Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 06-03-2011, 04:04 PM   #1
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
Zumo 550 Maps Data on SD Card?
Can I store maps, tracks, waypoints on my sd card so that they are accessible to the Zumo?
I want to add some maps but the internal drive is full...
Some say I'm apathetic, but I don't care. - Randy
'13 KLR 650 For Sale!
'07 KLX250s
hppyfngy is offline   Reply With Quote
Old 06-03-2011, 04:38 PM   #2
Twohondas
Twohondas's Avatar
Oddometer: 1,204
Yes you can put all of CN on the SD card or you can put overflow on the card. Sometimes I run Topo on the card as well.
Twohondas is offline   Reply With Quote
Old 06-03-2011, 05:16 PM   #3
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
Thanks but can you tell me how? When I go to send data from Mapsource, it doesn't give me an option of where to send it, except the device.
And running Topo from the card... is it slower or something? How does that work?
(what's the CN?)
'07 KLX250s
Old 06-03-2011, 05:57 PM   #4
Countdown
Oddometer: 5,696
I was under the impression that like the hand helds, all maps go on the data card but unlike hand helds you can add more maps without erasing what is there. I just downloaded Roads & Rec into my Nuvi.
Do you mean your Track Log is full?
Other data goes in internal memory.
If you send Zumo "Saved Tracks", it will ask you if you want to convert them to Routes.
Jerry Counts
Countdown screwed with this post 06-03-2011 at 06:19 PM
Countdown is offline   Reply With Quote
Old 06-03-2011, 06:05 PM   #5
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,758
I assume the Zumo is like my Nuvi 500 - preloaded maps are in the internal memory, but you can add additional ones to the card.
The memory card should show up as a choice when you are sending maps from Mapsource.
Now you should be able to put tracks, routes, and waypoints in a .gpx file on the card and then import them as needed. I don't have a Zumo though.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 06-03-2011, 10:36 PM   #6
griffo1962
griffo1962's Avatar
Oddometer: 1,555
the SD card has to have a folder called Garmin on it. save the maps there.
griffo1962 is offline   Reply With Quote
Old 06-04-2011, 05:00 AM   #7
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
Oh shit... is it that simple?...
wow. thank you
'07 KLX250s
Old 06-04-2011, 09:57 AM   #8
fluff34567
fluff34567's Avatar
Oddometer: 1,092
when you click "send to device" you will have the option to send it to any drive that is detected by the computer.
you can have 50 usb sticks/sd cards etc attached and you can send it it to any of them...... if you wish.
there is no need to have a garmin folder already existing as mapsource will make it.
fluff34567 is offline   Reply With Quote
Old 06-04-2011, 11:21 AM   #9
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
fluff is right I just tried it with a usb stick.
I guess my problem was I just never used the drop down menu to see the sd card...
The whole thing is a simple case of me not applying myself. I'm so ashamed...
'07 KLX250s
Old 06-04-2011, 11:33 AM   #10
Twohondas
Twohondas's Avatar
Oddometer: 1,204
No matter how much you clean the Zumo 550, it will not hold a complete CN mapset anymore so you have two choices basically for the NA maps.
1. Load the entire mapset update on to a SD card. THis is the same procedure you use to load TOPOS to a SD card for instance - that is once the Maps are installed on the PC.
2. Load 49 states to the Zumo drive (using the Garmin website app) and the overflow (Canada, AK and Mexico) to the SD Card.
Note I used option #2 for the last 2012 update. THe only issue is that TOPO maps have the same file name when you send them from Mapsource so you need another SD card for Topos unless you want to overwrite the Canada and AK mapset. I may try to put the TOPO on the Zumo itself and the whole CN on the SD card... but not sure that will work yet.
Frankly, I do not use the Topos much anyway.
Zumoforums.com has many threads on this issue.
Old 06-08-2011, 02:26 PM   #11
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
TwoHondas, my brain started to hurt while reading that...
So, I won't be able to get my new CN update I just ordered onto the Zumo?
I'll have to move maps to the card regardless?
'07 KLX250s
Old 06-08-2011, 03:10 PM   #12
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,858
Yeah I found out this the hard way, got the offer to download and did not put them on a drive trying to sort out the Zumo storage. (and Garmin would not admit it would not fit). Lost my access to the maps after a period of time and now have ancient ones on my 550... argh!
k
"And if we have food and covering, with these we shall be content."
elmontanero is online now   Reply With Quote
Old 06-10-2011, 11:00 AM   #13
Twohondas
Twohondas's Avatar
Oddometer: 1,204
That is the bottom line. Can not get the whole mapset update on the Zumo 550 Drive anymore. I still have 49 states from 2012 update on the Zumo drive and the remainder of NA on the SD card.
Zumoforums.com has lots of threads on this but ..... no room at the inn for the entire CN NA on the Zumo 550 anymore. But the procedure described above works fine.
Once you get the hang of it ...not too hard. But it does take a while. Also you should check and recalculate old routes (made on old mapsets) from the new 2012 mapdata.
Old 06-13-2011, 12:10 PM   #14
wonderings
Oddometer: 950
I found the easiest solution was leave the Zumo 550 alone, I didn't erase anything, it still has the 2009 maps on it, but I deselect it under maps. I load the newest maps completely onto a 4 gig SD card. I don't notice any speed issues, and it fits no problem. The file is about 2.2 gigs I believe.
“If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse
and you say that you are neutral, the mouse will not appreciate your
neutrality.” Bishop Desmond Tutu
2010 GSA
wonderings is offline   Reply With Quote
Old 06-13-2011, 02:00 PM   #15
hppyfngy OP
not dead yet
hppyfngy's Avatar
Oddometer: 4,143
I don't think I can do that. I have a bunch of routes I want to load also and will need a lot of the SD card for that. And anyway, I don't know why you would want to keep old data...
I have my update. Just trying to figure out where I want everything to live on the unit / vs the card...still confused
'07 KLX250s
Times are GMT -7.   It's 02:23 PM.
