Old 02-27-2005, 07:53 AM   #1
Wally OP
Oddometer: 10
KLR 650 cruise control
I have a '01 KLR 650 and I am looking for a simple cruise control for it. Does anyone have any ideas on an easy/cheap aftermarket add-on? Thanks, Wally.
Wally is offline   Reply With Quote
Old 02-27-2005, 09:38 AM   #2
CuzinMike
Treedragger
CuzinMike's Avatar
Oddometer: 307
I have a Throttle Lock on my '01, and it has worked great for 30,000 miles. About 25 bucks if I remember right...
CuzinMike is offline   Reply With Quote
Old 02-27-2005, 10:08 AM   #3
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
throw one of these on the gas pedal.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 02-28-2005, 06:14 AM   #4
DMZ
Castor Bean Addict
DMZ's Avatar
Oddometer: 10,113
Walley take one of those small 6" bunjee cords and attach one end to the base of your mirror bracket (use black so to blend in). Now wrap it around the throttle (clockwise) a couple of times and attach the end to the base of the mirror bracket. The idea is to apply enough tension to the grip to keep the throttle in any position.
Use this only on the highway when you get into 5th and want to cruise. Detach it as you aproach an exit.
This has worked great for me and cost about $0.50.
DMZ is offline   Reply With Quote
Old 02-28-2005, 06:28 AM   #5
freeflow
get in or go in
freeflow's Avatar
Oddometer: 16,127
I agree...I have used this for long range trips with great success......I have alos used a large 2.5 or 3 inch Oring...and even a red rubber plumbing gasket....just loosly place it between the flange of the grip and the cable housing....to engage it...pull and sandwich it between the housing and grip and viola!....just enough fristion to hold the throttle and yet can easily be overcome by twisting the throttle....all for less thatn a buck......my old 9" piece of 3/16" shock cord has lasted for the last 5,000+ miles....
judjonz turned me on to this over at klr650.net
freeflow is offline   Reply With Quote
Old 02-28-2005, 06:43 AM   #6
DMZ
Castor Bean Addict
DMZ's Avatar
Oddometer: 10,113
That is where I got the bunjee throttle lock idea as well.
Old 03-01-2005, 05:44 PM   #7
Ensey
KLR Combat Touring
Ensey's Avatar
Oddometer: 738
I had an old left over Vista Cruise from the 70s that I used on mine.
David
David
Team Pterodactyl
1000 Miles South of HQ
Ensey is offline   Reply With Quote
Old 03-01-2005, 07:07 PM   #8
CA Stu
CA Stu's Avatar
Oddometer: 47,644
David
Here you go, this is what I have:
http://www.klr650.marknet.us/vistacruise.html
Cheers
CA Stu
CA Stu is offline   Reply With Quote
Old 03-01-2005, 07:41 PM   #9
bman
bman's Avatar
Oddometer: 499
Originally Posted by Like A Virgin
Anyone have a vendor in CA for the vista cruise.
Seems you can't find them here.
Strange, seem every dealer around here carries them.
Try here
bman is offline   Reply With Quote
Old 03-01-2005, 07:49 PM   #10
CA Stu
CA Stu's Avatar
Oddometer: 47,644
www.arrowheadmotorsports.com
Great company to deal with.
Prompt shipping, and never the wrong part.
Highly recommended.
Where I scored mine, too.
Cheers
CA Stu
Times are GMT -7.   It's 04:45 AM.
