Old 02-26-2005, 08:00 PM   #61
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by meat popsicle
Looks great creeper! that is a nice safe spot for a aux. One thought, is that light protruding thru the faring hole? If not you could mount a lil bit of lexan on the inside (or cut it to fit the hole ) and you have a nice rock guard.
i would recommend it - with all these jealous bastages around they will likely be roostin' ya next chance they get!
Thanks Meat, I kinda like how it's turning out myself.
Only the top protrudes a bit... maybe 3/8".
Actually there is an issue with glare back when the lamp is behind the fairing. Right now I have a closed cell foam doughnut around the light to reduce the light being reflected off the inside of the fairing at the bottom of the lamp.
I may move the light forward, all the way thru the fairing, or make a plastic tube to "extend" the light housing to the fairing.
Already thought about putting it under glass, but whatever I use, polycarbonate... what ever, it would have to be optically "clear". Don't want to overthink it... beyond what I already have that is.
The basics are done but it is still kind of a work in progress.
Dark and foggy out now, time to go look at the beam.
So... how's tricks?
creeper is offline   Reply With Quote
Old 02-26-2005, 08:04 PM   #62
PASSMORE
Just the last name...
PASSMORE's Avatar
Oddometer: 4,250
Chris,
When we were hashing it out I think the consensus seemed to be that it would portrude slightly through the hole in the fairing to reduce any glare as well as prevent any funky wind movement (?)
- Michael
facebook.com/passmoreranch
PASSMORE is offline   Reply With Quote
Old 02-26-2005, 08:05 PM   #63
dagwood
dagwood's Avatar
Oddometer: 35,427
French it in. s
dagwood is offline   Reply With Quote
Old 02-26-2005, 08:09 PM   #64
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Anything is possible... even "Frenchin' it in" Dagmonster.
So... how's tricks?
Old 02-26-2005, 08:11 PM   #65
PASSMORE
PASSMORE's Avatar
Oddometer: 4,250
Originally Posted by dagwood
French it s
French his hole?
Oh the humanity of it all
- Michael
Old 02-26-2005, 08:13 PM   #66
dagwood
dagwood's Avatar
Oddometer: 35,427
either that or look like something from Logans Run or Robo Cop gone amok.
Amok amok amok. love that word
Old 02-26-2005, 08:45 PM   #67
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Ok, this is the last show-N-tell for the night. For the present, the HID is aimed to the same point as the stock high beam.
Low.
High
HID
On to the next thing...
So... how's tricks?
Old 02-26-2005, 08:54 PM   #68
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
So, give the proles a final HID rating. The lighting is now 10 - 20 - 30 - 40% better? Was it worth the cash? Are you happy with your hole? Would you recommend your hole to others? Tell all, oh Master of the Carbon Arc....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-26-2005, 09:30 PM   #69
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
To be honest, I'll reserve final judgment until I've had a better opportunity to experience it under varying conditions, and play around with aiming.
Night CC... gona' go watch "Collateral".
So... how's tricks?
Old 02-26-2005, 09:41 PM   #70
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Nighty-night
Chris
1943 BSA M20WD
Old 02-26-2005, 11:13 PM   #71
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
looks like you get a fair bit o light offa the thing. i see the potential for two of those biznatch's on loaded 640.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 02-26-2005, 11:33 PM   #72
PASSMORE
PASSMORE's Avatar
Oddometer: 4,250
It will be interesting to see how you get them lined up nice and perty Colin... Mine (yours may not) has the tach hump on the right... Alignment (if desired) may be a biatch, eh?
- Michael
Old 02-27-2005, 12:16 AM   #73
Loadedagain
making chips
Oddometer: 26,730
i'm gonna mount outboard like the touratech ones i posted a couple pages ago.
if these hid ones don't work out i'll prolly get a set of these hella lamps. i think they'll look cool beside the stockers.
Old 02-27-2005, 07:26 AM   #74
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Aren't these two Hellas gonna draw 55 watts each, as opposed to the Trail Tech HIDs at 13 each. 110 watts vs. 26....ouch
Chris
1943 BSA M20WD
Old 02-27-2005, 08:31 AM   #75
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
speakin aboot yerself in the third person...
ps - if you are going to get some Hellas, why not just replace the stock lamps with hellas? you will be spending enough money to come close right?
also, what about the stink that hellas and other car systems are not set up for bikes, something aboot the electrical schmegma...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 12:40 AM.
