Old 06-28-2011, 04:46 AM   #1
adventure950 OP
Anglo-Saxon
Oddometer: 571
Review of Soft luggage Enduristan Panniers
I have used both soft and hard luggage on my various travel bikes over the years. However time and experience have pushed me more towards soft luggage but have always found quality or storage issues with many of the systems available. I even dabelled with making my own luggage system to overcome all the requirements I had - but the reality of the competition in the market place along with costs and production became overwhelming and that slid into the dark recesses of the past.
I however have found a very good set of panniers for the job. Imported and supplied by Zen Overland in the UK - These are the Swiss designed Enduristan monsoon (as the name suggests 100% waterproof).
They are similar in some ways to the more basic Ortlieb bags but are far better quality, finish and fit with some interesting and inventive features. The Bags have a roll top allowing the volume to adjust between 15 and 30 lts per side, the bags are double skinned with a strong cordura exterior and an waterproof pvc type liner, in between the two is a semi hard shell (removable giving the bags a strong protective shell and shape).
On the bag back is a semi hard padded rubbing area to prevent wear. When rolled shut the bags have three securing straps with excellent buckles along with a number of tie on points for fixing roll bags tents etc to the top along with carry handles making them easy to move off the bike.. - excellent stuff.
Internally the bags have an easy clean interior which has fold away compartment dividers, making it easy to separate your luggage internally into three compartments without additional bags, when folded out the way these allow full use of the internal space.
The bags can be adjusted and fitted wherever you like them - well forward or way back easily and when fitted are very secure and do not move or flap about nor do they stick out like a huge pair of suitcases causing wind sapping drag and wallow nor do they make the bike massively wider so sides of cars or bushes along the way are no longer a major problem along with the huge weight saving - these bags weigh about 3 kgs total).
The securing straps system consists of two over the saddle straps with velcro - more about that later and then lower front and mid rear tension strap to hold everything secure - this is clever as the strap carries right through the rear part of the bag from the front lower where it come out the back so all the tension on the strap (which happens to be elasticated rock strap)is transfered not to the bag where it could rip but to the bike attachment points at rear behind seat or rack and front around maybe footpegs.
The straps are very easy to fit and undo when wet or with cold hands. Once fitted the bags are very secure. The seat straps were the only area of complaint I had - they were to long for my bike and had to be cut down to fit (this meant re stitching the velcro) Also the straps are attached one to each bag then fit the other bag through a buckle of very good quality.
I would have preferred separate straps altogether which would have made them easier to adjust to length and should it be required much easier to replace. I spoke to Enduristan directly about this - they were very open to this point and are in fact are considering the feature of separate straps and two buckles per bag in the future design. However they said the design was to allow quick and easy tensioning and fit of the bags while on the bike and once you get used to the method they suggest it works really well.
All in all knowing what is involved in making luggage and having tried these Bags I would rate then very highly in the soft luggage world. Away from custom built products made exactly to your own requirements (expensive) means at only 215 you get a fantastic pannier system with excellent Build quality and features along with usability I give them 10 out of 10.
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 screwed with this post 02-03-2014 at 02:56 AM
adventure950 is offline   Reply With Quote
Old 06-28-2011, 07:36 PM   #2
Benjava
Benjava's Avatar
Oddometer: 1,920
I know for a fact that those Zen Overlanders have spared no hardship to travel the world looking for the very best of everything to supply us with.
Hey Baron you coming over here I hear
"Limbautomy" what's the Rush?
Benjava is offline   Reply With Quote
Old 06-30-2011, 08:13 AM   #3
fluff34567
fluff34567's Avatar
Oddometer: 1,096
I however have found a very good set of panniers for the job.Imported and supplied by Zen Overland in the Uk - These are the Swiss designed Enduristan monsoon (as the name suggests 100% waterproof). They are similar in some ways to the more basic Ortlieb bags but are far better quality, finish and fit with some interesting and inventive features. The Bags have a roll top allowing the volume to adjust between 15 and 30 lts per side, the bags are double skinned with a strong cordura exterior and an waterproof pvc type liner, in between the two is a semi hard shell (removable giving the bags a strong protective shell and shape). On the bag back is a semi hard padded rubbing area to prevent wear. When rolled shut the bags have three securing straps with excellent buckles along with a number of tie on points for fixing roll bags tents etc to the top along with carry handles making them easy to move off the bike.. - excellent stuff. Internally the bags have an easy clean interior which has fold away compartment dividers, making it easy to separate your luggage internally into three compartments without additional bags, when folded out the way these allow full use of the internal space.
The bags can adjusted and fitted wherever you like them - well forward or way back easily and when fitted are very secure and do not move or flap about nor do they stick out like a huge pair of suitcases causing wind sapping drag and wallow nor do they make the bike massively wider so sides of cars or bushes along the way are no longer a major problem along with the huge weight saving - these bags weigh about 3 kgs total).
The securing straps system consists of two over the saddle straps with velcro - more about that later and then lower front and mid rear tension strap to hold everything secure - this is clever as the strap carries right through the rear part of the bag from the front lower where it come out the back so all the tension on the strap (which happens to be elasticated rock strap)is transfered not to the bag where it could rip but to the bike attachment points at rear behind seat or rack and front around maybe footpegs. The straps are very easy to fit and undo when wet or with cold hands. Once fitted the bags are very secure. The seat straps were the only area of complaint I had - they were to long for my bike and had to be cut down to fit (this meant re stitching the velcro) Also the straps are attached one to each bag then fit the other bag through a buckle of very good quality. I would have preferred separate straps altogether which would have made them easier to adjust to length and should it be required much easier to replace. I spoke to Enduristan directly about this - they were very open to this point and are in fact going to feature separate straps and two buckles per bag in the future design. Its a little point but one worth bringing up. All in all knowing what is involved in making luggage and having tried these Bags I would rate then very highly in the soft luggage world. Away from custom built products made exactly to your own requirements (expensive) means at only 215 you get a fantastic pannier system with excellent Build quality and features along with usability I give them 10 out of 10.
if you space out your review it would be easier to read. At the moment it is very hard.
fluff34567 is online now   Reply With Quote
Old 06-30-2011, 05:22 PM   #4
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 447
I have been looking at these bags but was not able to find any reviews. Very glad you posted this. I think these will be one of my next moto buys.
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, Airhawk seatpad, Pivot Pegs, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
GeckoRider screwed with this post 07-01-2011 at 02:46 PM
GeckoRider is offline   Reply With Quote
Old 07-01-2011, 05:32 AM   #5
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,851
Very nice write up although a link would prove to be usefully so we can find them easily.
About $315.00 plus shipping US.
Thanks for posting http://www.zenoverland.com/soft_pann...n_monsoon.html
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss screwed with this post 07-01-2011 at 05:44 AM
MotoBoss is offline   Reply With Quote
Old 04-01-2013, 11:54 AM   #6
OlivierS
Oddometer: 98
I am planning to buy these monsoons, there is one worry though. I don't have a luggage rack, and I would rather not get one. So that means that the bags would be pressed against the plastic of my 990 and to a part of the exhaust.
Did you have any problems with that on the 950? I emailed enduristan, with that question, referring to the giant loop producs that include a heat shield. And they said it might be advisable to put a heat shield in between. But enduristan does not make them, so I would have to order a GL, or make one myself.
I have a stock exhaust.
If I would need a luggage rack I would rather get the Magadans.
OlivierS is offline   Reply With Quote
Old 04-02-2013, 12:29 PM   #7
lilolita
fahr mit mir
lilolita's Avatar
Oddometer: 1,362
OlivierS, I have the Monsoons and would not use them without a rack or some way to keep them off the plastic. There's just too much chance of them touching the exhaust.
Founding Member, OPB [Other People's Bikes]
Scoot Commute: Getting to and from work on 10 inch wheels
Loveletter to Oregon | FLy & RIde: Florida to Rhode Island on a Husky TE610
New England to New Scotland
lilolita is offline   Reply With Quote
Times are GMT -7.   It's 03:01 AM.
