Old 06-22-2011, 05:35 PM   #1
newellbc OP
Oddometer: 55
DR650 sidecar
Hi there. I just finished putting together a hack, with a 2011 Suzuki DR650, a kenna single frame from DMC, and mounts from DMC, and a body from wherever. I bought the body and frame used for 1200 dollars, the mounts and a skidpan from DMC for 600 dollars. The bike has less than 600 miles on it. I changed the sprockets, 1 tooth down on front, 1 tooth up on back, so I could leave the chain alone. Just finished it today. So, only 60 miles on it. It's really light handling. I also have an older GL1000 with a sidecar. What a difference. I had it up to 75 mph on the highway, it can do it, but not comfortable. Up to 65 mph, it is nice.
newellbc is offline   Reply With Quote
Old 06-22-2011, 05:38 PM   #2
newellbc OP
Oddometer: 55
DR650 kenna single frame
Hi there. Here is a picture of the Kenna single frame and mounts attached to my DR650.
Old 06-22-2011, 05:41 PM   #3
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 489
Looks very nice, I like the white .Any more photos? So how light is light?
Any thoughts of a smaller diameter front wheel? Maybe match the rear?
LL front end?
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 06-22-2011, 05:44 PM   #4
newellbc OP
Oddometer: 55
Fender on Kenna frame
Hi there. The kenna single frame did not come with a fender. I welded on the supports and installed the fender. I have no electrical connections to the sidecar. I'm keeping it real simple. Remove 4 bolts, and the body comes off. So, I could install a platform real easy. I bought the DR650 specifically for mounting a light sidecar. It ways less than a KLR 650, has more stock horsepower and torque. I used to own a KLR 650, and always found it buzzy. The DR650 is smoother. If I ever plan a long trip, I can easily install an after market fuel tank for more range. Blaine
Old 06-22-2011, 05:46 PM   #5
newellbc OP
Oddometer: 55
Another pic
Here is another pic
Old 06-22-2011, 05:47 PM   #6
newellbc OP
Oddometer: 55
How light.
I'll go weigh it. I think it will be about 450. I'll be back.
Old 06-22-2011, 05:47 PM   #7
D.Bachtel
D.Bachtel's Avatar
Oddometer: 489
Talking
Hey Blaine, the DRs are stout and have always seemed to have more perk than the KLRs. Friend at work just bought a DRZ400. Nice bike. So what does the entire outfit weigh?
Don in Nipomo
Old 06-22-2011, 05:49 PM   #8
D.Bachtel
D.Bachtel's Avatar
Oddometer: 489
Beat me to it. What sort of track width did you end up with? Offset?
Don in Nipomo
Old 06-22-2011, 05:54 PM   #9
newellbc OP
Oddometer: 55
How heavy
Hi there. I used my bathroom scale on each of the wheels. How accurate is that, I don't know. The sidecar wheel was 95 lbs. The front wheel was 192 lbs. The rear wheel was 230 lbs. A grand total of 517, and that's a full tank of gas, and tail pack on the bike, and some small stuff in the sidecar. So, about 500 lbs. Blaine
Old 06-22-2011, 05:59 PM   #10
Qwik
Adrenaline Addict
Oddometer: 6,712
Looks good. Suzook reliability and Hack Usability
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 06-22-2011, 06:00 PM   #11
newellbc OP
Oddometer: 55
Size.
Hi there. From center to center on the tires is 45 inches. From outside edge of fender to other side end of handle bar is about 62 inches. I tried to keep it narrow to ride on ATV trails. The wheel lead is a little more than I wanted. But seems to work fine. It's about 10 inches of lead. The toe in is close to 1/2 inch. Blaine
Old 06-22-2011, 06:23 PM   #12
TebKLR
TebKLR's Avatar
Oddometer: 637
NICE! Hope you have more fun than a barrel of monkeys riding, no wait, DRIVING, it all over the place!
TebKLR is online now   Reply With Quote
Old 06-22-2011, 06:28 PM   #13
D.Bachtel
D.Bachtel's Avatar
Oddometer: 489
Thumb
Not sure about the bathscale, thought you might have a truckscale out in the shop.
I think I'm weighing in at about 360 lbs with a 44" track and 8" of lead.
Real agile and easy to roll around. Will enter flight over the right whoop de doos. The two tracks are fun, not a quite a catamaran but more like a canoe with an outrigger.
If you pilot it just right it's similar to running lengthwise in ocean or lake swells. Keep it upright and don't get awash.
Don in Nipomo
Old 06-24-2011, 02:33 AM   #14
Tussocktopper
Oddometer: 17
Top Front Mount
This seams to be just right and it is along the lines of what I am planning for my DR650 (at 64 its no longer a laugh to come off on the fire trails). Could you please show a photo of the top front mount or describe its fixing? Is it clamped to the thin section of the front down tube? I will be mounting mine on the LHS here in Australia so the oil cooler will not be such a problem
Tussocktopper is offline   Reply With Quote
Old 06-24-2011, 08:26 AM   #15
newellbc OP
Oddometer: 55
Upper front mount
Hi there. The upper front mount is a thick piece of plate steel, that bolted onto the front motor mount bracket running up to were the bolt held on the crash guard for the oil cooler. So the crash guard for the oil cooler came off, and the piece of plate went on. The piece of plate has tabs on it, drilled and threaded, to reattach the oil cooler. The problem for you, is that the oil cooler is on the wrong side. Sorry.
Times are GMT -7.   It's 04:34 AM.
