Old 06-14-2012, 04:00 AM   #31
Britome
Get Free
Oddometer: 1,152
Does that mean you can do speakers or earbuds, Eileen. (have both?)
Britome is offline   Reply With Quote
Old 06-14-2012, 06:47 AM   #32
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
Yes, you can plug the speakers into the jack when you wish to use them.
Eileen
Sent from my Samsung Galaxy II using Tapatalk
JetGrl is offline   Reply With Quote
Old 06-14-2012, 02:43 PM   #33
GaelicDog
Lesser of Two Weasels
GaelicDog's Avatar
Oddometer: 7,322
I saw where you were asked about the Q2 Pro series.
Can they be done successfully?
[SIZE=1][SIZE=2][SIZE=1][COLOR=white][SIZE=2][CENTER][SIZE=1][B]Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.[/B][/SIZE][/CENTER]
[/SIZE][/COLOR][/SIZE][/SIZE][/SIZE]
GaelicDog is offline   Reply With Quote
Old 06-14-2012, 03:38 PM   #34
stuartdivebum
assume first
stuartdivebum's Avatar
Oddometer: 91
Scala G4
Got mine back today, very qwik turnaround and looks and sounds great (Thanks for fixing my right side speaker) A very decent person to deal with
Thanks again Mz E!!!
Living proof that medical science has taken natural selection out of the equation.
2002 ZRX1200R
2001 ST1100 TCS ABS
stuartdivebum is offline   Reply With Quote
Old 06-14-2012, 04:33 PM   #35
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
I don't work om any Q2 units anymore. Too many different clamps. I only wotk on G4 and G9 units. Like the G9 units, there is no room in the clamp housing for a jack so it has to be an inline jack.
I'll post a picture of the next G9 I do so you guys can see it.
Eileen
Old 06-17-2012, 11:14 AM   #36
MotoLara
ADV rider wannabe
MotoLara's Avatar
Oddometer: 812
G9 mod
PM sent
[COLOR=White][COLOR=White][SIZE=3][URL="http://www.MotoLara.com"]www.MotoLara.com[/URL][/SIZE]
[URL="http://www.advrider.com/forums/showthread.php?t=620023"]2010 Canada to Argentina[/URL] |[URL="http://s826.photobucket.com/albums/zz182/betitolara/Central_America/"]
[/URL][URL="http://advrider.com/forums/showthread.php?t=810126"]2012 Bella Coola and Beyond[/URL]
[URL="http://advrider.com/forums/showthread.php?p=19392551#post19392551"]2012 WABDR[/URL]
[URL="http://www.advrider.com/forums/showthread.php?t=910523"]2013 Fernie and Back[/URL][/COLOR]
[/COLOR]
MotoLara is offline   Reply With Quote
Old 07-05-2012, 01:58 PM   #37
GISdood
GISdood's Avatar
Oddometer: 856
G4 mod, please!
email sent
[SIZE=1][COLOR=DarkOrange][URL="http://gisdood.smugmug.com/Motorcycles/DR650/i-DxDHwsN/0/M/20140413_093548-M.jpg"]2002 DR650[/URL]
[URL="http://www.advrider.com/forums/showthread.php?t=712408"]Moto-fishing in Central BC[/URL]
[/COLOR][/SIZE]
GISdood is offline   Reply With Quote
Old 07-10-2012, 12:42 PM   #38
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
Scala G9 earbud mod
I have done a few mods on the G9 and it is quite different than the G4.
First here are some pics of the clamp. The first one is a picture of the open clamp, you can see there is much less room inside partly due to the smaller section along the bottom to accomodate the larger G9 unit and partly because Cardo went to a new method of mounting the microphone boom with a 3.5mm plug into the back of the unit. There are now 2 jacks inside from the factory, they are mounted on a small circuit board that stacks beneath the main board and has a very small connector between the boards.
Stacking boards
Small bottom board with connectors:
Finished unit with jack bonded to clamp bottom:
I will do the mod for the same $30 price as the G4 mod, $5 shipping, $5 plug for the speakers option. It takes a little longer to do however because of the glue.
Email me for my address and to make arrangements: eileen.kelleher at gmail.com
Old 07-20-2012, 03:02 PM   #39
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
Wayward G4...
A lonley lost wayward G4 clamp came in today via UPS with the return address of a mailboxes etc. in Houston.
If you are the owner who didn't put a note or a check inside please contact me so I know what to do with it. Email me at eileen.kelleher AT gmail.com.
Thanks much,
JetGrl
Old 08-05-2012, 11:59 AM   #40
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
Nicholas A Hill
I got a clamp in the mail today from Nicholas Hill but no email address or forum user name. If you are Nicholas Hill please contact me via PM or email at eileen.kelleher at gmail.com.
I need to know what you want done and how you are sending payment.
Thanks much.
Old 08-07-2012, 08:42 AM   #41
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
Mystery solved...
Old 08-15-2012, 05:43 PM   #42
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
G9 Mod Update
I have been working with one of my customers on volume issues with the G9.
Just to be clear, the G4 mod has the problem with volume being louder when you use the earbuds. It is a matter of impedance and power required. When the earbuds are used you need to run the master comm volume at a much lower level, almost at the bottom.
This is not really a problem with the G4, it is still usable. The difference you notice is when the master volume goes up to compensate for increase in background noise it goes in steps and when you are at a low volume level the steps seem large.
While you can live with it when using a G4 it gets harder when you are using a G9. The volume output of the G9 is higher than the G4 clamp can provide so as a result, it gets harder to live with at the low volume levels of the main control. Sometimes it can get to the point that when you plug in an MP3 player it may not be able to put out enough volume to get "noticed" by the amplifier and you can't hear it.
The solution is to get some resistance in the output to the earbuds. This can be done in 3 ways, either by installing a 56 ohm resistor on the common leg inside the clamp or by installing an inline volume control. If you install a resistor inside the clamp you can no longer plug the speakers back in and use them, the volume will be cut down and you can't hear it.
A simple solution is to get an inline volume control.
I found a source for some short inline controls that seem to work well and are cheap. I picked up a few of them and will pass them along to anyone who gets an earbud mod done for an additional $8. If you have had a mod done in the past just send me an email and I'll send you one for the same price plus postage.
This is what it looks like:
Old 06-19-2013, 12:21 PM   #43
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,512
incoming
Email incoming for G4 mods.
IDRIDR is offline   Reply With Quote
Old 06-27-2013, 04:58 PM   #44
leesoars
Oddometer: 16
g9 mods
HI. Jetgirl.
I have a g9 ordered and want to send them to you to be modified. I am using a set of good westone earbuds and like the sound and noise reduction they give me. As for the mp3 volume issue, is it still a problem when using a bluetooth mp3. I think you are saying it's an earbud issue not a source issue. Also what is your turnaround time?
"Can't slow down, the clowns will catch me"
leesoars is offline   Reply With Quote
Old 06-27-2013, 06:38 PM   #45
JetGrl OP
FJR Pilot
JetGrl's Avatar
Oddometer: 54
You are correct about the volume issue. The turn around is 2 workdays usually.
Shoot me an email and I will send you the particulars.
JetGrl
eileen.kelleher@gmail.com
Sent from my Nexus 7 using Tapatalk 2
Times are GMT -7.   It's 04:48 AM.
