06-23-2011, 03:00 PM
#16 |
Lost In Place
Oddometer: 15,975
You've got me curious Stage, because I can't imagine how a GS would/could possibly benefit from a steering damper?
![]() ![]() I've pushed the aulde PD through some fair decent "extremes" over the years and have had moments wishing for less weight, better traction more suspension or greater ground clearance. But never, ever have I felt a need for a steering damper. What's up with that?
06-23-2011, 03:23 PM
#17 | |
Lost again
Oddometer: 3,530
This was on a lighter bike with better traction, more suspension and greater ground clearance...
DRCOOL rides with me |
06-23-2011, 06:26 PM
#18 |
Chronic Noob
Oddometer: 2,292
Stage. I've watched your exploits on the GS and also though I'd like to ride with that guy he seems to know how to have a lot of fun.
I've considered a steering dampner but got used to the mild headshake as the bikes way of telling me to ride more agressivly. I've gone long on the front and rear 265/210mm on a shorter than stock wheeelbase. I only use 210/170mm of travel but its nice to know I'm not approaching the limits. The suspension mods changed the bike to allow selection of gear and throttle to choose power delivery rather than gear for speed to match the front end performance to the terrain. Pretty much the bike is a 3rd gear proposition with second being for cautious apprasial of what lies ahead and 4th for open sections of forest where the response from the power and torque of 4000+ rpm is not called for. 5th is transport and hooning but 4th is still good for hooning on dirt roads. A taller 5th is on the menu. 1st is for getting it wrong or wusssing out. Bike still does "Dakar" really well but not as good as a long driveshaft long wheelbase bike but well enough to see of all but the 950SEs, HPNs and the occasional well riden ADV990. For the extra high speed stability and luggage /load balance options of the longer swing arm I've decided to pass cause I'm not that fast anymore and I'm a credit card camper prefering pubs and a mimimal payload on the bike. So how is this related to the original post? My experience is franken bike conversions are a good thing but full blown "Dakar" type conversions may not be appropriate for all riders and riding conditions. I went duc hunting (rare for me to enjoy sealed roads) a while back with a bloke on an HPN frame / suspension and the 1040 motor. He was clearly faster on the top end when the 336 cam kicked in but the roads we were on were more suited to mid range and a more nimble set up. Turning, braking stability and power on exit were more important on the day. We both enjoyed ourselves, picked up a couple of scalps and got some ideas re alternate setup on our bikes.
If the Earth is flat why are my tyres round? |
06-25-2011, 10:01 PM
#19 | |
+/- V TDSPP
Oddometer: 19,897
This is video of stuff that a steering damper is great for: http://www.youtube.com/watch?v=QaXRnxAlwZI Granted, this is also the kind of stuff that a larger HPN style bike would be great for. Country Doc can probably back me up on this. He's raced Rallymoto as well, AND is building an HPN. Lornce, I swear I'd let you ride mine to try it out, but its got progressive front springs and heavy fluid, so I know you wouldnt like it. But I dont want to do that, its like gilding the lily or something. I like it basic, with all the more or less original stuff on it. Sure it isnt too expensive, but Mr. Farmer, thats only the beginning. A full WP front end isnt so bad and of course, grafting an 1150 rear end isnt too bad by itself either I suppose. Everybody has a different idea for the upper shock mount, dont they? THere are definitely times I want to try the HPN style desert long legged warriors and see what they could do, but I also want to see if they are just awkward giraffes in the back woods, or if they go another way.
What to do... What to do... Stagehand screwed with this post 06-25-2011 at 10:12 PM |
06-26-2011, 01:58 AM
#20 |
Commonist
Oddometer: 14,130
Ruksta Stage room now.
![]() Long distance romances never end well.
7th Day Adventourist. Terrafied -If you get it wrong you'll get it right next time- |
06-26-2011, 03:32 AM
#21 |
Chronic Noob
Oddometer: 2,292
Yep sure don't, glad you spotted that.
06-26-2011, 03:54 AM
#22 | |
Lost In Place
Oddometer: 15,975
06-26-2011, 05:20 AM
#23 |
Oddometer: 3,460
I'll echo what Stage said. Riding the R100GS in rough stuff (Rockies singletrack etc.) the deflection of the front wheel gets exhausting for me. I don't have a steering damper but I can fully see how it would help exactly as he describes.
It's probably because of the roadrace influence that people think steering dampers are to reduce tankslappers. For offroad, for me at least, this is simply not the case. It's a whole different situation. The R100GS has relatively short trail compared to comparable bikes from KTM or even BMW. Great on flat surfaces but I think there's more leverage for impacts forward of the steering axis (when you strike rocks, the tire is hitting them well forward of the normal contact patch) to twist the bars in your hands. This is the behavior of the GS that I like the least. |
06-26-2011, 06:19 AM
#24 |
Chronic Noob
Oddometer: 2,292
I can agree with this argument but feel a steering damper, even a modern
radial is just masking the symptoms of a suspension setup and geometry that is less than optimal. Once you have some travel to play with, a suitable spring rate and a sophisticated compression damping arrangement, the causes of the headshake and deflection can start to be addressed. Changing the front end to an alternate product often means changing the triple clamps and adjustments to the rear suspension. This is a good oportunity to address the underlying geometry causes. Replacing the triples with a lower offset type, often all that is available without custom fabrication with a front end swap, increases the trail. Having the 'luxury' of running >50mm static sag and little or no preload makes for very effective unloading of the front end under power (even with the shaft jacking of a monolever) and subsequent "lengthening" of the geometry. The compliance offered by high and low speed circuts on both compression and rebound means the suspension can be tunned to ride over variations in the suface rather than try to move them out of the way without too much of a compromise of hardness on the big hits & jumps. For Stage with his "stock for class" requirement a transplant is not an option but for others the cost of a radial damper can represent a fraction of the cost of the front end swap. I chose the transplant it might not be the best choice for everyone.
06-26-2011, 11:18 AM
#25 |
+/- V TDSPP
Oddometer: 19,897
I'd agree that the GS geometry is less than optimal for what we're asking them to do
lol get a room Its totally be worth getting on a bike set up as such to see what I'm missing.
What to do... What to do... |
10-25-2012, 08:52 PM
#26 |
+/- V TDSPP
Oddometer: 19,897
OK, now I've ridden one with pretty decent suspension and Ive decided I have no idea what the hell I'm talking about.
Apparently you are supposed to ride with the throttle, anyway. I was lugging it over major bumps, and it was kicking me in the kidneys. They said "make the revs higher. even if you go the same speed, just be down a gear and rev it higher" and it smoothed the rear suspension right out. Other than that, I only have everything to learn.
10-26-2012, 02:00 AM
#27 |
Oddometer: 921
Thanks for the bump Jason,
I hadn't read this thread before. I think we need to start developing a thread index or something for all these kind of GS-ish suspension/geometry/tuning etc discussions that are spread around the place. Of course this is all very relevant for me- I've gone the WP50mm front end, shortened, the Rdubb triples with 38mm offset (which combined with the increased WP50 axel offset must make for a very small trail), ohlins on the rear, I'm going to try to emulate Rucksta's raising of the rear by moving the shock mount forward and keep the shorter wheelbase, and then extend the forks a bit longer again, and I've got a road (damping both ways) scotts/ohlins steering damper on it. Should be interesting... and I think I've got a lot more to learn than you do! I just wish I had a bit more time to work on it again. Moved house, back to full time study briefly, and probably about to head OS for the summer... Soon, soon... |
