Old 07-02-2004, 09:20 PM   #1
12bridn OP
I need throttle therapy
12bridn's Avatar
Oddometer: 4,603
Topcase for 12 bucks.
Many of you may have seen my request for accessories for my NX. I have a hard time finding anything used, and new stuff for a 15 YO bike can be pretty expensive. I wanted a topcase, and after looking at Givi and others, decided to make my own. I scrounged an old rolling case with a broken handle from work. It had two chintzy keylock latches and a 3 digit combo lock, good enough for my use.
12bridn is offline   Reply With Quote
Old 07-02-2004, 09:24 PM   #2
12bridn OP
12bridn's Avatar
Oddometer: 4,603
To mount the case, I took the top rack off the bike and used it as a template to drill four holes in the case. I put the rack back on the bike using only two of the six screws. I then used some longer allen-head screws and flat washers to mount the case through the existing holes for the rack, thus holding both pieces in place.
Old 07-02-2004, 09:27 PM   #3
12bridn OP
12bridn's Avatar
Oddometer: 4,603
I also used 8 eyebolts to act as bungee points. Six are on the lid, on the rear and sides, and two are in the front for a tent or roll. I used trim washers with teh o-rings to keep the look clean.
What I really like about the case is that it is watertight, with a rubber o-ring sandwiched between two aluminum trim pieces for a seal, as seen here:
Old 07-02-2004, 09:29 PM   #4
12bridn OP
12bridn's Avatar
Oddometer: 4,603
The front bungee points, for illustration. I put these two on the body of the case, so the lid could be opened without removing said roll or tent.
Yeah those are wheels. I left them on to act as frame sliders.
Old 07-02-2004, 09:31 PM   #5
12bridn OP
12bridn's Avatar
Oddometer: 4,603
Heres the whole package, doesn't look too bad if you ask me...
Old 07-02-2004, 09:33 PM   #6
12bridn OP
12bridn's Avatar
Oddometer: 4,603
I did the eyebolts like that so you could access whats in the case without removing whats on top. Exhibit A: Soft cooler.
Old 07-02-2004, 09:34 PM   #7
12bridn OP
12bridn's Avatar
Oddometer: 4,603
Exhibit B: Said soft cooler rotated 90 degrees. I hope to test this whole thing out over this holiday weekend, as it is supposed to rain for 3 days, and I need to check watertightness.
Old 07-02-2004, 10:14 PM   #8
Farnsrocket
Manos arribas!!!
Farnsrocket's Avatar
Oddometer: 3,983
Thumb
Very cool!
Crackhead retards keep me steadily employed.
I can't leave good enough alone.
Farnsrocket is offline   Reply With Quote
Old 07-03-2004, 02:14 AM   #9
Peachmaan
Boneless chicken
Peachmaan's Avatar
Oddometer: 429
Crafty...
The Old ...............expect everything
The middle aged ...question everything
The youth ............knows everything
"It has been said that "Life is a sexually tranmitted, fatal disease." You're born. Sometime later, you die." -Flash412
Peachmaan is offline   Reply With Quote
Old 07-03-2004, 12:32 PM   #10
chain
chain's Avatar
Oddometer: 4,772
chain is offline   Reply With Quote
Old 07-03-2004, 07:23 PM   #11
Superannuated
Oddometer: 279
Nice job.
Superannuated is offline   Reply With Quote
Times are GMT -7.   It's 05:17 AM.
