and Grok,
Thanks for the advise. One last question. I and a friend changed my clutch because of a slave cylinder failure at 31,000 miles (new clutch disc, diaphragm spring, housing cover, pressure plate, slave cylinder and felt ring on pushrod). At 42,000 miles it began slipping in 5th and 6th gears under hard acceleration. I've put another 3,000 miles on it and it hasn't gotten much worse, but I've purchased all the parts and am about to tear it apart to find out why this happened (no evidence of an oil or clutch fluid leak). I have the seals for the input shaft and pushrod.
My question is at 45,000 miles if when I disassemble it I find that we put too much grease on the input shaft splines and a new clutch disc is all that is needed would you still go ahead and replace the input shaft seal? And are there other seals I should replace besides the drive shaft seal where the slave cylinder sits?
Old 05-27-2011, 08:08 AM   #15
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,295
If your issue is a contaminated clutch disc, then no, you should be good with just replacing the disc itself.
Jim
Times are GMT -7.   It's 02:20 PM.
