Old 06-05-2011, 11:36 PM   #31
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,796
Fun, I'm gonna enjoy watching this one! I just love to see things brought back to life, I have little doubt your the man to do it! Keep up the good work!
Old 06-06-2011, 09:24 AM   #32
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,643
I did the vinegar trick on my friends gas tank and it worked well.. got a ton of dirt/rust/junk out of the tank.. until I let it sit out and get surface rust all inside it. So, it's full of vinegar again on my workbench. This time, I'll fill it with gas when I'm done. Not bad for a couple dollars. I would love to see a before/after with your tank.
crazydrummerdude is offline   Reply With Quote
Old 06-07-2011, 07:28 PM   #33
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
↑ ↑ ↑ Now, this tank is dead to me, but one lucky inmate wants it for an art project.
So now I got to flush it before mailing. We'll see how this vinegar trick pan outs.
Here's a before pic after I drained most of the sludge.
IMG_2583
Once filled with distilled white vinegar it quickly turned into Chicken Tikka Masala.
IMG_2598
Ooops!
IMG_2596
Just a wee little leak...
IMG_2595
I'll report back in a fortnight on my findings.
Slash 5 Revive
elite-less is online now   Reply With Quote
Old 06-09-2011, 06:53 PM   #34
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
Continued teardown highlights and notable findings...
Right cylinder head came off with no fuss. Header and sparkplug threads were in healthy condition.
IMG_3844
However.... here's what lay below. As suspected, the cause of the frozen engine.. rusted rings.
IMG_3847
I then channeled a CDD thread for this doodad. Made a simple puller/pusher tool. This sneaked the barrel off curse word free.
IMG_3854
IMG_3860
Left cylinder head plopped off easy.
IMG_3849
I was kind'a bummed I didn't get to use my new tool on the left barrel. It slide off by hand.
IMG_3850
IMG_3867
Engine spun smooth and free. No abnormal in/out play on the con rods, or photo worthy wear on the components.
The speedo indicated a sun bleached 30k, and the PO said this was correct, but I won't use that as a baseline for any evaluation.
Bagged and tagged most engine components for scrupulous inspection later.
Slash 5 Revive
Old 06-10-2011, 06:35 AM   #35
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,149
It would be a good idea to pull the rods and look at the big-end rod bearings-- this will give a definitive assessment of the rod, and also the main, bearings.
And remove the oil pan and note the "swarf" collected there. And the oil pickup screen assy.
How do the lifters look? Pitted?
You're making good progress.
'73 R60/5 Toaster
Old 06-10-2011, 11:54 AM   #36
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
I agree as oil tends to become acidic when it has been sitting for years and will corrode the bearings over time.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-10-2011, 04:51 PM   #37
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
↑ ↑ ↑ Yup, I removed the con rods and will post pics of the oil pan findings.
I planned to get the engine fully balanced, so Iíll remove the cam and crank. Iíve been told not to monkey with the bottom end, since they are long lived, but Iím just uneasy about letting it be. It has languished for awhile.... however, the internals havenít shown any sign of trauma. I'll let it percolate as I labor on the rolling chassis.
Slash 5 Revive
Old 06-11-2011, 06:51 PM   #38
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
Dropped the pan and the screen was its usual grubby self.
IMG_2601
No magic glitter, metal nuggets or wayward e-rings in the bog.
IMG_2604
Inspected further with gloves, but it was just a thick, slick mud bath.
IMG_2608
Lifters still in serviceable condition.
IMG_2612
IMG_2614
Hard to take photos in the case, but here are the best I got.
IMG_2619
IMG_2620
Pulled the engine and cleaned the worst buildup from the case with a brass brush and mineral spirit. Upon further disassembly, I'll probably sodablast the case for a somewhat consistent finish.
IMG_2623
Slash 5 Revive
elite-less screwed with this post 06-11-2011 at 06:57 PM
Old 06-11-2011, 08:57 PM   #39
Bill Harris
Oddometer: 8,149
Not bad looking inside. It's rather like a Bog Mummy, looks really rough on the outside, but low mileage.
The speedo cable boot looked intact so that probably means that the tranny is dry inside.
'73 R60/5 Toaster
Old 06-12-2011, 08:51 PM   #40
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,643
..thought that looked familiar.
Old 06-16-2011, 07:04 PM   #41
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
Frame now neked and all parts ziploc'd in storage.
IMG_3990
Used the Makita master key to remove the fork lock.
IMG_3840
The sweet spot.
IMG_3842
When restoring my old r90 I used the dermel and chisel technique to remove the rusty racers. It worked, but what a pain. Bought this tool from cycleworks.net and it took longer to install than to wrench the racers free.
IMG_3959
IMG_3966
The centerstand threads were knackered after I removed the bolts. I was going to tap the hole larger, then I ran across these fix'em bits from wirewrkr. http://www.advrider.com/forums/showthread.php?t=397549
Drilled the hole larger, pressed in the new metal insert and installed the new bolt. Perfect and secure fit!
IMG_4266
The tang was ham-footed long ago, so made a new one for the centerstand. It'll get welded up after I lug this heap to my uncle's garage for further shenanigans.
IMG_4270
Slash 5 Revive
Old 06-16-2011, 07:29 PM   #42
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,927
Much nicer on the inside than the outside would indicate. I think you got a winner. Too bad about the tank but hey you have more, great match. You were made for each other.
Old 06-18-2011, 06:01 AM   #43
loukyairhead
loukyairhead's Avatar
Oddometer: 6
What a fun thread! I look forward to future installments!
"We're surrounded. That simplifies the problem."
- Lewis B. "Chesty" Puller, USMC
loukyairhead is offline   Reply With Quote
Old 06-24-2011, 08:35 PM   #44
elite-less OP
As above, so below
elite-less's Avatar
Oddometer: 548
Tank Flushing
Well... tank stewed for 2 weeks in distilled white vinegar. Let see how it flushed out.
Before...
IMG_2583
After...
IMG_2660
IMG_2657
IMG_2653
No, I didn't accidently upload a gold panning pic... that's the sediment that globbed out.
IMG_2663
Quite impressed... I wasn't expecting that much purging power from vinegar!
It'll probably flash rust this evening, but at least it's somewhat sanitary to mail. Should be another inmate's headache shortly.
Slash 5 Revive
Old 06-25-2011, 11:48 AM   #45
Boxer Metal
Mad Scientist
Oddometer: 3,521
That is amazing.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 07:16 PM.
