06-11-2011, 08:50 PM
#1 |
Oddometer: 5
I recently bought a new to me 2005 950 Adventure S. I just put some Remus pipes on it. I bolted them on, put it all back together, started her up, let it idle for a while and then it stalled out. It didn't want to start after that, and I knew I was about out of gas so next day I put some more gas in, start her up and let her idle for a few minutes.
Then it stalls again. And doesn't want to start again. I figure it must have to do with the new pipes and the jetting, but I don't know anything about jetting and if that may be the issue or what. I've searched the forums but haven't found anything that has helped. Any advice would be appreciated. I figure I probably should just take it to a dealer, but I'd like to learn how to fix this thing myself if I can. I'd even put the stock pipes back on but the freaking bolts snapped off and are still in the pipes. Jason |
06-11-2011, 09:17 PM
#2 |
Orange Caveman
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,098
How much choke are you using?
![]() -cp DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt. |
06-11-2011, 10:15 PM
#3 |
Oddometer: 5
I tried full, half and no choke when trying to restart it...
Had about half choke till it got going when I first started it. I'd add that it died when I tried to give it some gas. TILLER screwed with this post 06-11-2011 at 10:23 PM |
06-12-2011, 01:56 AM
#4 |
Orange Caveman
Oddometer: 7,098
If it's fairly cool weather, it will need some choke until it warms up a bit before it will idle or take much throttle (with stock jetting).
06-12-2011, 05:59 AM
#5 |
Cranky Old Fart
Oddometer: 2,325
Did you remember to turn on the Petcock at the bottom of the Left tank?
Tom 2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC To Think is to Create!http://my2wheels.com/forum/cmps_index.php |
06-12-2011, 08:52 AM
#6 |
Oddometer: 5
I will double check the petcocks.
Thing is before I swapped the stock pipes for Remus, i had no problems. Then swap and problem presents. I didn't take off the tanks or mess with anything but taking off the luggage racks. I will also double check I didn't clip any wires during my epic struggle to get the stock exhaust bolts off... I appreciate the responses. Jason |
06-12-2011, 02:35 PM
#7 |
Druid Revisionist
Oddometer: 396
It's worth a glance, as you wouldn't be the first to leave packing material inside new muffler...paper, plastic, red rags, etc.
....there's nothing more permanent than a temporary solution
