Old 06-01-2011, 04:29 AM   #1
Bruce Caldwell OP
Bruce Caldwell's Avatar
Oddometer: 1,016
Anybody Mounted A Pelican Top Box On F650GS ?
My 81 year old dad just picked up his new F650 twin yesterday & it's my job to figure out how to mount a Pelican on it. I believe we got the model # 1500. Anyway, I figured i'd have a sheet metal place near me cut me a 10 ga. aluminum plate to mount the box on similar to what I did years ago on my 1100GS although it's not as straight forward as mounting the plate on his bike as it was on my bike. If anyone has done something similar i'd like to see pics. thanks
late-braker
Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa
Bruce Caldwell is offline   Reply With Quote
Old 06-01-2011, 07:34 AM   #2
Captain Beardylocks
travelling beardo
Captain Beardylocks's Avatar
Oddometer: 7,510
easily removable, or semi-permanent? if you're going for something super simple, I think the backing plate with four bolts going down into the mounting points on the tail should work fine. you'd need spacers though
Livin' on the road, my friend, was gonna keep you free and clean...
Captain Beardylocks is offline   Reply With Quote
Old 06-01-2011, 08:20 AM   #3
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 602
Try Caribou Cases, they make a luggage rack and a very good mounting solution for pelicans. My wife got their 34l case for her 650 twin. The 34l is not a pelican, but all their other cases are. The 34l fits her helmet. Very robust, high quality stuff, and for a good price.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 06-01-2011, 09:04 AM   #4
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Here's what I did on my F800, mounted to a Touratech rack, though I'm betting that any kind of backing plate would do. You'd have to source the rear spacers somewhere.
Rubber washers sandwiched in between the fender washers keep it waterproof. Takes about 30 secs to unbolt for when I want to strap on a duffel, tent, etc. I got the lock from Roger at Caribou to match the locks on my Caribou 36L panniers. I didn't want a larger topbox. Too much weight back there is a bad idea.
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks screwed with this post 06-01-2011 at 09:11 AM
WoodWorks is offline   Reply With Quote
Old 06-01-2011, 09:25 AM   #5
Bruce Caldwell OP
Oddometer: 1,016
I was just going to go the semi permanent route because even though the top case on my dad's previous bike (1200GS) was quickly removable, he never took it off anyway. Although the Caribou system does look interesting. But he got the Pelican for around $90 & I got to looking around in my shop & i've got some alum. plate that will probably work & plenty of spacer material. He already spent a good chunk of change on some Givi side cases so we're trying to save some money.
late-braker
Old 06-01-2011, 10:58 AM   #6
Captain Beardylocks
travelling beardo
Oddometer: 7,510
I'd bust out some spacers on the lathe, cut the backing plate and keep it cheap. I think the bolts are M8's, but I'd check on that first. throw a blob of silicone around the holes in the pelican to keep stuff dry and call it a day
Old 06-01-2011, 11:01 AM   #7
Captain Beardylocks
travelling beardo
Oddometer: 7,510
yup, M8 bolts. somewhere around 55 - 60 mm depending on the length of the spacers
Old 06-01-2011, 11:07 AM   #8
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
What size pelican box is that? I've been wanting to do the same on my rack but havn't decided on a size quite yet.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 06-01-2011, 11:21 AM   #9
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
It's their iM2200. It used to the Hardigg iM2200, but they got bought out by Pelican. I keep all of my tire changing tools in there, as well as a small pump, chain lube, and a few other odds and ends. But it will hold all that AND a 1.75l bottle of Bombay Sapphire.
David
--Curly
Old 06-01-2011, 04:08 PM   #10
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Nice. I'm looking at the 1200 or IM2050. It's a bit smaller but I am thinking it would fit the tools for a trip, pump and a tombstone of gentleman jack.
Old 06-02-2011, 04:00 AM   #11
JRWooden
Oddometer: 4,313
I have the Pelican 1500 as my top case as well.
I mounted it in a similar fashion to Woodworks (using the Touratech plate) except that I glued the washers to the inside bottom-inside of the Pelican case (so I wouldn't have extra loose parts) and used allen head screws to mount it. I put these "knobs" on the top of the cap screws to make the case removable:
http://www.amazon.com/Shear-Loc-SLK-.../dp/B002DGEHNA
On the bottom side I found that some "caged nuts" like these:
http://www.amazon.com/StarTech-com-P...ies/B00009XT0G
would snap into the slots of the Touratech plate.
This makes the thing pretty easy to remove.
I sometimes wish I had gone with the 1550 case, but the 1500 works OK most of the time. If I fold carefully, I can get my jacket in the case, along with a bit of mish-mash of maps and etc.
I mounted the case such that the back of the case was even with the back of the Touratech plate. Doing so means that the case covers a few inches of the back of the seat meaning I could not ride two-up with the case installed. I rarely ride two-up anyway, and don't like the looks of the case sticking way out the back when it is not necessary.
I also found that if a strap a small stuff bag to the front of the Pelican with soft stuff in it (jacket, extra clothes, ...) that it is just about perfect as a modest backrest ;-)
Old 06-02-2011, 08:48 AM   #12
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I've found that the Wolfman double-ended expedition duffel serves that purpose nicely. It's only 9" in diameter, and the double-ended openings make it easy to access without having to unstrap it.
David
--Curly
Old 06-02-2011, 10:57 AM   #13
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Got a pick of it on the back of your bike? I've been looking at the different pelican options and can't decide between a few. The iM2200 looks kind of big for the rack I have. Here are the options I am looking at (biggest to smallest). Ideal based on my estimated measurements would be 13 x 10.5 x 5.5
Narrowed it down to one of these. Leaning toward the IM 2100 or 1400 at the moment.
iM2200 Pelican Storm Case Specifications
Exterior Dimensions 16.20" x 12.70" x 6.60"
Interior Dimensions 15.00" x 10.50" x 6.00" = 945
iM2100 Pelican Storm Case Specifications
Exterior Dimensions14.20" x 11.40" x 6.50"
Interior Dimensions13.00" x 9.20" x 6.00" = 717.6
Pelican 1400 Case Specifications
Exterior Dimensions 13.37" x 11.62" x 6.00"
Interior Dimensions 11.81" x 8.87" x 5.18" = 542.6
iM2050 Pelican Storm Case Specifications
Exterior Dimensions 11.80" x 9.80" x 4.70"
Interior Dimensions 9.50" x 7.50" x 4.25" = 302.8 (sounds small!)
Gangplank screwed with this post 06-02-2011 at 12:02 PM
Old 06-02-2011, 05:30 PM   #14
JRWooden
Oddometer: 4,313
I'll snap some tomorrow when I get home from work... too dark now for me to get any good ones.
I do not think the 1500 looks "out of place" on the bike.
There is a local distributor close-by, one of these days if I get time I plan to ride by and borrow the 1550 to just set on the bike to see what it looks like...
Pics tomorrow!
Old 06-03-2011, 01:41 AM   #15
Bruce Caldwell OP
Oddometer: 1,016
Pics tomorrow!
I don't think it looks out of place either. I made my own mounting plate but need to source some longer bolts sometime later today. I was able to mount the plate temporarily with two bolts just to see what it all looked like.
late-braker
Times are GMT -7.   It's 02:28 AM.
