Old 06-21-2011, 04:25 PM   #1
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
airhead off road suspension?
Does anyone have experience in upgrading airhead suspension for real off road use?
I assume some of you have tricked out airhead dirtbikes
I have a paralever 80gs which I use as a dual sport bike on conti tkc's.
the tractor pull is great and as long as you avoid mud with those tyres - it can get you through far more than it should.
Have got into it enough that I now wanted to move on from the soggy stock ride
Ras Thurlo screwed with this post 10-30-2012 at 02:26 AM
Ras Thurlo is offline   Reply With Quote
Old 06-21-2011, 04:37 PM   #2
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,725
There is some info here:
http://www.advrider.com/forums/showt...ghlight=unholy
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 06-22-2011, 12:03 AM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,537
I'm lining one up as my next project.
I have a few sets of WP USD forks from 640 KTM's in my stash, getting them to fit the GS is pretty straightforward.
The stem simply presses out, took around 5 tons of pressure on a press, it's then just a case of machining the KTM stem down to take BMW bearings. before pressing the stem back in.
This is my mock up and a long way from what the bike will end up looking like. The frame will need bracing before I use the bike.
If you want it done well then have a look at Richie Moores website http://www.moorespeed.co.uk/aircoole...s-improvements
I want to ship my frame to Richie for the bracing work. Looks like this when it's done.
Shurv has posted his rebuild using Moorespeed parts and services http://www.ukgser.com/forums/showthread.php?t=247228
Rob Farmer screwed with this post 06-22-2011 at 12:21 AM
Rob Farmer is offline   Reply With Quote
Old 06-22-2011, 03:21 AM   #4
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,949
1100/1150 swingarm/rear end?
We appear to be headed down a similar garden path, Rob...
Old 06-22-2011, 12:31 PM   #5
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,537
How far have you got with it Lornce? What are you doing about the offset in the rear wheel?
Ideally I'd have liked the 1150 swinging arm driveshaft/Swing arm because it's shorter but the 1100 parts came up at the right price.
Old 06-22-2011, 02:17 PM   #6
airheadpilot
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 286
Something I've wanted to try (but don't currently have a Paralever bike to try it on) is combining the 1150 swingarm with the airhead drum brake final drive. I've seen photos of some of the HPN bikes that appear to have taken this route, and it seems to me that you'd get the central-mounted shock and slightly longer swingarm afforded by the oilhead, but be able to use the airhead GS driveshaft (although you'd probably need to have it extended). Did you look at this at all? I'd be curious as to how easy it is to mate the airhead final drive to the oilhead swingarm.
Andrew
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 06-22-2011, 02:33 PM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,537
Andrew,
I'm not sure what you'd gain by that. The 1100 driveshaft will fit to the Paralever bevel box but you need the adapter at the gearbox end. The whole point of the conversion for me is to replace the increasingly expensive and hard to find drum braked rear wheel for a disk brake and remove the driveshaft failing problem by fitting the stronger oilhead one.
The paralever bevel box will fit in the 1100/1150 swinging arms but will need a torque arm mounting with an offset. The standard shock will be too short as well.
Oilhead parts are very cheap at the minute so it makes sense to make use of as many as possible.
Old 06-22-2011, 08:51 PM   #8
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,949
Still in the parts gathering stage. Have a complete WP Extreme 50 front end from a Husaberg and swingarm/final drive/wheel/disc brake ass'bly from my aulde 1150 carcass. Still need a driveshaft to mod to suit. Haven't decided if I'll use the 1150 rear wheel or lace the 1150 hub to an airhead rim. Those 150 section tires are expensive.
Primary reason for doing it is to raise ride height and use the taller oilhead 2.91 final drive. 3.09 airhead gears are rediculously short for a healthy litre motor, imho.
Old 06-22-2011, 08:59 PM   #9
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,469
If you think 3.09 is short, try a 3.36. Yeeesh.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-22-2011, 09:11 PM   #10
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,199
I'm not sure what you guys mean by "offroad" I think it means something different here than it does elsewhere. If you'd like basic endless dirt roads and long highspeed desert stuff, a front end thats adjustable on the fly and increased wheelbase with a long rear end and stiffer braced frame is all good... but if you are talking about non-touring tight stuff, where the traction pattern of the tire will actually make a significant difference you have a different path to go down.
Unintentional psychokinesis.
Stagehand screwed with this post 06-22-2011 at 09:17 PM
Stagehand is online now   Reply With Quote
Old 06-22-2011, 10:26 PM   #11
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,676
I'm interested.
More on your thoughts on "non-touring tight stuff" setup.
I've been keeping the wheelbase short so the bike will turn and the supension low enough so I can still get on and off to open gates, high enough to clear logs, soft enough not to skip on bowling ball sized rocks and stiff enough to handle jumps and power sliding sweepers.
Conflicting compromises all then add in strong enough to take the punishment and light enough to be handled and it all gets pretty hard to make a good choice even if I had unlimited $$$$ to throw at it.
I haven't mentioned brakes yet
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 06-23-2011, 09:52 AM   #12
Ricklesss
Ricklesssssssss
Ricklesss's Avatar
Oddometer: 142
To me, "off road", mean's lowwwww gearing...I've got a 32/9 (3.56) rear drive on my /6 g/s, and if you can hang onto it, it will climb up and over most anything. It's especially good for crawling over downed/stalled riders in front of me.
It supposedly still has a 90mph top end, though I've never tried. I like it.
RicklessssssS in Oregon
Ricklessssssssss in Oregon
"Never ride faster than your guardian angel can fly."
"And no matter what, what ever you do, NEVER chase camels faster than your guardian angel can fly...
Ricklesss is offline   Reply With Quote
Old 06-23-2011, 10:19 AM   #13
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,199
Wrote something, but got booted in last night's site maintenance.
What I basically said was I guess I need to ride one of these WP'd 1150 swingarmed bandits to see if they really do better than significantly better for what I want to do with them, which isnt necessarily Dakar stuff. A steering damper alone did more for me than an entire frontendectomy.
SO I am saying I shouldnt have spoken out of turn, because I dont actually know how good those expensive modifications really are. Dont get me wrong, I am the first one to pour stupid money onto projects already burning, but I need to get out more.
Speaking of which, Rucksta, if thats your kind of riding, I want to ride with you
I kind of want one GS to keep relatively stock like mine kind of is, and I want another to trick out like crazy.
Old 06-23-2011, 01:49 PM   #14
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,537
They aren't expensive options. The whole front end on my bike in the picture cost less than a new pair of stanchions for the standard front end and thats with the brakes and master cylinder. PYCymu, an inmate here, gave me another front end the other day. If the parts are cheap it's worth trying? If it works well I'll be buying a set of Gletter yolks.
Old 06-23-2011, 03:49 PM   #15
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,949
I could barely stand that at 800cc. At 1000cc? No way.
Times are GMT -7.   It's 07:49 PM.
