Old 09-22-2012, 08:48 AM   #256
knary OP
sunshine and puppies
knary's Avatar
Oddometer: 29,432
Put the rear wheel back together and on the bike for the first time in over a year, if only so I could move it in and out of the studio more easily.
Hrm.
Some parts appear to be missing in the rear hub and I realized that one set of bearings just drop in when, as I understand it, they should take heat to get in and out.
Hrm.
Maybe I'm misunderstandingerating something.
One set of bearings (#6) drops right in without any heat or pressure. Item #8 is scored and banged up as though a previous set of bearings had grenaded.
The stack of parts away from the final drive, not including the bearings, etc on the final drive side of the wheel. Hmm... not many parts.
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is offline   Reply With Quote
Old 09-22-2012, 09:44 AM   #257
Rinty
Rinty's Avatar
Oddometer: 546
This looks serious, but I'm not a wrench.
Thanks for the update, Scott. I had been wondering how the project was going.
Rinty is offline   Reply With Quote
Old 09-22-2012, 06:19 PM   #258
Horsehockey
A GPS? Huh?
Oddometer: 328
Click on the little pics to enlarge:
http://w6rec.com/duane/bmw/wheel_bearing/index.htm
Horsehockey is offline   Reply With Quote
Old 09-23-2012, 08:04 PM   #259
melville
melville's Avatar
Oddometer: 1,467
If the hub is a loose fit on the bearing outer, you may be able to save it with Loctite Sleeve Retainer.
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 09-26-2012, 08:25 PM   #260
scout18
scout18's Avatar
Oddometer: 938
I'm about to embark on a parallel journey with out the emotional attachment Scott. Just doing my research and found your thread. Thanks for the education so far. I'm just about to crack open the rear wheel on my 74 R75/6
Alis Volat Propiis
scout18 is offline   Reply With Quote
Old 09-26-2012, 08:58 PM   #261
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
That ones a little too far gone.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 09-26-2012, 10:36 PM   #262
knary OP
knary's Avatar
Oddometer: 29,432
Have I taught you how to go really really slowly with no end in sight?
With my daughter through the worst of the medical crap she should see for a number of years, I hope to make some real progress on this thing.
FWIW, I bolted the wheel back together and it's free of slop or, to my hand, undesirable drag. I should care that it isn't to spec, but I can't get too wound up about it at the moment. FWIW, the hub is about .1mm wider than the bearing race. IIRC.
Goodbye Toolfan
Old 09-27-2012, 08:33 AM   #263
lucky23
lucky23's Avatar
Oddometer: 197
Great bike. I just did a similar rebuild to an R75/5. Yes, those piston clips were a pain in the balls to get out! Keep it up! BTW, nice paintings.
lucky23 is offline   Reply With Quote
Old 11-13-2013, 11:21 PM   #264
knary OP
knary's Avatar
Oddometer: 29,432
Is it really more than 13 months later? Ok. I believe it. This past year has been focused on being a dad, husband, and rebuilding a career.
This meant that other than being the subject of a painting, the bike sat. I didn't have the time or energy to move forward. It didn't help that I'd lost all of my documentation of the cobbled wiring. I'd look at the tangle of wires, a mess before I took them off the bike, and the list of everything else that still needed sorting and look away.
But then, the skies parted with the arrival of Ben and Charla. While they were visiting one morning, Ben, the professional mechanical whiz, got the itch and sorted out some of that wiring. It was the push I needed. So after a crazy month of work, I went back at it, finishing up the bare minimum needed to get it to start and run. I hoped.
Two weeks ago:
A mess. But a running mess. It sounds *much* better in person. The heads are ripe for an overhaul, but I'd had them looked at not long after I picked up the bike.
Goodbye Toolfan
knary screwed with this post 11-13-2013 at 11:39 PM
Old 11-13-2013, 11:37 PM   #265
knary OP
knary's Avatar
Oddometer: 29,432
I've been a bit busy since, but I finally found a little more time yesterday. I picked up a few brake fittings and cleaned up some of the wiring mess. And today I went for a ride. Ok. Not much of a ride, but it was something.
I don't know if I'm giddy from getting this moving under it's own power, or dizzy from the fumes this thing was putting off as it baked off all the oils, cleansers and whatever else that had been rubbed into it those first months I had it.
Video 1 link
Video 2 link
The bike needs:
speedo/tach
charging light (if not part of the above)
rear lights
a better battery
battery box
grips
mirrors
some other incidentals including a seat
and those carbs tuned
Too many small movies of boring shit? I don't care.
Goodbye Toolfan
knary screwed with this post 11-14-2013 at 12:42 PM
Old 11-14-2013, 03:18 AM   #266
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,557
Finally!
Nice job!
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 11-14-2013, 07:10 AM   #267
Speed King
Speed King's Avatar
Oddometer: 1,635
Man, it looks good! Really diggin' the color as well. It's a great feeling isn't it? It's always easier for me to be motivated when I have the thing rolling around.
Speed King is offline   Reply With Quote
Old 11-14-2013, 09:04 AM   #268
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,454
Great work Scott!!
When you get it running and are going to take it out for a long weekend, let me know. I've got Mike's Falstaff jacket and I'll send it up to you for a reunion with the bike.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 11-14-2013, 09:32 AM   #269
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,542
That was a really great first ride.
---Albert Einstein
Old 11-14-2013, 12:45 PM   #270
knary OP
knary's Avatar
Oddometer: 29,432
Thanks, guys. I'm stoked. There's too much work to do, the regular bill paying kind, but I just want to tinker. Now that it's truly running it can be tuned.
Originally Posted by YetiGS View Post
Great work Scott!!
I didn't realize that had ended up down yonder.
I also just realized that it has been more than 18 months since I'd ridden a motorcycle and yet it felt more natural than anything else.
Goodbye Toolfan
Times are GMT -7.   It's 02:20 AM.
