Old 11-02-2011, 09:13 AM   #301
Delta61
Delta61's Avatar
Oddometer: 258
harmonizer
Just ordered one
Can't wait to sync the "CAMHEAD" using this instead of the manometer
Thanks GROK
Jim
"Keep the Greasy Side Down"
10 1200 GSA
07 X Challenge
04 1150 GS(SOLD)
Delta61 screwed with this post 11-02-2011 at 09:14 AM Reason: spelling
Delta61 is offline   Reply With Quote
Old 11-02-2011, 03:09 PM   #302
Ianuk
Oddometer: 90
Originally Posted by Grok View Post
Hi Ian,
Your order was shipped Oct. 18th to Leytonstone, ESX.
My previous experiences shipping to the UK has been variable (7-14 days), but I believe you should receive it very soon!
Many thanks for your patience and the business!
-Mark
Hi Mark,
The Harmonizer arrived today
Many Thanks
Ian
Ianuk is offline   Reply With Quote
Old 11-03-2011, 02:37 AM   #303
PeterW
Oddometer: 2,756
Arrived yesterday, used in anger today.
Excellent apart from the bugs
And before you have a heart attack, I live in Queensland, insect central.
Between when it arrived in my mailbox in the morning and me pulling it out late afternoon a tribe of ants had decided "Yep, nice, well made, comfortable dwelling - with skylight" and had set up home
I got a bit of a shock when I opened the box, but only one made it into the clip-top plastic bag, so alls good.
(And no, they didn't come all the way from the US, it's happened a few times with envelopes but not with so much enthusiasm).
Really nice bit of gear - and really easy to use.
FWIW. I was thinking of making something similar when I stumbled across your postings here. I couldn't make one for that cost - so well done and good luck with this.
Pete
PeterW is online now   Reply With Quote
Old 11-03-2011, 08:39 AM   #304
Grok OP
Grok's Avatar
Oddometer: 3,783
Pete
Hi Pete,
Thanks for the feedback - glad you like it!
Interesting story about the ants - I sometimes wonder what the boxes look like when they reach their final destinations! They are pristine white boxes when they leave here
And thanks for the well wishes!
I was born in San Andreas but it's not my fault
Grok is offline   Reply With Quote
Old 11-04-2011, 04:54 AM   #305
Flatknuckles
Oddometer: 8
I'm just after placing an order for one too
Flatknuckles is offline   Reply With Quote
Old 11-04-2011, 08:26 AM   #306
Grok OP
Grok's Avatar
Oddometer: 3,783
First Harmonizer to Ireland!
Thanks for the order, It ships today!
Old 11-04-2011, 11:32 AM   #307
Delta61
Delta61's Avatar
Oddometer: 258
Harmonizer
Hey Mark,
Now that is what i call fast
Ordered on Wed the 2nd and got it today
Can't use it till tomorrow cause i got to much yard work to do and have to fly students tonite
Will post up again after i get the "CAMHEAD" synced
Thanks again
Ride Safe
Jim
10 1200 GSA
07 X Challenge
04 1150 GS(SOLD)
Old 11-04-2011, 12:27 PM   #308
Flatknuckles
Oddometer: 8
That really does make me grin!
Go raibh Maith agath. (thankyou grok in Irish!)
Flatknuckles screwed with this post 11-04-2011 at 03:40 PM
Old 11-04-2011, 07:01 PM   #309
ghostownguy57
Oddometer: 24
Hi Grok, After reading all the good things everyones been saying, I finally ordered a Harmonizer of my very own.
Thanks, Mike
ghostownguy57 is offline   Reply With Quote
Old 11-05-2011, 07:25 AM   #310
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,046
I will be hosting a Bing rebuild/sync carb day for some NM airheads sometime in December. We will rebuild carbs then try out at least 5 methods for syncing them: Grok's Harmonizer, a twinmax, $5 fluid-in-tube, mercury manometer, and shorting out method (one of the local airheads is also a nuclear engineer with access to many very expensive toys--he might bring some sort of manometer used in nuclear power plants). I may as well post here the results.
I can already tell you the Harmonizer will be useful for the tachometer function alone on bikes without tachs or with unreliable tachs.
Stay tuned.
Cordless screwed with this post 11-05-2011 at 02:20 PM
Cordless is offline   Reply With Quote
Old 11-05-2011, 02:30 PM   #311
lineareagle
philomath
lineareagle's Avatar
Oddometer: 502
Talking Great tool
Leaps and bounds ahead of the twinmax.
I just did a complete service on my '06 GSA after an 8500 mile trip. The bike was running great but still needed a service.
I wasn't going to do valves and a balance because it was running so well but decided to anyways.
After adjusting the valves I hooked up the Harmonizer and went for a ride to get it warmed up. As expected at 4500 rpm, my normal rpm cruise it was only out by 20 to 25, smily faces but it was erratic sometimes 11 sometimes 25 so I figured I could do better.
I went back to square one using the gauge mode to just get a rise at idle and then backing off a full turn as per JVB on each side. Then adjusted to 3500 rpm for a close balance.
Went for a ride with the Harmonizer hooked up and made some final adjustments at 4500. Now I am 0 to +3 at 3500 all the way to 5000 rpm and at various gear and speed configurations. I have smily face and I'm smiling too. Great product.
"A good traveler has no fixed plans, and is not intent on arriving."
Lao Tzu
'06 1200 GS Adv - non A
lineareagle is offline   Reply With Quote
Old 11-05-2011, 10:21 PM   #312
Unkgd
Oddometer: 345
On the fence
Grok,
Quick question. WIll the uypcoming 4 cylinder model be able to work on 2 cylinder ala the current Harmonizer?
Thanks,
Bill
Unkgd is online now   Reply With Quote
Old 11-06-2011, 06:29 AM   #313
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Grok:
Bit the bullet last night and bought one. should have the bike together so I am ready to use it when it shows up
1Bonehead is offline   Reply With Quote
Old 11-06-2011, 08:39 AM   #314
Grok OP
Grok's Avatar
Oddometer: 3,783
Originally Posted by Unkgd View Post
Grok,
Thanks,
Bill
Yep,
It will be useful for synchronizing motors with 2,3,or 4 separate intakes. It will also have a gauge mode for single-ended vacuum measurements.
In 2 port balancer mode it will emulate the Harmonizer.
My current plan is to make it completely automatic, so it operates in the correct mode based on which ports are active
It's going to be significantly more expensive than the Harmonizer however. Not much I can do about that.
Old 11-06-2011, 08:41 AM   #315
Grok OP
Grok's Avatar
Oddometer: 3,783
Originally Posted by 1Bonehead View Post
Grok:
Shipping tomorrow (Monday). You should have it Wednesday (Thursday at the latest).
Thanks for the business!
Times are GMT -7.   It's 01:45 AM.
