Go Back   ADVrider > Riding > Trip Planning
Old 06-06-2011, 10:09 PM   #1
jetjackson OP
jetjackson's Avatar
Oddometer: 490
Question Adventure riding with daily medication that requires refridgeration - any experience?
So I am planning on taking 12-18 months to ride a bike around the world. Just booked the first flight on the weekend so my adventure begins on October 7th. Getting prepared though and have one issue to address...
I have an issue in that I have something called Hashimotos disease or Hypothyroid. I have to take medication every day or my thyroid hormone will drop. Your Thyroid is like the throttle on your body for those who don't know... so if I stop taking the medication it will be like slamming on the brakes on my body and the result is no energy, depression and endless tiredness and if left for say 6-12 months with no medication eventually I would likely die from a heart attack. The latter unlikely though.
The problem is that the medication needs to be refridgerated below 6 degrees celcius to be kept indefinitely. Once in room temperature <25 degrees celcius the medication will keep for a cumulative total of 4 weeks before the active ingredient starts to break down and potency is reduced. I can get about 8 months worth in advance before I leave and can probably get some more in the UK about half way through my trip by jumping through a few british hurdles. So whilst I can keep the medication above 6 degrees for some periods it would be better if I could reduce that time by carrying it in some sort of cold case on the bike.
So I need some way to store this on the bike and looking at something like this on the link below and rigging up a DC adapter to the bike and back to the cooler.
http://www.medicool.com/diabetes/dia...ler_fridge.php
Does anyone have any experience with this at all? Perhaps someone with diabetes that needs to store medication. Ideally I need a cooling device that can run off DC 12V/mains power with adapter/batteries.
jetjackson is offline   Reply With Quote
Old 06-07-2011, 01:40 AM   #2
bones_708
Oddometer: 574
It seems to me that you're on the right track. I,ve seen other DC cooler devices but none that compact and perfect for the job. I would suggest two things. Get yourself a good solar setup. One that if you drain your battery it can charge it enough to start it in a couple of hours.
http://www.amazon.com/California-Sol...431874&sr=8-11
I would also plan on making more visits to a doctor. Basicly a year and a half of meds without seeing anyone? That seems a bit much. Personaly I wouldnt think every 3 to 6 months to be too much when you consider that a lot of the symptons could be easily mistaken for a hard days travel. I would think you could pick a spot or two out for a doctors visit and a quick thyroid test in almost any major city.
bones_708 is offline   Reply With Quote
Old 06-07-2011, 12:59 PM   #3
PsychoSayWhat
PsychoSayWhat's Avatar
Oddometer: 437
That medicooler is very cool.
I can't say much on your health, but as far as the battery situation and the electronics, I found info that said the cooler uses 25 watts max (that's about 2.1 amps), and your stock battery I believe is 14 amp-hours, so you should "technically" be able to run that cooler for about (14 amps capacity/2.1 amps draw) = 6 hours until the battery would be completely dead from fully charged.
You might consider is getting a separate battery to run it from overnights and charge that battery off the bike while you ride. LiPo batteries are light, compact and have a lot of amps capacity for their size and weight, unfortunately they don't do well with heavy vibration or being punctured - so you would have to make sure it was padded & protected. You could also go with A123 cells for a little more money - the A123 cells are also a lot safer.
You will also need to make sure that cooler has some ventilation and that it doesn't get packed with dirt or flooded if it rains.
Good luck on your trip - sounds awesome!
Tiger 1050, Bonneville, Brutale
PsychoSayWhat is offline   Reply With Quote
Old 06-07-2011, 02:05 PM   #4
JakeDee
Oddometer: 8
Are you on Levothyroxine (synthroid)? I am, and I've never refrigerated it. Doc/instructions on the bottle only say to keep it away from direct sunlight.
JakeDee is offline   Reply With Quote
Old 06-07-2011, 07:51 PM   #5
jetjackson OP
jetjackson's Avatar
Oddometer: 490
No I am on Oroxine. In Australia they make the recommendation that you refridgerate it - not always recommended in other markets. How often do you get it dispensed though? I only get dispensed every 4 months or so.
@bones - you are right. I will have to get blood tests done every 3 months or so. My doctor in Australia is pretty good and I should be able to call him back with my results and also discuss with local doctor (I want my Aussie doctor who knows my entire situation to know what is going on as well) Thanks for the link to the solar panel. That is an awesome idea and could come in very handy for camping and other situations where I might not run the bike for 3-4 days or have access to refridgeration.
@Psycho - thanks for the battery tips. I would not have thought of that at all. Would have just put the unit somewhere in the pannier away from heat of exhaust.
Old 06-07-2011, 10:46 PM   #6
JakeDee
Oddometer: 8
Once per month. I've never refrigerated, and it keeps my levels normal.
Best of luck, man!
Old 06-07-2011, 11:17 PM   #7
Yakima
Whee! Wee Strom
Yakima's Avatar
Oddometer: 330
Google "Frio"..
Worked for month-plus with insulin.
Yakima is offline   Reply With Quote
Old 06-08-2011, 09:37 AM   #8
Eyes Shut
See no evil
Eyes Shut's Avatar
Oddometer: 2,067
Best of luck, man!
I take levoxyl also (the generic Synthroid), and just store it at RT. I can get 90 days at a time through a mail order pharmacy.
Eyes Shut is offline   Reply With Quote
Old 06-08-2011, 05:52 PM   #9
bush pilot
bush pilot's Avatar
Oddometer: 2,536
You probably already know this but there are a number of naturalpathic ways of dealing with hypothyrpoidism.
http://www.dreddyclinic.com/findinfo...l-remedies.htm
USA travels 09'
Anchorage to Ushuaia
RTW...part: Europe
Iron Butt #35784
bush pilot is offline   Reply With Quote
Old 06-08-2011, 11:22 PM   #10
jetjackson OP
jetjackson's Avatar
Oddometer: 490
Wow, thought it was really rare for guys to have Hypothyroid. Good to know there are a few others out there. I thought it was something predominantly older women got. I was expecting mostly responses on this topic from people with diabetes.
I understand that the medication lasts about 1 month at room temperature so if you are only getting 1 months supply at a time then you would not have any issues. However in Australia they give you a box of 10 sheets 20 tabs per sheet and at 1 pill a day that will last for six months. So I leave all 10 sheets in the fridge at the start and then take one sheet out at a time and take that over 20 days.
I understand that there are naturopathic ways of dealing with it but probably don't want to experiment these when I will be pushing myself on a regular basis. I have never suffered any hardcore symptoms. I am only 27 and I only found out last year because I was training for a marathon and all the extra exercise was putting my system under a sh-tload of pressure. I ran a marathon with high TSH levels so I can't be that bad. I was getting panic attacks and so went to the doctors thinking it was psycological (although I am lucky to have a carefree life with nothing that would suggest issues) and he did a blood test to make sure it wasn't physical. They found my TSH was 36 but my T4 levels were slightly under the low end of average. After being on the Oroxine my TSH has come way down and T4 just below middle of average range - panic attacks gone and have slightly more energy but not that noticable.
I am finding a lot of the problems with these fridges are they only have enough space for the shape of insulin, whereas I need something that will store 12cm x 6cm x 20cm for 6 months worth of medication.
Old 06-09-2011, 02:10 AM   #11
bush pilot
bush pilot's Avatar
Oddometer: 2,536
Riding motorcycle is much more therapeutic than running a marathon.
I'd be hesitant to place that much faith in a western doctoring. Some of thier treatments are actually self fullfilling where they futher suppress the body's natural coping ability.
If you were in thailand I'd invite you to come here.
http://www.siamhealthy.net/english/index.html
the doc here has been helping some remarkable healing of folks with her enzymes.
I happen to be there right now getting a tuneup for my upcoming trip.
As far as the 6 month supply perishble meds go there ought to be someone you know who you could forward it to to keep to in a fridge for ya, and send some when ya needed it.
I'd offer but I'm not based in the USA anymore and I'll be travelling too.
USA travels 09'
RTW...part: Europe
Iron Butt #35784
bush pilot screwed with this post 06-09-2011 at 02:16 AM
Old 06-09-2011, 04:03 AM   #12
bones_708
Oddometer: 574
Well you can get just about any size 12v "fridge" you want but the issue may be temp control. Most items don't have the narrow temp restrictions you are looking for so thermoelectric coolers are common and work fine but only lower the temp 35 degrees, or 20 for those who use Celsius, below ambient temp. The temps you need you would have to have one with a compressor and it will add weight and cost. a thermoelectric cooler, under $100 usd easy. Smallest compressor cooler I know of is 27lbs and $650 usd. Talk with your pharmacist about the drugs and maybe the 35 to 40 degrees, or 20 to 23 Celsius, will be enough. Otherwise expect to pay big and lug a good sized cooler everywhere. The other issue is a compressor cooler uses more power also. Check that your bike can supply the juice it needs or if you can upgrade the system to handle the draw up to 3.0 amps an hour. Do a search for ENGEL MD14F as it may be the closest to what you ask but I think you need to see if really need the requirements you first stated.
Old 06-09-2011, 06:07 AM   #13
jetjackson OP
jetjackson's Avatar
Oddometer: 490
Thanks Bones that is awesome advice.
Agreed Bush pilot... although running a marathon you learn about yourself... part of the same reason I want to ride to other countries.
I will stick with western meds for the moment, as I said above, now is not the time to experiment.
Old 06-09-2011, 06:12 AM   #14
BikePilot
BikePilot's Avatar
Oddometer: 11,253
It might be worth talking to a doc to see if there is another equally-effective med that doesn't require refrigeration. Sounds like there may be.
If it were me and the meds last a month at RT I think I'd be inclined to have fresh packets shipped along the route rather than trying to carry a fridge, but I prefer traveling light and simple.
Its going to be really difficult to run a compressor-cooler for an extended period of time. Even assuming the bike could make enough current to run the thing while you are on the road, what about at night and when stopped? Even if you had enough batteries to run it all night (weight and const prohibitive I suspect, at least with a compressor fridge) you wouldn't be able to charge them back up plus run the thing during your daily ride I think :O Anyway, without a generator and fuel supply the compressor mini-fridge probably isn't going to work.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 06-09-2011, 10:13 PM   #15
bush pilot
bush pilot's Avatar
Oddometer: 2,536
I understand your reluctance; but part of the adventure of travel is learning different ways of looking at things and different ways of problem solving.
Western therapies have thier place yet often they are limited to treating symtoms without addressing the health of the body as a whole functioning system.
There is a relationship between hypothyroidism, diabetes, and heart conditions.
The thyroid sympoms are likely a sign of an underlying imbalance.
Anyway it is just some food for thought as western medicine is good for replacing parts and ancient eastern thought considers all the parts and how they work together. The thyeoid is only a small part of the system.
It just seems like you're an awfully young guy to be locked into the box the doctors appear to have you in.
USA travels 09'
RTW...part: Europe
Iron Butt #35784
bush pilot screwed with this post 06-09-2011 at 11:09 PM
Times are GMT -7.   It's 04:04 AM.
