Old 09-23-2011, 08:41 PM   #16
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,574
With 9 posts my guess is she doesn't spend a lot of time here.
soyanarchisto is offline   Reply With Quote
Old 09-24-2011, 09:34 PM   #17
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
I have put a plug on the speaker wires after removing them so you can plug them back in to the new jack.
I have done it for those who asked. I will do it at the same time as the mod for an additional $5.
It's not too hard since I desolder the speaker wires and remove them the ends are bare and tinned so I just solder them onto a plug, remove the old strain relief, and put the new one on.
Regards...
Sent from my EVO using Tapatalk
JetGrl is online now   Reply With Quote
Old 10-02-2011, 11:34 PM   #18
intr1gue
intr1gue's Avatar
Oddometer: 211
Excellent!
can you PM me your contact info so I can get mine to you as soon as they arrive? I'll be picking up a pair of G4's for myself and my wife and we'll want this mod done ASAP. Thanks!
--Ranjan
Regards...
Ranjan
One little Indian
Seattle, WA
intr1gue is offline   Reply With Quote
Old 10-18-2011, 04:43 PM   #19
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
PM Sent
PM Sent...
Old 03-13-2012, 08:12 AM   #20
Mad Kaw
purveyor of fine BS
Mad Kaw's Avatar
Oddometer: 42
Thanks Eilieen! Very cool mod and a professional job to boot!
The Republic was healthy until Congress discovered it could tax the producers then leverage those monies to buy the votes of the freeloading zombies.
Mad Kaw is offline   Reply With Quote
Old 04-17-2012, 05:12 PM   #21
ttfrank
Oddometer: 74
PM Sent
ttfrank is offline   Reply With Quote
Old 04-20-2012, 03:28 PM   #22
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,399
Awesome mod! Thanks for the nice work and quick turn around. I'm a happy customer as is my buddy Charles.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 04-21-2012, 10:02 AM   #23
avc8130
Oddometer: 1,570
Ever done a Q2? I have a multiset that could really use headphone jacks.
ac
avc8130 is offline   Reply With Quote
Old 05-05-2012, 07:45 PM   #24
ttfrank
Oddometer: 74
spotless
I just received mine. This mod is a must for this equipment. My ear are protected and the sound quality has improved exponentially.
Now, I must say Eileen,s jobs is top quality. Spotless finish and she sent it back the same day..
THANK YOU EILEEN!!!
Old 05-09-2012, 08:11 PM   #25
Golevi
Golevi's Avatar
Oddometer: 221
I've done this mod now for several of the inmates here. A couple of them have posted back to the original mod posting here: http://www.advrider.com/forums/showp...6&postcount=53
I have had questions about the ear buds and setup that I use. I tried using ear buds last year once and gave up on it because the buds I had pressed on the padding inside the helmet and irritated my ears. After I did this mod I got a new set of ear buds from cyclebots.com, the S-Plug ear buds. They are very soft and pliable and fit inside the ear so they don't rub or irritate your ears. I have worn them for 16 hours straight with total comfort. I also have a friend that wears them all the time, he has run in 2 Iron Butt Rallies (11 days, 11,000 miles).
The plugup.com website has a volume control extension cable that can be used as well to take care of the increase in volume when using ear buds. http://www.plugup.com/volume_control..._p/ad%20vc.htm
If you purchase the S-Plug ear buds in the 22" length (short) and use this extension to cut down the volume you can then use the G4 normally. The S-Plugs can also be found on the same website: http://www.plugup.com/the_S_plug_ear...22-3.5-4.5.htm
Eileen
Something I discovered about using the ear buds in a helmet is that they would begin hurting my ears after a while in the saddle, mostly my lower ear lobe where the wires come out; it seemed that the padding would push it into my ear lobe... Some worse than others... Now, I put the ear buds in upside down with the wire pointing up and it stays within my ear instead of pressing against my ear lobe... There is a little sliding tie (I use the 20 dollar Sony ones from Wal-Mart) that takes up slack on the wires that I slide close to the top of my head, put my helmet on then plug it into the G-4 and it is COMPLETELY pain free! I have worn them this way for up to 8 hours, and I do not even know they are there...
Just my experience...
"I pick, therefore I grin."
2008 BMW R 1200 GS Adventure
Golevi is offline   Reply With Quote
Old 05-12-2012, 06:33 AM   #26
Britome
Get Free
Oddometer: 1,154
Are you able to do your mod on the new G9?
Britome is offline   Reply With Quote
Old 05-12-2012, 02:10 PM   #27
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
I'm working on one now. It does not have room for a jack inside the clamp but I'm seeing if I can figure a way to reliably solder on an in line jack that can be velcroed to the helmet base. The varnished wires have always been a problem.
Sent from my Samsung Galaxy II using Tapatalk
Old 05-12-2012, 03:02 PM   #28
Britome
Get Free
Oddometer: 1,154
Ok. Thx. Please let me know when and if you figure it out.
Old 05-22-2012, 09:21 AM   #29
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
I have been successful in installing an inline jack on a short cable to the G9 base so earbuds may be used.
I will install the inline jack and a plug onto your speakers for $30 plus $5 retutn postage.
Send an email to Eileen.Kelleher@gmail.com for contact info to send your unit to me.
Old 06-13-2012, 07:50 PM   #30
aslaen
Oddometer: 1
Hello, I sent an email to you, but have not heard back. Are you still doing the inline jack conversion for the g9?
Thanks...
aslaen is offline   Reply With Quote
Times are GMT -7.   It's 02:22 AM.
