Old 02-21-2005, 08:55 AM   #16
eap
El Adventurero Solitario
eap's Avatar
Oddometer: 3,265
Originally Posted by johnjen
we're work'n on fixing up the Hall of Wisdom so we can get reports in there faster...
and this is a choice morsel indeed.
JJ
BTW - where is the Hall of Wisdome nowadays. I've wanted to pull up the OVAD for a buddy but don't see it anywhere...
eap '14 R1200GS-LC Thunder Grey
Chesapeake Bay Watershed, Surf Your Watershed
Support Mammograms
"Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm
eap is online now   Reply With Quote
Old 02-21-2005, 01:33 PM   #17
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,066
That's a good question...
Oh Baldy, paging Mr. Baldy...
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 02-21-2005, 02:03 PM   #18
Team Dennis
Certified Troublemaker
Team Dennis's Avatar
Oddometer: 4,538
Moved to the bottom of the page next to the donate button.
Team Dennis is offline   Reply With Quote
Old 02-21-2005, 04:18 PM   #19
eap
eap's Avatar
Oddometer: 3,265
Oh there it is .Down at the frign bottom of the page, GDMHK always moving things around thanks,
Support Mammograms
Old 02-21-2005, 08:28 PM   #20
configurationspace
delooper
configurationspace's Avatar
Oddometer: 8,920
Woohoo! Poolside!
configurationspace is offline   Reply With Quote
Old 02-22-2005, 01:50 AM   #21
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Ok, I just added the last set of pictures to the original post. Have at it.
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 02-22-2005, 09:39 AM   #22
kixtand
kixtand's Avatar
Oddometer: 2,175
Thumb Excellent
Just when you thought things could not get any better, they do. Top notch post.
Kix
kixtand is offline   Reply With Quote
Old 02-22-2005, 12:59 PM   #23
Rad
Just me
Rad's Avatar
Oddometer: 12,176
Wow! Just saw yur second set of Pics and directions
I love the "Alley oop"
Who can do a pdf of this so we can get it in da Hall?
Rad is offline   Reply With Quote
Old 02-22-2005, 01:10 PM   #24
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,691
Done. Where would you like me to send it, Rad? It's about 1.9MB. Send me a PM and I'll mail it to ya.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 02-22-2005, 01:10 PM   #25
slowbike smallpenis
Tester of Tooheys Old
slowbike smallpenis's Avatar
Oddometer: 19,717
Thanks Jim, any chance of dropping down Jervis Bay way and running thru it again?
Illusion is the first of all pleasures
slowbike smallpenis is offline   Reply With Quote
Old 02-22-2005, 02:48 PM   #26
Rad
Just me
Rad's Avatar
Oddometer: 12,176
I will pm ya
Old 02-22-2005, 03:27 PM   #27
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,532
Jim, thanks for the photos.
Isn't that new tensioner about $150 each?
Is there a torque value for tightening the tensioner?
Is there one on the other side on the bottom, easy to get to?
Both need to be replaced?
Do you think all GS 1150s need the new tensioner? Is it one of those parts that will have a problem sooner or later?
Just curious, I followed some earlier posts about the tensioner fixing noisey engines.
Is this normal goop on a BMW throttle body?
scooteraug02 is offline   Reply With Quote
Old 02-22-2005, 04:20 PM   #28
configurationspace
delooper
Oddometer: 8,920
I believe this is only for the left-side tensioner. Nobody seems to have troubles with the right-side one.
In the BMW service manual under Engine -> Timing chain -> Chain tensioner they have 32Nm listed. They also mention you should replace the seal every time you remove the tensioner. I can't seem to get a complete P/N for the gasket/seal. It's ?? ?? ? 963 308. I don't know what the first 5 digits are, the MAX BMW fiche doesn't want to give them to me.
configurationspace screwed with this post 02-22-2005 at 04:34 PM
Old 02-22-2005, 04:34 PM   #29
philschl
Oddometer: 222
am also keen to learn about the ins and outs of TB goop.
am starting a new thread on the topic...
philschl screwed with this post 02-22-2005 at 05:28 PM
philschl is offline   Reply With Quote
Old 02-22-2005, 05:13 PM   #30
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,691
PDF now available
IMHO.
Times are GMT -7.   It's 06:52 PM.
