Old 02-28-2012, 04:34 PM   #436
Grok OP
Grok's Avatar
Oddometer: 3,604
Originally Posted by Pete Swede View Post
Is the new 2,3 and 4 cylinder Harmonizer going to be bigger or the same size as the 2 cylinder one?
Same height and depth, just about an inch wider :)
I was born in San Andreas but it's not my fault
Grok is offline   Reply With Quote
Old 02-28-2012, 05:08 PM   #437
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,575
Ordering one now!
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 02-28-2012, 06:52 PM   #438
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 329
Laugh
Originally Posted by ridepjride View Post
OK, I'm in. Ordered one today and hope it provides better results than my homemade yardstick-mounted, ATF filled manometer.
Took a whole day to get it, what took you so long?
Thanks for the quick shipping! Looking forward to using it.
ridepjride is online now   Reply With Quote
Old 02-29-2012, 09:35 AM   #439
tdw
Oddometer: 3
WooHoo!!!! Just received mine!
Perfect timing as I just finished rebuilding the carbs on my '82 CB450SC last night. Now I just have to get the top end back together & I can try it out.
Maybe I'll try it out on my 'new to me' '02 R1150RT.
tdw is offline   Reply With Quote
Old 02-29-2012, 09:55 AM   #440
Pete Swede
Pete Swede's Avatar
Oddometer: 21
Please tell me when the "234" is ready. I will order one...
Pete Swede is offline   Reply With Quote
Old 02-29-2012, 03:11 PM   #441
MikeyT
Krusty Olde Pharte™
MikeyT's Avatar
Oddometer: 5,419
Originally Posted by pete swede View Post
please tell me when the "234" is ready. I will order one...
+1
MikeyT
99 Shadow Spirit 1100
"Non Illegitimi Carborundum"
MikeyT is offline   Reply With Quote
Old 03-02-2012, 07:23 AM   #442
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,930
Yay. Finally got around to ordering a Harmonizer. Looking forward to it...
'73 R60/5 Toaster
Bill Harris screwed with this post 03-02-2012 at 08:09 AM
Old 03-04-2012, 03:55 AM   #443
jaydee1445
Footpeg Crash Tester
jaydee1445's Avatar
Oddometer: 4,061
+2
jaydee1445 is offline   Reply With Quote
Old 03-04-2012, 05:16 AM   #444
ned52
Oddometer: 1
Hi Grok,
Had mine a time now and finally got around to having a go setting the bike up with your Harmonizer.
I am impressed with the build quality of the unit and how easy it is to use, my old unit ( tw## ###) was a pain
to use compared with this.
Ned (UK)
ned52 is offline   Reply With Quote
Old 03-04-2012, 07:52 AM   #445
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,575
JVB,
Have you made a video yet on how to use the Harmonizer??
Semper Fi
Old 03-04-2012, 08:27 AM   #446
Grok OP
Grok's Avatar
Oddometer: 3,604
Originally Posted by ned52 View Post
Hi Grok,
Ned (UK)
Thank you sir
Old 03-05-2012, 11:11 AM   #447
Bill Harris
Oddometer: 7,930
Ordered Friday, arrived today. Outstanding.
I like the comprehensive instruction label, and the wide variety of the calibration/adjustment/operation button. Outstanding.
Opened the package, immediately pushed The Button. Took ten seconds to find the Flashlight mode another ten to find the menu mode and five to turn it off. Outstanding.
The vacuum takeoff fittings on my R60/5 are non-standard. There is no decent place to put them in the carburetor (Bing Type 53 slide-valves) so I have installed them in the intake port of the cylinder head. Consequently, the 5/32" brass nipples tend to run somewhat hot (never measured, but the heat is enough to soften clear "tygon"-type tubing. The hose in the Harmonizer is good to 275*F, but if this is not enough, I'll add a short section of silicone tubing between the supplied tubing and the nipple.
For years I've synched the carbs by the plug-shorting method and/or the #1 Calibrated Ear method. Added the vacuum takeoffs, tried a pair of vacuum meters, found that the TLAR method was as good and easier.
One question: about 3" from the carb-end of the hoses there is an internal connector in the hose. Wuddisit? Restrictor piece ( I did a suck/blow on the hose and it didn't seem that restricterly)?
Outstanding.
'73 R60/5 Toaster
Old 03-05-2012, 11:49 AM   #448
Grok OP
Grok's Avatar
Oddometer: 3,604
Outstanding.
Hi Bill,
The internal connectors are indeed restrictors. They work in conjunction with the hose volume to "snub" peak pressure impulses. They protect the Harmonizer sensor from backfire, racing motors with large valve overlap, motors with damaged intake valves, and motors that have large vacuum orifices (> 1.5mm). You are right, they aren't very "restrictory". They are just enough to protect the sensor. They should remain in place, along with the hose length.
Thanks for the feedback!
P.S. What is the TLAR method?
Old 03-05-2012, 12:28 PM   #449
Dan Căta
Dan Căta's Avatar
Oddometer: 1,676
Got mine and used it on a 1200gsa, 1150 gs and my 1100RT. I love it! Used to have a twin max but this product is way better.
Dan.
Dan Căta is offline   Reply With Quote
Old 03-05-2012, 12:43 PM   #450
Grok OP
Grok's Avatar
Oddometer: 3,604
Dan.
Thanks Dan,
Glad it arrived safe. You have the only one in Romania so far!
-Mark
Times are GMT -7.   It's 07:10 PM.
