08-12-2011, 07:36 AM
#61 |
Oddometer: 429
Nice project and report. I need to find a project like that myself, the 700 doesnt seem too bad as the overall condition isnt too bad. Could you tell us how much you have into it so far? You're doing a great job, carry on.
08-12-2011, 07:45 AM
#62 |
Oddometer: 3,818
Thanks, Brian.
As to cost, so far it's less than $400. However, that's not counting the work in progress, which is estimated to be about $150. Having to buy a new piston really upped the cost on my budget build. But, the price does include a new back tire and both chain and sprockets, so not too bad so far. I finally got the valves and will drop them off at the machine shop this morning. I've also lined up a welder to do the frame. My buddy has been too busy to help me, so another buddy has a friend that's a certified welder who has a mobile welding set up and will come to my house. That's scheduled for tomorrow morning, so hopefully things will start rolling.
"Deeply flawed people make deeply flawed decisions." Kawidad screwed with this post 08-12-2011 at 07:53 AM |
08-16-2011, 11:31 AM
#63 |
Oddometer: 3,818
Okay, here's the repaired frame. The welding used a stick welder and thought the frame enforcing I did was excessive. However, I feel better and think this little piece should have been done at the factory; especially considering all of the loading that goes on at that point.
![]() ![]() And, now I again wait for Ron Ayers and the parts.
"Deeply flawed people make deeply flawed decisions." |
08-18-2011, 06:01 AM
#64 |
Oddometer: 3,818
The parts arrived and so off to the machine shop I went. The machinist said the head turned out good. The intake valves and seats were good as new (after his work, that is) and the new exhaust valves and seats turned out really well considering the damage.
So the next day, this is what I've got. ![]() ![]() He did some nice work for very little $$$.(A fellow rider who took pity on me
08-18-2011, 08:50 AM
#65 |
KLR tank commander
Location: Perinton NY; trail town USA but none for DS or MB
Oddometer: 217
can't wait. thanks for the detail.
08-19-2011, 08:18 AM
#66 |
Oddometer: 3,818
Well, I got it buttoned up and the thermostat housing started leaking like a sieve. I've had to go back and figure that out. I re-used the thermostat with what appeared to be an intact gasket. So, I have to drain the coolant and re-exam what went wrong.
![]() The problem right now is I've run out of time before I leave on a pre-planned family vacation. So it'll have to wait until next week.....
08-19-2011, 09:29 AM
#67 | |
CDI REPAIR
Oddometer: 3,332
![]() ![]() sorry...too many beer.....or not enough,depends how you look at it..![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
08-19-2011, 12:48 PM
#68 |
Oddometer: 470
should have added some more metal to the cylinder head cooling fins to aid in cooling .. its a idea i found when dealing with temps on a xr600r
08-19-2011, 10:22 PM
#69 |
Yes, it is BIG.
Oddometer: 94
Given that the KLR is liquid cooled, he'd be better off to do the thermo bob.
The Kawasaki KLR 650, sure it will do that! Hell, it'll do anything ... just not necessarily well.
08-19-2011, 10:26 PM
#70 |
Oddometer: 470
well that two lol but have you seen what they look like adding biger fins that is .. there there on the cylnder head jug for a reason there a heat sink so why not add some more heat sink to heelp cool the bad boy down????????????/ just a thought .. i was going to do it to my aircooled xr but then i sold it and bought this :)
08-26-2011, 09:25 AM
#71 | |
Oddometer: 3,818
I doubt seriously that would be cost effective. Moving the overflow bottle and adding a secondary radiator would be a far better solution if necessary.
08-26-2011, 09:27 AM
#72 |
Oddometer: 3,818
Okay. I'm back and pulled the thermostat housing. I couldn't find anything that looked wrong and the gasket looked okay, so I cheated and used a little bit of silicon to seal it up. It worked like a charm, no more leaks.
I thumbed the starter and it started immediately. However, it won't stay running for anything longer than a couple of seconds. It settles into a normal fast idle for about a second or two and then dies. If I give it any throttle, it dies instantly. If I try to start it without the choke, no dice at all. ![]() I already cleaned the carb and it looked really good in the first place. I've also check the tank vents and rebuilt the petcock. ![]() It acts like carburation, but I'm not sure. I pulled the valve cover off to double check the cam timing, and it looked good. I guess I'll pull the carb and check it again.
08-26-2011, 07:54 PM
#73 |
Pitch pine slalom
Oddometer: 420
That sounds like a carburetor problem to me too. Glad you got it going though, and nice repair on that frame.
There seems to be less and less garden in this state. |
08-26-2011, 08:05 PM
#74 |
Irreverent Reverend
Oddometer: 2,078
.. getting close ..
.. also check your tank vents ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.." RevBill's SmugMug Shenanigans My '06 KLR |
08-26-2011, 08:34 PM
#75 |
Ribbon Rider
Does that mean U won't be riding with us CCKLR riders tomorrow=Sat. up to Big Sur?Good lucky with Your Project M/C.
Happiness Is Riding My Two Wheel Prozac 2013 Triumph Explorer |
