Old 05-04-2007, 09:52 PM   #151
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
You might want to do a little research on this, try these threads
http://www.advrider.com/forums/showt...ry+chain+guide
and
and
Be sure and look for Poolsides posts
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 05-04-2007, 10:02 PM   #152
markjenn
Oddometer: 10,473
Originally Posted by pro-bassoonist
It does seem like the two sides should be done at once, especially since the left-side change isn't being done for wear or breakage as much as redesign...wouldn't we do the right side as well just for even wear?
The two sides use different tensioners so you can't fit the left-side parts to the right. AFAIK, there are no oilhead retrofit options for the right side. I'm not sure whether that's because the right-side tensioner is unchanged from the oilhead to the hexhead, or because the right-side hexhead tensioner won't fit an oilhead. I supposed you could replace the right-side parts with new parts of the old design, but I doubt it would do a thing.
I wouldn't worry about "even wear" - this isn't going to effect your throttle-body sync or anything. We're talking about a noise issue mainly.
- Mark
Old 05-04-2007, 10:35 PM   #153
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
There is fundamental mechanical difference between the left and right side
cam chain dampners. If you read the threads I listed you'll see how they differ.
JJ
WingMakers.com
Old 05-13-2007, 10:05 AM   #154
Farnsrocket
Manos arribas!!!
Farnsrocket's Avatar
Oddometer: 3,983
Just ordered my parts from Chicago BMW.....$61.07 shipped!
Crackhead retards keep me steadily employed.
I can't leave good enough alone.
Farnsrocket is offline   Reply With Quote
Old 05-27-2007, 11:31 AM   #155
geckosan
Lost but okay with it!
geckosan's Avatar
Oddometer: 395
30 minutes later- and I'm eating my cake- and what a piece it is!! I ujust took off the throttle body and off it came- no spring problems-came out on it's own accord, and a magnet to remove the one inside the cylinder. I do suggest having the new o-ring though. Sounds great now to boot!!
Thanks for the photo-tutorial- I love this stuff!!
01 1150 GS
01 650 GS Dakar
04 KTM 950 Adventure
geckosan is offline   Reply With Quote
Old 05-29-2007, 02:27 PM   #156
wrxtance
wrxtance's Avatar
Oddometer: 130
Bluhduh
So after a couple thousand miles, my noise is back! There is no knocking noise at start-up still but at around 2800 rpm, it starts knocking. It goes away at about 3000, comes back at about 3200, then quiets down a bit as I rev higher. The "old" clacking noise was more of a soft "thug" now its a much sharper "clack". Maybe its time to get that 5000 mile old 10-40 BMW oil outta my engine? Any other ideas? Valves?
wrxtance is offline   Reply With Quote
Old 05-29-2007, 07:57 PM   #157
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
Your noise may be either the butterfly shafts in your TB's or perhaps your rocker arm end play. The HoW has a write up that covers the rocker end play adjustment. Dealing with the butterfly shaft is either a replace it, live with it, or try and re-bush the plain bearings in the TB's.
JJ
WingMakers.com
Old 05-29-2007, 09:53 PM   #158
pro-bassoonist
Oddometer: 145
Question Torque on the new tensioner?
I think I read someplace that the torque on the new tensioner needs to be 32Nm. I just got these parts in and will be putting the new tensioner in place shortly...how do I get a torque wrench on this? I see places in the thread where one isn't used - did anyone get a wrench on this without removing the front suspension swingarm?
TIA.
pro-bassoonist is offline   Reply With Quote
Old 05-29-2007, 10:13 PM   #159
markjenn
Oddometer: 10,473
I just torqued it by feel. I doubt exact torque hear is terribly critical - you're basically just sealing up the opening.
- Mark
Old 05-31-2007, 07:00 AM   #160
pro-bassoonist
Oddometer: 145
Talking Got it
- Mark
Did it last night. It turned an already quiet engine (relatively anyway) into an almost silent engine. Even after hanging out all night on its sidestand - no clackety-clack for three to five seconds on startup.
Thanks for all the help everyone!
Old 05-31-2007, 12:15 PM   #161
Minnesota
Conform or be cast out
Minnesota's Avatar
Oddometer: 4,040
I just ordered the parts from Chicago BMW as well. $55.38 plus 5 bucks for shipping, including the TB O-ring. The guy knew exactly what I wanted when I called and even suggested adding the o-ring. Knowledgeable, I like that.
This is after I had called the dealer in Minneapolis and they wanted $77.00 for the parts, without the o-ring, picked up at the store! I did order some crush washers, a couple key blanks and some parts for the BMW system cases. They were consistantly 15-20% higher than Max BMW's fiche. Somebody is making some money there.
I think from now on, when I need parts for the bike, Chicago BMW is the place!
To learn who rules over you, simply find out who you are not allowed to criticize. -Voltaire
Minnesota is online now   Reply With Quote
Old 06-03-2007, 06:53 PM   #162
Farnsrocket
Manos arribas!!!
Oddometer: 3,983
Still waiting for my parts!
Old 06-04-2007, 10:56 AM   #163
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,349
welcome to Chicago BMW....
Tbone is offline   Reply With Quote
Old 06-04-2007, 11:13 AM   #164
AnnieGS
Namastι, bitches!
Oddometer: 29,551
I'll bet you a final drive that they're sitting in a huge pile with all the other 'net-ordered parts from the week of the 13th. Call and raise a polite stink and they should arrive on your doorstep a little bit faster.
AnnieGS is offline   Reply With Quote
Old 06-06-2007, 01:50 PM   #165
Farnsrocket
Manos arribas!!!
Oddometer: 3,983
What do ya know, I got em today!!!! Thanks for the hex Annie!!!
Times are GMT -7.   It's 02:47 AM.
