Old 12-29-2012, 10:09 AM   #16
weld86 OP
Weld86 Motoparts
Oddometer: 196
2" center to center. 1 hole is slotted for tolerance.
weld86 screwed with this post 12-29-2012 at 02:03 PM
weld86 is offline   Reply With Quote
Old 01-06-2013, 11:20 PM   #17
Adrian V
Oddometer: 520
Tool tube size???
G'day Weld86,
Please can you confirm the size of the tool tubes that the brackets will accommodate? I looked on your website and you say the tooltube is 3 1/2" in diameter, but at the start of this thread you say the tooltube is 3 1/4" diameter?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 01-07-2013, 06:05 AM   #18
weld86 OP
Weld86 Motoparts
Oddometer: 196
The outside diameter whrere the strap clamps is 3 1/2". The inside diameter is 3 1/4" they are listed in the parts catalog wher I purchase them. Thanks for catching that.
weld86 screwed with this post 01-10-2013 at 03:05 PM
Old 01-13-2013, 10:20 AM   #19
stoney4vida
Semper Fidelis
stoney4vida's Avatar
Oddometer: 2,167
still available ?
stoney4vida is online now   Reply With Quote
Old 01-14-2013, 07:26 AM   #20
weld86 OP
Weld86 Motoparts
Oddometer: 196
Originally Posted by stoney4vida View Post
still available ?
Yes, I have them in stock. Check out my website. Thanks
Old 08-26-2013, 03:33 PM   #21
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,681
I've been forgetting to post this:
The "DR650" Tool Tube bracket I purchased fits our DR200 perfectly, and should be listed with the DR650. I dunno about the DRZ400.....
It is a nice piece of stainless steel that, while it costs a few $, works well, looks good, and therefore seems well worth the dough I spent.
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is online now   Reply With Quote
Old 01-19-2014, 09:08 AM   #22
Tj007m
Oddometer: 83
Tool tube bracket
Just put a order in. Looks like a good solution for mounting the plastic tube. Thanks.
Tj007m is offline   Reply With Quote
Old 01-19-2014, 09:35 AM   #23
jon_l
jon_l's Avatar
Oddometer: 3,466
Weld86's bracket is a quality piece. Mine is mounted in an unconventioanl location, but works fine:
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Times are GMT -7.   It's 08:26 AM.
