Old 06-12-2011, 06:56 PM   #1
vacantstare OP
vacantstare's Avatar
Oddometer: 294
"The Wedge"
I'm still a noob in the world of airheads, and I only very recently became aware of the wedge that is part of the handlebar controls. I installed a handlebar mounted master cylinder from the 88-93 RS model, and I had no recollection of having installed a wedge. This concerned me, because I read that without the wedge, you stand a good chance of cracking the perch when you tighten it down. I ordered one, then went to install it today. There doesnt seem to be room for it. I looked at the parts fiche in Max BMW, and it does not show this M/C perch as having a wedge, but curiously, the clutch does.
What am I missing?
vacantstare screwed with this post 06-13-2011 at 07:13 AM
vacantstare is offline   Reply With Quote
Old 06-12-2011, 07:05 PM   #2
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,241
I don't know when the wedge went away, but it must have been sometime in the early 80s, just guessing. Perhaps wirewrkr knows - he's familiar with stuff like that.
Old 06-12-2011, 08:41 PM   #3
melville
melville's Avatar
Oddometer: 1,495
My 1975 /6 did not take a wedge. Perhaps it ended with the last of the /5 style controls on the 1974 models? Here's the wedge, NOT fitting:
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 06-12-2011, 08:45 PM   #4
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
My '74 /6's do indeed have the /5 controls and wedge.
crazydrummerdude is offline   Reply With Quote
Old 06-12-2011, 09:06 PM   #5
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
I have a 1982 R100RT, and a 1965 R69S.
Never heard of "The Wedge", and don't remember seeing anything like that picture on either one. I've had both apart several times. (The R69S was apart when I acquired it)
Must have just been a /5 and /6 thing.
caponerd is offline   Reply With Quote
Old 06-12-2011, 09:25 PM   #6
cptmoney
Two wheels, only one seat
cptmoney's Avatar
Oddometer: 541
My '77 R75/7 has a pair of wedges - just saw them today.
cptmoney is offline   Reply With Quote
Old 06-12-2011, 10:02 PM   #7
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,644
I had one wedge on my R60/2 (and the other was a homemade wedge, broken piece of plastic). The /2 controls are similar to a /5. Are the R69S controls different from a "regular" /2?
Old 06-12-2011, 11:02 PM   #8
caponerd
caponerd's Avatar
Oddometer: 1,980
Shouldn't be. There was no wedge among the bits I put together, and I haven't had a reason to miss it.
These are Magura controls, which I assume are standard /2 units.
I'll have to look into this. Can the controls be removed without the wedge falling out? Maybe they were in there the whole time, and I just never noticed?
Prolly not likely, I did take the things apart to paint the mounts black.
Old 06-13-2011, 06:14 AM   #9
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,201
The wedge, Ithink, was used only on Magura control assemblies and may not have been used with post-Magura controls. Check MaxBMW or RealOEM for your specific model: Main Group 32, Steering.
BMWs can be so quaint at times...
'73 R60/5 Toaster
Old 06-13-2011, 08:33 AM   #10
melville
melville's Avatar
Oddometer: 1,495
But mine was Magura! Right up until I polished the logos off.
Old 06-13-2011, 09:11 AM   #11
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
R60/6, 1975. Had a wedge.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 06-13-2011, 09:42 AM   #12
England-Kev
Oddometer: 3,696
I have that on my R80ST, a right pain in the arse too.
England-Kev is offline   Reply With Quote
Old 06-13-2011, 09:51 AM   #13
Bill Harris
Oddometer: 8,201
Hmmm, may be. But check the parts fiche for specific applications...
'73 R60/5 Toaster
Old 06-13-2011, 10:35 AM   #14
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
76 /6 Mine had wedges
79/7 Mine has wedges
Them pesky little buggers WILL fall out when pulling off the perch. Watch for it. Put down some rags so it don't bounce under the work bench. If there are PO's anywhere in the background of your Airhead, don't be surprized if the are not there.
I saw somewhere some pix and instruction of how to make a wedge from a snipped and folded beer can. A thing of beauty from another Airhead problem solver.
They can be very difficult to get back on. Use a dab of thick grease to seat them firmly in the perch. Carefully twist and push easy and after several renditions of reseat the wedge and try again it will clear the bar end and go on.
DoktorT is offline   Reply With Quote
Old 06-29-2013, 11:16 AM   #15
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,988
My 1984 R65 has them.
Big Bamboo is online now   Reply With Quote
Times are GMT -7.   It's 09:30 AM.
