Old 02-12-2014, 03:47 PM   #1231
Ravenslair
Oddometer: 478
I sent him a few PM's and an email around the time he went dark. I never heard back. I hope all is OK with him
Ravenslair is offline   Reply With Quote
Old 02-13-2014, 10:07 PM   #1232
SidecarDan
Noob
Oddometer: 10
HTML Code:
I'm with you, as much as I'd like to get a Harmonizer I hope all is well with Grok.
SidecarDan
2012 Ural Gear-Up
SidecarDan is offline   Reply With Quote
Old 02-25-2014, 02:08 AM   #1233
Brisco
Chik'n Eater
Brisco's Avatar
Oddometer: 74
Originally Posted by ultane View Post
OP's last activity was in May 24, 2013
Does anybody know if Grok is still alive and kicking?
I've been trying to contact him with no reply.
I need a source of the two nipples where the vacuum hoses connect.
Mine were both broken. I only need a source for replacements.
Brisco is offline   Reply With Quote
Old 02-25-2014, 05:05 AM   #1234
Berger
Berger's Avatar
Oddometer: 701
The nipples are used in the medical industry. Try googling them. You might also try McMaster-Carr.
Sent from my Nexus 4 using Tapatalk
2014 Triumph Tiger XC
2007 Ural Patrol w/ mods
http://advrider.com/forums/showthread.php?t=723916
Berger is offline   Reply With Quote
Old 02-27-2014, 04:51 AM   #1235
Brisco
Chik'n Eater
Brisco's Avatar
Oddometer: 74
I found them. They are a Luer bulkhead connector for 1/16" hose.
Hard to buy in single quantities, but I found a manufacturer willing to send me a sample pack of 5.
They will probably be disappointed when I don't buy 500 more....
Old 02-28-2014, 09:31 AM   #1236
mendoje
Oddometer: 237
Can you post a part number? That way it's saved here for reference.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 03-16-2014, 11:09 AM   #1237
tcassem
Oddometer: 12
Harmonizer on 2003 R1150RT
Can anyone give me the directions for using the harmonizer on this bike?
tcassem is offline   Reply With Quote
Old 03-16-2014, 11:16 AM   #1238
Berger
Berger's Avatar
Oddometer: 701
Search the thread.
Old 03-16-2014, 11:37 AM   #1239
Happy Wanderer
Day Dreaming.. .
Oddometer: 207
Isn't there directions on a sticker on the back of the unit? It's pretty straightforward.
- Take bike for 15 minute ride to thoroughly warm it up (5 bars on RID)
- Remove rubber caps (or hoses) from vacuum ports on bottom of throttle bodies
- Turn Harmonizer on; wait for it to zero itself to atmosphere
- Plug hoses into vacuum ports at bottom of throttle bodies
- Put a fan in front of your bike to keep it cooling, fire it up
- Adjust throttle body big brass screws so it idles around 1100 RPM and is balanced in the middle of harmonizer display
- Twist throttle and check higher RPM balance at just off idle (~2500RPM)
- Adjust left and right throttle cables as necessary to achieve off idle balance at higher RPM. Follow procedures in a BMW shop manual or Haynes or Clymer (bleccchhh) manual to do this.
Tons of throttle balancing info on this forum with tons more details but this is the basic process you need to do.
Happy Wanderer is offline   Reply With Quote
Old 03-16-2014, 02:05 PM   #1240
tcassem
Oddometer: 12
The issue I had last summer was when I tried to do each TB seperate for best vacuum in gauge mode (I believe). I then balanced the two TB's in the center of the gauge but the bike ran like crap. I then screwed the air screw down, backed them out equal, and balanced again, ran great. So was I doing something wrong the first time, trying per directions, to get best vacuum seperately first?
Old 03-16-2014, 02:24 PM   #1241
Happy Wanderer
Day Dreaming.. .
Oddometer: 207
You don't need guage mode to synch throttle bodies. This is turning into a troubleshooting discussion so suggest you post questions over in GS Boxers. This is a vendor thread.
Old 03-16-2014, 02:56 PM   #1242
prestonpaul
What?
prestonpaul's Avatar
Oddometer: 1,552
As I understand it gauge mode is for setting the idle mixture on carburettors & shouldn't be used on fuel injected bikes.
Re-set your air screws as per factory specs and then balance. Problem solved
Mostly harmless.
prestonpaul is offline   Reply With Quote
Old 03-16-2014, 03:50 PM   #1243
tcassem
Oddometer: 12
Makes perfect sense. Thanks. Now to find the specs.
Old 03-16-2014, 04:09 PM   #1244
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,049
The 2 modes (gauge and balance) are used for different functions.
Gauge is like a standard manometer, it displays the amount of vacuum in inches of mercury.
Balance is a differential function and shows only the difference of vacuum between the 2 ports, not the total amount of vacuum.
To balance 2 carbs or FI ports use the balance function.
To diagnose why you can't balance 2 cylinders, or if you need to know the magnitude of the vacuum (like check for air leaks etc), use the gauge mode.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 03-16-2014, 04:13 PM   #1245
tcassem
Oddometer: 12
So wouldn't make sense to use gauge first to set the highest equal vacuum, then do TB adjust? There must be a better way to know the air adjustment instead of saying...2 and 3/4 out from bottom. By the way, I have not found what the spec is.
Times are GMT -7.   It's 11:37 AM.
