Old 06-17-2011, 05:41 AM   #31
choccoloco
Cabin Fever....
choccoloco's Avatar
Oddometer: 798
Great stuff Ray and the knowledge that this place can offer, some don't head into hacks.
Going through the process myself, one thing I noticed is that second hand outfits stay on the market quite long, something that I noticed is a real personal thing.
So with that, I want to make sure I set mine up right the first time.
I was put on to Phyllis, gave him a call and was blown away by his wealth of knowledge.
Once I've got the body sorted out, Phyllis was open about building the chasis, attaching to the bike & building the LL's.
Had an offer from A2 was to ride his, unfortunately haven't been able to meet up due to reasons I want a sidecar.
TspED3, I'm sure you are the same guy my boy always gets excited about when he sees what looks to be your outfit. The same outfit that you potentially see a blue VStrom hanging next to you giving you a wave. A couple of times with your young passenger on the Monaro.
choccoloco is offline   Reply With Quote
Old 06-17-2011, 05:42 AM   #32
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,692
Originally Posted by mcfear View Post
whats the advantage of the front end like this picture below compared to normal forks?
hytram hope you dont mind me using the photo
McFear - the long answer:
A Leading-link front end reduces the trail - that is, the distance between the actual contact patch of the tyre on the ground and a line drawn trough the steering head and extending to the ground. On most bikes, this distance is around 100mm and is one of the factors in straight-line stability.
But a rigid sidecar can't be leant into corners, so the front wheel needs to be turned to steer the outfit, like the tiller on a boat. This is made hard by the trail, so sidecar builders do a bunch of things to the front end - the main one is to reduce the trail to anything between 0 and 40mm to make the steering lighter. Usually it's done with a leading link - which is basically a swingarm the wrong way around.
However, reducing trail invariably reduces straight-line stability, so a fairly hefty steering damper is also a common fitment to eliminate wobbles. It's a linear process of curing symptoms caused by curing symptoms.
Hope that helps!
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 06-17-2011, 05:59 AM   #33
mcfear
now known as many things
mcfear's Avatar
Oddometer: 2,587
cheers guys.
got some photos uploading i found. went through about 2000 stills haha, took a fair while and only found 3 bloody photos of the sidecar haha. i know i got pictures somewhere of the sidecar in the air.
the bike is a kawasaki Z1300, and the sidecar was a 2 person but we had it when me and my sister were little. i think i was 9 or 10 when we got a car
back when we had it, it was the right size for me, my sister, a friend and the dog. it even had a boot for the groceries.
http://adventurerider.com.au/
My International Travel Blog
http://www.mcfearsadventures.blogspot.com.au
Originally Posted by tHEtREV View Post
mcfear is offline   Reply With Quote
Old 06-17-2011, 06:02 AM   #34
mcfear
mcfear's Avatar
Oddometer: 2,587
ours is the blue one in the middle pic.
Old 06-17-2011, 07:28 AM   #35
Hytram
crash test dummy
Hytram's Avatar
Oddometer: 700
Originally Posted by AL-58 View Post
Remember Marty?
yes Al..it was all your fault!!
Marty
'10 Multistrada 1200
Hytram is online now   Reply With Quote
Old 06-17-2011, 03:36 PM   #36
boy60
boy60's Avatar
Oddometer: 713
I bought it
I bought Al s outfit
then to this
now this
The handling is so much better with th LT than it was with the RS.
boy60 is offline   Reply With Quote
Old 06-17-2011, 08:16 PM   #37
AL-58
BMWs make good landfill
AL-58's Avatar
Oddometer: 850
The RS was better with the low seat than the high seat (better height for the bars). So that's 3 bikes that sidecar has been on now (the original owner in Canberra bought the chair and subframe new and never fitted them). 3 bikes for the leading link too (Mick Mathesons K100RT, the RS, now your LT).
Bloody kit bikes these things.
Good to see you're enjoying it. I'm on the lookout for some 1100 running gear to upgrade mine sometime in the future (house to finish first before building a suitable shed).
Al
AL-58 is offline   Reply With Quote
Old 06-17-2011, 08:17 PM   #38
sidecarcrazy
grandad in gladstone
sidecarcrazy's Avatar
Oddometer: 181
Side car design
Just finished building a new front end (leading link) for my outfit ( K1100 + home built chair)
Found out BMW R60 from 1950-1969 ran 65mm trail for chair use & 95mm trail for solo.
The swing arm pivot was also behind a vertical line dropped down from the steering head.
Have measured 5 other K1100 outfits (from a common point on the motor to the axel ) and found they varied from 510 mm to 570 mm and sump heights 175 mm to 225 mm.
Tyre and wheel sizes also come into how a bike handles.
The R60's also had the handle bar mounts behind the steering head pivot point as well, so my K1100 has the bars moved back 35 mm which helps to lighten the steering.
PJ in Gladstone SA
sidecarcrazy is offline   Reply With Quote
Old 06-17-2011, 11:12 PM   #39
TspeED3
Cult of Three
TspeED3's Avatar
Oddometer: 33
Yep sounds about right, I think I have seen you a couple of times. Don't be offended if the boys don't wave back, I am trying to teach them to only wave to the good looking ones.
Good pics McFear, other than the beard your old man hasn't changed a bit!
TspeED3 is offline   Reply With Quote
Old 06-19-2011, 02:22 AM   #40
boy60
boy60's Avatar
Oddometer: 713
LL's
Leading Links is a major improvement over standard forks. Have not ridden on standard forks for years. Ron Hudis built my first LL's and secound chair. It was brilliant to ride.
Old 06-19-2011, 04:13 AM   #41
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,560
I will be send my bike to Phyllis in the next month or so once i have the chair finished to mate up the chair I have sitting here at home. Phill came very highly recommend.
Brendan J is offline   Reply With Quote
Old 06-19-2011, 04:16 AM   #42
Clancy
Clancy's Avatar
Oddometer: 5,941
On ya Brendan. Anyone thinking of getting into outfits should be required to talk to Phyllis. The bloke's been riding 'em and building 'em most of his life, and he's forgotten more than most of us will ever know. His knowlege, enthusiasm, and willingness to pass it all on is invaluable.
And he sees the vision splendid of the sunlit plains extended,
And at night the wondrous glory of the everlasting stars.
Clancy is offline   Reply With Quote
Old 06-20-2011, 01:21 AM   #43
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,397
If God had a sidecar, it would have been built by Phyllis..
Originally Posted by troy safari carpente View Post
I don't even have a clue.
nevgriff64 is offline   Reply With Quote
Old 06-20-2011, 02:54 AM   #44
TspeED3
Cult of Three
TspeED3's Avatar
Oddometer: 33
Ever wondered why Lucifer fell?
Just sayin' is all.
(no idea if Phyllis had a hand in it or not though.
Old 06-20-2011, 03:55 PM   #45
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,053
Oh, please.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Times are GMT -7.   It's 09:22 PM.
