Old 05-22-2013, 09:02 PM   #901
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Round two. Many of you are familiar with the woes I have had with this carbon build up inside the motor of Hobbes. It happened once around 8500 miles and the stealership in Denver and Triumph fixed it no problem. They said leaky valve guide seals were the culprit.
A number of months ago, and before I quit my job in aviation, I took a really fancy boroscope and looked inside the cylinders. I photographed the carbon build-up and showed them to the stearlship in Boise. They and Triumph agreed that they needed to look in the motor again. And this was after a month of taking their sweet ass time getting things approved.
Work finally started and of course I didn't get many updates. I asked to see the motor torn apart and was never called. Just called when the work was done. I asked to see pictures and the recorded measurements of valve clearances and cylinders. I've had my bike back for weeks and I'm still waiting on this data. I've asked Birds of Prey three times now.
I was told the technician thought this was a totally normal amount of carbon build up. All things in spec. Nothing wrong.
Well what about the shitty fuel mileage? Could all the excess fuel they are dumping into the motor be causing the carbon? Back story in this is these Tigers had a stalling problem when they first came out. Mine never stalled once and I never had this problem. Triumph came out with a MANDATORY service bulletin engine tune to solve this problem I never had. During Round
One they loaded the new tune for a performance pipe and my gas mileage went from low 50's and high 40's to low 40's and high 30's. 10 mpg I lost for a problem I never had. Now I can't even get 200 miles out of a tank of gas. That's a big problem for people in this part of the country. What's the solution? Spend $400 on a Power Commander V and another $300 to have it dynoed and a real fuel map drawn. Triumph doesn't own a dyno and leaves us with this shitty fix? Guess so.
So maybe that would help. Spend $700 I don't have right now to fix the shitty tune Triumph wrote to solve a problem they tell me doesn't exist. Well, I don't know what to do anymore. Actually I do. My warranty has expired and I'm just gonna ride the damn thing. It runs like a top and there has never been any performance issues. The bike just screams and has always been reliable. Guess I should just ride it. I think that's what I'll do.
The conclusion to this carbon build up? They say it's normal and there's nothing wrong. I guess that's what I have to go with.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 05-22-2013, 09:08 PM   #902
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
Wow, that sucks! Glad I'm no longer planning to get a Tiger 800XC.
I'd say when you have the money, get a proper tune. If for no other reason than to get your mpg back. But otherwise, just ride it.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 05-23-2013, 09:13 AM   #903
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
It's common knowledge the Arrow tune will drop mpg by about 10mpg. Load the latest non-Arrow tune and your normal mpg will return and the bike will probably run better than ever. Do you have the Arrow exhaust? It's sounds like you don't. Zero reason to be running the Arrow tune. NFW I would waste time with a Power Commander for this bike.
The cable is $20 and the TuneECU software is free. Load the map yourself.
http://www.ebay.com/itm/USB-cable-fo...072d1e&vxp=mtr
swimmer is offline   Reply With Quote
Old 05-23-2013, 09:19 AM   #904
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
Rob
I am not familiar with his situation early on at 8500 miles but in this latest scenario his dealer is the problem. Search around and try to find someone with similar issues. Good luck.
Old 05-23-2013, 09:23 AM   #905
ducnut
Oddometer: 3,320
Agreed.
Sounds like a dealer who doesn't know what to do and is just throwing ignorance at the bike.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 05-23-2013, 08:35 PM   #906
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Thanks Swimmer. I knew about tune ECU and I'll go this route. I have an aftermarket exhaust, but not the Arrow. It's a Fuel exhaust which I highly recommend for the sound and the price point. I'll have to search to find the non Arrow tune. I asked the dealership to load it since there's no longer any more warranty to void. They refused. Not real happy with them. But they are the only Triumph dealership for hundreds of miles.
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 05-23-2013, 08:36 PM   #907
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Sitting down to write at least one episode for you guys tonight. Gonna get busy.
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 05-23-2013, 09:37 PM   #908
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
http://www.tomhamburg.net/Tune_List.html
From that site it looks like map 20654 or 20653 is what you need depending on ABS or not. Others are running Leo Vince, Scorpion, Fuel, etc... with the standard (non-Arrow) map with no problems and aren't suffering the loss in mpg.
As a precaution pull your headlight and tail light fuses when you are connecting to the bike so that they aren't pulling the voltage down when you are installing the new map.
That ebay cable is the exact one I ordered. It works.
Too bad about the crappy service from the dealer. Maybe you could throw your stock exhaust on real quick tell them you sold the Fuel and get them to put the standard map on then switch the exhaust back...
Old 05-23-2013, 11:25 PM   #909
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
I like this girl. She's the type to jump head first into something she likes. Today is the day when it is time to test if she likes this dual sport thing or not. She's read my entire blog and thinks she knows what she's getting into with The Adventures of Tyson and Hobbes.
She's bought all the gear and we haven't even touched a speck of gravel yet. You guys know me by now. Safety first! ATGATT. Fly Trekker DS helmet, Fox Titan body armor, Rev'it pants, Fox boots, and Fox knee guards. I had a jacket for her. Have I mentioned I like this girl?
It's May 5th. Her birthday. Our first ride is going to circumnavigate the Owyhee Range to the Southwest of Boise and we will be in Oregon for awhile. Simple route. Highway 78 to Mud Flat road. Cross the North Fork of the Owyhee River and make a right on Corral Creek. Meet back up with the highway and burn 95 home. Simple route to get her new stuff dusty.
It's cold this morning. Not sure why the hell my heated vest is at home. But, it is. Then, I notice we start to have a little bit of an issue. 38 miles to fuel and 32 miles remain on board. I kept her in the dark for a little while. But, I had to point it out to get her blood flowing when the miles remaining were on zero, low fuel light illuminated, and no bars of gas left when we were still at least 6 miles from the gas station. Nice way to start out her first ride with a little excitement.
We made it. Had plenty of fuel left. All of 0.15 gallons. Even on the highway out in the desert there is barely any gas.
The sun is out, but it is still chilly. And it sure is nice to have someone to snuggle with on the bike. Not that it's any warmer, but is sure is more pleasant.
Off on the gravel for her first taste of life off road on a motorcycle. Of course they laid down fresh gravel so the bike is squirmy as hell.
We got a kick out of this. The Pole Creek Wilderness is one of the new Wilderness areas that has been created over the past few years. And you all know how I feel about more wilderness in this part of the country. But if you don't know how I feel, I'M AGAINST IT!! All it does is block off areas that would have been used by people and allow only foot traffic in. And let me tell you... ain't nobody hiking this shit in the desert. Public land disappears.
Not sure what the author meant in the photo below, but I like to think somebody is as pissed off as I am they can't use this land anymore.
Dropping into the North Fork of the Owyhee Canyon. We are getting hungry and it's time to stop for lunch down there.
Time for a little food. And time for a little update. I've almost left the writing out of this story for effect. There's just nothing to report about her. And that's the great part. She's a natural rider.
Other than the added weight, and that's not much for this sexy woman, I can't even tell she's back there. She moves right along with me, is conscious about body position when stopped, and squeezes me back when I grab her hand.
We had a nice lunch sitting in the sun. It warm and scenery was beautiful. Time to load up and continue the journey.
We found our turn off to Corral Creek Rd. Just as my friend Tom said it would be. And now I even have somebody to get the gates for me!
Now you don't think I'd let our first ride take place on ALL good graded gravel roads, would you? Nope. Sure as hell not. Now that she's a little used to being off road, let's go down a mountain two track.
Corral Creek traverses three different creek drainages and then climbs to the North side of South Mountain. The tallest peak in the Southern Owyhees. Tom told me it would be rough in places. And we are looking forward to it!
The first drainage has quite the entrance to it and I asked Tamara to walk it. There were some step downs and a fair amount of large loose rocks followed by a sharp left switchback. She was happy to take photos.
Bad snow year this year means all the creeks are running really low. This was Tamara's first creek crossing on a moto. Juniper Creek.
Cabin Creek drainage.
South Mountain in the hazy distance. We'll be headed to the right of that mountain and it's all unmaintained Jeep road between here and there.
Corral Creek Crossing.
High on a ridge and Tamara is smiling. She is loving this! And so am I! Remember my "Happiness is best when shared" comment? Yep. Even saw four elk on this stretch.
Off the Jeep trail and back on the graded stuff. Success!
Just 100 miles to home on the pavement. Her first day on a dual sport was well over 300 miles. All three of us thoroughly enjoyed our day outside. It's great to have Hobbes back. It's great to have this amazing woman to play with. And it's great to have the time to do it all.
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 05-24-2013, 03:49 AM   #910
TheAdmiral
TheAdmiral's Avatar
Oddometer: 1,054
Possible close encounter
You may have passed by us! I drove the support vehicle for my father-in-laws wagon train ride. i.e. I had my camper, and the wife and I rode my TW and ATV instead of being on the wagons.
Anyway, we were camped at Cottonwood Creek just a tad past the Juniper Mtn turn off. Just curious if you saw the camp.
Been darn near 16 or 17 years since I've been on the Corral Creek trail. Your taking this reminds me to "re-explore" it once again. Glad you had a good time with your new found friend. Sharing a ride with someone is kinda fun ain't it!
For the record, I hate snakes!
Admiral's Voyages http://advrider.com/forums/showthread.php?t=788178
TheAdmiral is online now   Reply With Quote
Old 05-27-2013, 06:12 AM   #911
KildareMan
KildareMan's Avatar
Oddometer: 681
No searching required. All tunes are on Tuneecu.com, he says hurrying to check that they are.
Phew they are.
Spotted you have abs so you need
Tiger 800 XC - ABS, standard exhaust = 20653
Mine ran like shite with the arrow tune, which my local T dealer loaded because of my Scorpion can. Got home and loaded correct standard tune. Beautiful again.
PS extremely jealous of your riding locations.
KildareMan is offline   Reply With Quote
Old 05-27-2013, 08:19 AM   #912
obrianmcc
obrianmcc's Avatar
Oddometer: 612
Seems as if Birds of Prey are getting mixed reviews on their service...... Appears that they struggle when it comes to following instructions?
http://boiseriders.net/mechanical-te...xperience.html
Cyclone Cycles have been getting from local riders.....might be worth at least having a conversation with them should future service be needed.
2006 DRZ 400 E / Plated - 2012 Yamaha Super Tenere
OBR ADV Gear
Website - www.obradvgear.com
Facebook - OBR ADV Gear
obrianmcc screwed with this post 05-27-2013 at 08:37 AM
obrianmcc is offline   Reply With Quote
Old 05-28-2013, 09:09 PM   #913
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
The day after my fabulous ride with my new squeeze was Monday. I had off and she had to work. What ever was I to do with my time?
At this point, and after 40,000+ thousand miles of dual sport riding over the last three years, I've covered most all of the main roads close to home. It's time to start exploring the "spurs".
Just going to head out to the Owyhees today. It's the mountain range to the south that all the people who live in the Treasure Valley look at every day. And so few of those people take the time to drive "over yonder" and check out our back yard.
That's Jump Creek Canyon. A pretty popular spot actually. Lots of people go to practice canyoneering there. Especially when the water is really flowing to prep for doing the gnarly canyons in Utah. A customer at the shop offered to take me sometime and I think I might just have to go.
I'm not going through the canyon. I'm going up the side of it. There's a little thin red line of a road on the map that says I can go straight up the North side and meet up with Poison Creek.
It was a pretty good climb up the side to start with. Then flattened out for a bit. Then it went down. Big time. One of those "I sure hope I don't have to come back up this" moments I seem to have rather frequently. And then back up big time. Kinda wished for a knobby tire today.
That's a pretty good climb, but no where near the point I don't think I can do it. Or as steep as what I had just done. I did have the butterflies in the tummy a bit.
Now I'm up on the rim. This is view of the canyon not many see.
That's a looooooooooooooong way down!
Now I'm up on the top of the plateau and its easy sailing. Poison Creek is just a few miles up and I've been on that road numerous times.
Lots of folks have lived a very hard life out in these parts. I wish the rest of the world knew that it was tough here too. America is not all it's viewed to be sometimes.
The next spur is Leslie Gulch. An out and back to the Owyhee Reservoir that people speak very highly about.
All of a sudden....BAM!!! Leslie Gulch! This place is amazing! When I'm putting along in 3rd gear really enjoying the scenery, you know it's pretty. Totally taking my time and photos. This is such a unique area. I'll let the photos speak for themselves. It's about 10 miles if this.
Just a quick pee break at the reservoir. Time to reflect on just how low the water is. This is scary. I like to have water to drink and cook with. I also like to eat food which generally requires water to grow. And, it's nice to take a shower every now and then.
Bad snow year and dry Spring. And guess what? Everybody's lawn is green here! In the desert! I'm sorry, but green lawns in the desert are RETARDED!! I didn't turn my sprinklers in this year much to my neighbor's horror. It's pretty consistently reported that 50% of residential water use is for lawns. Not to mention all the perfectly good fuel that gets burned in lawnmowers. It should be in my moto tank!
I'm gonna transplant some sage brush next spring and call it good. That seems to grow pretty well in these parts.
Back out the canyon.
Another little side trip off the road to the top of the ridge for a better look.
Thunderstorm a brewin' just as I pulled into my girl's house. Great end to a great day. Dinner, wine, and bed.
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 05-28-2013, 09:14 PM   #914
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
I do remember that campsite! On the South side of the road in the same vicinity as some sheep herders? When are we finally gonna meet in person?
2011 Triumph 800 XC
2007 Honda CRF 250X
Old 05-28-2013, 09:17 PM   #915
av_mech OP
Risk Taker
av_mech's Avatar
Oddometer: 1,143
Rob
No longer planning on getting a Tiger? Why not? Just cause I had a little carbon build up?
2011 Triumph 800 XC
2007 Honda CRF 250X
Times are GMT -7.   It's 07:02 AM.
