Old 02-27-2005, 09:09 AM   #1
barbasma OP
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
Look Under Your Frame!!!
some bike have a creep under the frame near the bashplate...
nothing dangerous for driving but just for bashplate...
in italy the dealer make a TIG reparation... in germany some CHANGE ENTIRE FRAME...
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni
ciao Matteo
www.barbasma.smugmug.com
www.lc8.org
www.adventureschool.it
KTM 950 ADV S 2003 80.000 KM..... and gooooo...
barbasma is offline   Reply With Quote
Old 02-27-2005, 10:06 AM   #2
motozilla
motozilla's Avatar
Oddometer: 5,740
Matteo,
Do you mean a crack in the frame?
motozilla is offline   Reply With Quote
Old 02-27-2005, 10:11 AM   #3
barbasma OP
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
yes..
ciao Matteo
www.lc8.org
Old 02-27-2005, 03:53 PM   #4
wittman
Oddometer: 7
Hi everybody,
I have discovered (or better the Sommer mechanic discovered it).
Here you are
http://www.tenerside.it/tecnica010.php
My new frame is arrived last week and the next I'm going to change it.
In the picture the break is simply to note because there is a TIG on it but it is very difficult to see. You can find it touching the part with a finger.
Hope none of you could find it
Best regards
Paolo
wittman is offline   Reply With Quote
Old 02-27-2005, 04:28 PM   #5
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Critical point of breach chassis
Thanks to, wittman, barbasma and the fine folks at http://www.tenerside.it/tecnica010.php
Translation: This disadvantage has been found on the construction chassis vintage year 2003, I say construction and not registration.
If from the booklet of circulation not succeeded to go back to the year of construction of the motion you transcribe your number of chassis and makes it you to visionare to your concessionaire KTM of confidence, it will be in conditions for going back to the vintage year of construction.
Premetto that in occasion of this defect guarantee KTM has answered with the substitution of the chassis.
In the photo the point of breach of the chassis is visible, hour is present a welding that has been executed before the participation in guarantee, if not a lot were the welding probably the cracking would not be visible.
In order to notice it could be sufficient to pass the hand over, to eye often is not visible, sight the paint job of black color.
The critical zone is situated in the skillful side (side posterior brake) under to the footrest in correspondence of the attacks of the cavaletto centers them (than on this present motion not e') close to a bolt that fixed the motor.
The leak of the chassis does not happen on mounting or the crib but if watched under the footrest side brake you will see the posterior attack of the slab fixed bumper with an embedded bolt if moved a po' behind (with the look) you will find a ring of the fixed chassis with a bolt. Such ring has a thickness much small (said 5/6 milimeter) breaks off the advanced part of this ring well.
It seems that the chassis is broken off for via of the slackening of the bolt (consequent to the vibrations). In order to tranquilize the the 950 minds of Adventure in the new chassis the thickness e' be increased and the bolt e' different.
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack screwed with this post 02-27-2005 at 06:10 PM Reason: pics added
Mack is offline   Reply With Quote
Old 02-28-2005, 02:03 PM   #6
overlander
Gravel Travel Tours
overlander's Avatar
Oddometer: 390
Yeaaahh! That's what I thought it said!
overlander is offline   Reply With Quote
Old 02-28-2005, 10:07 PM   #7
creator8
Team Hollywood
Oddometer: 135
There is definiitely a smartassed response to this--I'm just not quite sure where to start.
07 Ducati Monster S2R 800
05 KTM 950 Adventure (Orange) SOLD
04 KTM 525 MXC Dual Sported (Orange)
creator8 is offline   Reply With Quote
Old 03-01-2005, 11:53 AM   #8
Stephen
Stephen's Avatar
Oddometer: 3,191
Just like an owl !
Originally Posted by Mack
I would not mind humor or sarcasm, as long as you guys contribute to the thread!
Yeah, sure you wouldn't.
Hope it doesn't contribute to your (deservedly) foul mood, but I checked this morning and found no crack on my bike's bottom. Like an owl.
Relievey Stevie in Austin.
Stephen is offline   Reply With Quote
Old 03-09-2005, 12:32 PM   #9
Mack
Mack's Avatar
Oddometer: 3,797
Bump.
I am just curious if anyone checked their frame? Or if owners just aren't concerned enough to worry about it? (Other then Stephen and myself, I don't know of anyone else in the USofA that has commented on this one way or the other.)
From what the Italians are telling me, they have had a number of cracked frames! Not sure on the German's, but it sounds like they have as well. (The crack in my frame was VERY hard to see, and I do this kinda stuff for a living.) My bike has 10,5k miles, Stephens wasn't cracked and has similar mileage.
Old 03-09-2005, 01:24 PM   #10
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,744
Mack do you have any photos of your cracked frame?
Renazco is offline   Reply With Quote
Old 03-09-2005, 01:32 PM   #11
Mack
Mack's Avatar
Oddometer: 3,797
James, Seen from the side, the crack in my frame is identical to the pics in this thread. Mine continues up into the radius and up over the top, angling back and aft into the plate. (Might have pics, not sure the cheap borrowed digicam focused well enough, if so I'll send them to you.)
Old 03-12-2005, 05:43 AM   #12
schradt
Oddometer: 33
I don't think that it could be a security issue. That sheet metal does only hold the engine, nothing other. I think it was simply too thin, or wrong handled.
Got a new frame for my LC8, 10/2003, 45000km.
regards
Schradt
schradt is offline   Reply With Quote
Old 03-12-2005, 10:20 PM   #13
Mack
Mack's Avatar
Oddometer: 3,797
The welder finished today, I'm very happy with his work, he did a bang up job. I'll need a longer bolt for the centerstand, but the TT skidplate and motor are business as usual, fit perfectly. (He welded both sides, and added a triangular doubler.)
Now to finish the updates, valve adjustment, and get the motor back in. Yee Haw.
Old 03-14-2005, 08:57 AM   #14
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,376
Checked mine and no crack.
Goss
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 03-21-2005, 03:25 PM   #15
Noise
Dreamy Adventurer
Noise's Avatar
Oddometer: 193
I join you in your happiness. For now, of course :O
[ Sssshhhh... The Beast is sleeping ... ]
[ '03 LC8 950 Adventure silver ]
Noise is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
