Old 05-27-2011, 02:38 PM   #1
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
Thumb Group interest in DR650 Lamp Cluster Relocation mount
Folks I had this idea sparked by a fellow DR rider who had something similar to this, though implemented differently. I haven't seen something like this "on the shelf" but I don't know what all is out there so if there IS such a part, somebody speak up like quickly.
The idea here is that the stock DR650 instrument/light cluster [Neutral, Hi/Lo, Turn Indicator] is in a position that sometimes is occluded by cables or what have you... not exactly in your face. Though I hate clutter, I thought it would be unobtrusive to relocate it to the handlebar Clamp bolts... that is, 'suspend' it on a plate there, at reasonable cost.
I include a CAD mockup here by a fellow ADV inmate [bless him]. If this all works as drawn-up, one could mount this either on upper or lower 2 clamp bolts - take your pick. I will mount on the uppers "just because".
The proto is not finished yet so I have no riding time with the unit. That's crucial of course 'cause I'm wondering if it will jitter/vibe excessively, if stock aluminium is too reflective, if it needs any size tweaking, etc. Should have those answers in a week or two.
Meanwhile....
If you think you'd buy one of these at a delivered cost under $10, just chime in and say so. I'm just trying to judge interest to see if I should do a run of these.
Picture it:
From MotoAdventures
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 05-27-2011, 02:51 PM   #2
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,578
Interested!
John
http://rerax.net/index.html
jet123 is offline   Reply With Quote
Old 06-01-2011, 01:38 PM   #3
Old Nubbins
Old Nubbins's Avatar
Oddometer: 434
Finished prototype
Old Nubbins is offline   Reply With Quote
Old 06-14-2011, 09:43 AM   #4
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
Thumb Need Feedback
DR heads, need some input here.
A few questions on my mind, and a few pictures [I have more but don't want to overload, so if you want to see another angle or something, say so].
1. I'm thinking we only want to do this for standard DR triple-tree - i.e. the standard clamps, at least on bottom ... I guess there are all kinds of ways to do new/different top-clamps for the DR, but its important to note that this sits on top of the top clamp, so its not really made for a curved top clamp surface... the stockers are blessedly flat.
If you have another opine, pls let me know.
2. We're on the fence about whether to make this a 'full' so that it mounts on all four handlebar-clamp Bolts. There are good arguments for both, so I'm undecided. It looks "finished" in a 4-bolt pattern, but it also would seem like a bit of unnecessary metal, and would unnecessarily limit what one could do with the other 2 bolts, or the little bit of space in between if one wants something attached to the bar inbetween the clamps.
Again, pls speak your mind
3. I tried this in the upper bolt position and in the lower. To me, mounting on the upper two clamp bolts presents too many challenges: Crossbar size? Crossbar position? Handlebar position? Sitting or standing? Height of the pilot? Sitting forward, vs. laid back?. If we get into moving the position of the instrument Pod more forward so as to avoid handlebar/crossbar visibility issues, then you creep into field of vision for the speedo, again with all the sitting/size/etc issues. In the lower position, I have no issues.
Anything else you think of, post it. This is the time to do it.
Pictures:
From MotoAdventures
From MotoAdventures
From MotoAdventures
From MotoAdventures
Zapp
Old 06-14-2011, 09:55 AM   #5
IdahoRenegade
Oddometer: 1,491
I like the concept, and agree, the stock warning lights are hard to see. I miss the turn signal indicator now and then.
A couple of ideas. It looks like you have water jetted the plate. Given that, could you "sexy it up" a little"? No need for rectangular plate, the sides could be contoured to make it look more like a factory part. Also, could you perhaps offer 2 different versions, one extended (top and bottom of clamps, I'm thinking, but would have to play to evalutate) that had holes for attaching power outlets? I have Solidworks on my home 'puter, and could throw a model together. Do you have an inexpensive source for waterjetting?
IdahoRenegade is online now   Reply With Quote
Old 06-14-2011, 10:21 AM   #6
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Looks good and I am interested.
Can you add more functionality, even if it adds a bit to the price
My wish list...
1. I think it would look better if it sits on all four bolts.
2. Can you make a opening to fit a CG lighter adapter for some standard ones that are available in wally world or some auto parts store?
3. An opening for a analog voltmeter would be a bonus.
something like this
http://www.harborfreight.com/in-dash...ter-95779.html
or
http://www.harborfreight.com/2-inch-...uge-98479.html
or
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Retro-Line-Electric-Voltmeter-Sunpro_9030050-P_N3342E_P|GRP2032_____#fragment-1
Just a suggestion...not sure if the above Voltmeters work.
4. Make sure that the mount works with aftermarket bars and is visible.
DR650 - FZ1 - 200 EXC (plated - Not inspected yet)
fizzerfz1 is online now   Reply With Quote
Old 06-14-2011, 10:34 AM   #7
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
Great ideas!
you guys are a lot more creative than I.
we thought about the power outlets for just a min... the problem I have is, "which one"? there are so many out there, and strong opinions as to which is the better ADV part to use, and they have differing dimensions.
voltmeter a cool idea... didn't think of that [but then, I didn't think of a LOT of things ]
Zapp
Old 06-14-2011, 10:53 AM   #8
fizzerfz1
fizzerfz1's Avatar
Oddometer: 756
Well I want a integrated GPS mount too for the 60csx, but the choice of GPSs are too many, so kept the idea to myself.
The power outlets options are many and yes some would want the BMW type adapter. Soooo... you can try going with the most standard types... or wait for more suggestions.
I have used the Walmart $5 adapter screwed to my fairing, tapped into some unused switched wiring behind the headlight cowl for a couple of years without any issues.
Also if you still have space, you can try to fit in couple of universal on/off switches. Most of these switches are a few dollars and will be handy if some one wants to have a switched light or similar.
Like this
http://www.harborfreight.com/push-pu...tch-66306.html
or
http://www.harborfreight.com/push-bu...tch-66304.html
or
http://www.harborfreight.com/6-piece...set-95099.html
I am sure there must be some waterproof versions available somewhere...
Am I asking for too much now
Old 06-14-2011, 11:10 AM   #9
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,625
looks good.
however, if your riding in sunshine could be hard to make out lights.
the stock location is shaded
plugeye is offline   Reply With Quote
Old 06-14-2011, 11:28 AM   #10
Grizz Adams
Grizz Adams's Avatar
Oddometer: 1,925
Pictures:
From MotoAdventures
From MotoAdventures
From MotoAdventures
From MotoAdventures
I would be interested.
Something to think about as well is that some of us run a cross bar pad. This would make the current set up hard to see. If it were to move forward an inch or so this would make it easier to see. Just a thought.
I would not get too caught up in power options for cig outlets and such. Just give a little extra "meat" on the plate for room to drill your own hole. That way if you use switches or outlets you can decide on your own.
Great idea Zapp!
"I go where the voices in my head tell me to!"
KTM 990 ADV- "Annika"
Grizz Adams is online now   Reply With Quote
Old 06-14-2011, 11:36 AM   #11
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,983
Nice that the "N" for neutral is right side up no matter what the unit does.
I hate where the stock indicator sits. I almost always don't see the turn sig lite. High beam... never use it. Neutral, don't care. This is the only bike I have had in the last 30 years with a neutral light.
I think you have a good product here.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 06-14-2011, 11:49 AM   #12
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,578
+1 on leaving some extra space for customizing by the user
+1 on rather than having 2 specific mounting holes, can you cut out an elliptical shaped mounting hole on each side allowing the mount to slide up and down. Yes this adds complexity and cost, but allows more flexibility to the mounting options given differing bars/crossbars/pads
John
Old 06-14-2011, 12:13 PM   #13
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
yep.
thought of that one.
we seem to have nothing but unlimited sunbeams here anymore.... no rain, no cloud. Can't think of a way to defeat that one, offhand.
Originally Posted by plugeye View Post
looks good.
Zapp
Old 06-14-2011, 12:17 PM   #14
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
like the elliptical groove idea; that added to the flipability makes flexy
i'm sorta partial to the toggle-switch idea but not sure why.... i may be wrong in hoping they are closer to 'standard' in terms of the mounting scheme and dimensions, and I imagine them to be durable... or at least some of them. the bulletproofer the better
Zapp
Old 06-14-2011, 12:21 PM   #15
Zapp22 OP
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,683
Finish? [we have one input about finish] ?
anodized?
colorized?
I'm a tad concerned about a shiny, bright finish...
Zapp
Times are GMT -7.   It's 09:41 PM.
