Old 07-03-2011, 08:45 PM   #1
YBDRTY OP
YBDRTY's Avatar
Oddometer: 22
Front Sprocket
I have 25,000 miles on my 2005 950 Adventure. I have replaced the rear sprocket and the chain but never the front sprocket so I assume it's time. Checking out the KTM parts book, I see that there's 2 diffferent ones. They are both 17-T but one is listed as "Damped" and is a few bucks more. Anyone know the difference or have any recommendations?
The is no "I" in TEAM...but there is a "U" in SUCK!!!
YBDRTY is offline   Reply With Quote
Old 07-03-2011, 09:21 PM   #2
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,699
Yep - 1 has a rubber damper on it that reduces chain vibration and hence makes it smoother (very slight difference IMO). The cheaper doesnt, just a counter shaft sprocket. I prefer the dampened - but in the end they both pull the chain round just the same. Its your choice and $$$ in the end. When you change it make sure the shaft splines are cleaned of any corrosion/rust and install the new one with plenty of high temp grease to prevent rusting, and of course a new lock washer on the nut.
Pete
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-04-2011, 05:53 PM   #3
zedtours
zedtours's Avatar
Oddometer: 360
Does the 990 now have a nyloc nut?
zedtours is offline   Reply With Quote
Old 07-04-2011, 07:29 PM   #4
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,699
Not that Im aware of (I have a 950), it doesnt need it. The lock washer is simply a thin splined washer that you bend over to stop the nut from rotating - costs about $0.80 so make sure you buy one.
Pete
Old 07-04-2011, 07:42 PM   #5
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,738
On most bikes, the damped CSS will be about 10 dB quieter than the undamped.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 07-05-2011, 10:01 PM   #6
tomdubz
getting there
tomdubz's Avatar
Oddometer: 493
You suspect correctly.
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 07-06-2011, 11:30 PM   #7
Gluaisrothaí
Feckin' gobshite
Gluaisrothaí's Avatar
Oddometer: 547
Huh?
A 10dB reduction is 90% quieter. The damped sprocket really makes that much difference? I've switched to an undamped aftermarket and haven't noticed 10x the noise level.
2009 KTM 990 ADV
2006 DRZ400SM
1974 Aero Commander 112A (AC11/G)
2010 FJ Cruiser Trail Teams
2013 Tesla Model S 85kWh
Gluaisrothaí is offline   Reply With Quote
Old 07-07-2011, 04:55 AM   #8
KatoomDownUnder
Safer off a horse than on
KatoomDownUnder's Avatar
Oddometer: 956
Question
How the hell are you going to notice a supposed 10dB change in counter sprocket noise
I've just gone for the undampened 17 and I'll be stuffed if I can notice any real change in the noise levels. Mind you twin Akras without baffles tend to cover everything else in the sound of pure joy
Na cnuic tha lomnochd
's tha duilleach Foghair
mar bhrat air la\r,
am fearann caillte
dan tug na seo\id ud gra\dh,
a sheas an aghaidh
feachd uailleil Iomhair
's a ruaig e dhachaigh
air chaochladh smaoin
You're not drunk if you can lie on the floor without holding on.
KatoomDownUnder is offline   Reply With Quote
Old 07-07-2011, 07:13 AM   #9
Gluaisrothaí
Feckin' gobshite
Oddometer: 547
If it was 10dB you definitely would notice. dBs are a log scale; a 3 dB increase = twice as loud, 6dB is 4 times, 10dB is approx 10x.
2009 KTM 990 ADV
2006 DRZ400SM
Old 07-07-2011, 08:27 AM   #10
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,336
YB,
One more collective detail: once you've got your new front sprocket going, make a note to turn it around at about 12 to 15 thousand miles out.
The fronts wear faster than the rears, and this will help extend chain life.
Plus, it gets you behind the countershaft cover to clean it and check that the nut is still tight (which I found it not to be once!)
"Hells AL is right."Zuber "Bad roads, good people. Good roads, bad people." Mama Espinoza
“Ride first, tart second. Sorry bro but that’s the way it has to be.” Cbrit, 2008
“You gas it where I brake!” trackday passenger, Thunderhill, 2005 "Especially since he's one of the fastest riders on the planet, on any surface!" Earwig, 2014
HellsAlien is offline   Reply With Quote
Old 07-07-2011, 11:51 PM   #11
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,925
Is Hells Al right this time? I remember that this sprocket is offset, so you can't reverse it. OR, maybe that's ALL the other KTM's?
The diff in sound between these two sprockets is very small. If you have knobs or a tire that's cupped, you'll never even hear it.
"Son, you can't do both"
Old 07-08-2011, 05:56 AM   #12
snarley
snarley's Avatar
Oddometer: 501
I would replace both front and rear and chain together. Why waste good money ruining a new chain on old sprockets ???? Or even worse a new chain on one new and one old sprocket ??
snarley is offline   Reply With Quote
Old 07-08-2011, 12:59 PM   #13
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,940
Listen to this WISE Man
ALL new or leave it alone
Brown Dog is offline   Reply With Quote
Times are GMT -7.   It's 12:17 PM.
