07-05-2011, 12:52 PM
#31 |
More Ride, Less Google
Oddometer: 5,791
I'd love a light, narrow, flickable 750 v-twin w/ 19 - 17 wheels, high quality suspension, maybe 7.5 to 8" of travel, real brakes, real wind and weather protection, and the same high quality KTM build and components as the current bikes. Don't cheap out to compete, KTM! Lead, don't follow!
(I've had ZERO problems with my Adventure, and I don't mind the maintenance a bit.)
2003 Kawasaki KLR650 "Reality" 1993 Ducati 900SS "L'evento" |
07-05-2011, 01:39 PM
#32 |
ow, my balls!
Oddometer: 4,624
50,000 miles through the Americas mostly off pavement. We must be in the minority.
Riding the Americas: No Fumar Español - Terminado. ![]() _____________________________________________ |
07-05-2011, 01:41 PM
#33 |
Oddometer: 5,791
Broke 50k a couple weekends ago. Maybe riding is the key.
07-05-2011, 02:36 PM
#34 |
Motociclista Non Elegante
Oddometer: 2,233
990 se!!!!!
Something, something, something ... in latin. "Now with more SE then ever!" Das KTM520 2004 KTM 625 SXC - Sick. Getting better |
07-05-2011, 03:58 PM
#35 |
Oddometer: 5,202
Longer piston stroke on LC8.
Dual WP seals with bleed gap. Side stand relocation. Thermostatic oil cooler. Stainless exhaust. Stainless spokes and Dirstars rims on all models. Better rear axle block and markings. Better lights on EXC models. Fork bleeders as standard. And don’t change KTM’s blood for commercial reasons, no ST or Multi Strada. |
07-05-2011, 04:45 PM
#36 |
Oddometer: 9,851
A few more:
+1 on the high front fender. Single disk up front with a better set of calipers and master cylinder. More options for add-on storage.
2010 KTM 990ADV 2004 KTM 250SX |
07-05-2011, 04:53 PM
#37 | |
i like stuff
Oddometer: 4,325
Oh and a windshield that doesn't cause tinnitus.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..." |
07-06-2011, 02:19 AM
#38 |
Polishing Turds
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,551
Headers?? Muffler is stainless, thought the headers were as well.
Ti for me
How the hell did you get all this together? It just happened, Max, you know? A p-p-p-p-piece from here and a p-p-p-piece from there. |
07-06-2011, 03:25 AM
#39 |
Barrus Vegrandis
![]() That way we can ask not to have it.
Veni, vidi, velcri. |
07-06-2011, 06:43 AM
#40 |
Oddometer: 7,985
Detune a 950/990 for the same effect
![]() While a smaller version may be nice in some respects, I think the real reason many find it interesting is because of weight and/or size. However, I don't think there's a lot of weight to be taken out of the 950/990 in a transition to an 800; without the cost going up a whole lot or the bike becoming relatively fragile. And the new 990 standard height is not that much different than the competition (that is, if you consider the BMW and Triumph as competition .). I'd be real happy with better serviceability and addressing the fuel pump, water pump, clutch slave "maintenance items". And a tubeless 19/17 option. And being really greedy-- some optional effective electronics like the Duc MS12 and BMW S1000R have: because I'm not the riding god that all the people who say "don't do it" imply they are when they say it.
Walter Barlow wpbarlow screwed with this post 07-06-2011 at 06:48 AM |
07-06-2011, 09:54 AM
#41 |
Oddometer: 187
I still wonder what the secret of Highland with their 165kg 950 V-twin Outback is.
I really much like the modular concept, maybe this could be an example for KTM. They just have the engines 750 V-twin, 950 V-twin, 1050 V-twin, 350 single, 450 single and 507 single with which they build their bikes like a supermoto, road bike, enduro/dakar, trail, cross, quad, duke-alike and street tracker while using high quality components like Ohlins suspension and Brembo brakes. It would be nice if KTM did a similar modular concept based on the 1190, 990, 790 V-twins. With each motor, you could chose between an Adv, SE, SM, SMT, Duke and RC. |
07-06-2011, 10:31 AM
#42 | |
Oddometer: 5,202
http://www.advrider.com/forums/showthread.php?t=130990
07-06-2011, 01:01 PM
#43 |
Miles of Smiles
Oddometer: 678
You know, as long as we're dreaming . . .
Wouldn't it be interestingl if Adventure bikes had integrated fuel expansion designed into the main tanks? Main tanks could be engineered with three or so hard mounting points and upper and lower quick-connects to add a sculpted 1.5 - 2 gallon tank to each side. With a setup like that you could take the long distance tanks off when you don't need the extra capacity. Merely having integrated mounting points built into the main tanks would allow aftermarket manufacturers to offer more options, even if the factory didn't want to. By using large enough quick-connects it might even be possible to fill the expansion tanks while filling the main tanks. These same integrated mounting points could also be utilized to add bolt-on storage, or other accessories. When building such a versatile bike for nearly a decade, why not add a little flexibility to accommodate some of the more common aftermarket add-ons? As long as we're talking fuel, how about having the main tanks attach to the bike using pins and sockets and use only one bolt to secure them? That would be pretty sweet! Imagine only having to remove one bolt, the fuel and breather lines, electrical connection, and off it comes! Replacement would bypass all the trouble lining up bent crashbars and the wrestling match that ensues getting the tanks back on. Factory quick-connects on the fuel hoses would be very generous as well. Just dreamin'
13 TRIUMPH TIGER 800XC . . the new kitty in the litterbox 04 KTM 950 Adventure . . . . Farkelization Completed - soon to be up for adoption 00 SUZUKI DRZ-400E. . . . . . DS Plated |
07-06-2011, 02:31 PM
#44 | |
Oddometer: 137
The one time (hmm acctually two times) I have tried the Highland I must say that KTM has a better feeling in the bike then the Highland. But I guess any MX rider will most likely disagree with me. It's a MX bike with a 950cc engine in it, KTM could learn something about FI from highland though. Can't recall that I had any trouble riding it or even thinking about the FI on that bike (well I was hanging on for my dear life). And if anyone think that KTM makes engines that are rough, check out the highland. :) Back to the question? What should KTM do. 1. Quality, quality, quality 2. see point 1 3. see point 1 4. see point 1 5. A lighter 800 cc bike (twin) with better fuel economy would be great. 6. see point 1 7. see point 1 Anyone who disagree on point 1 is most welcome to chip in on my US$4000 bill caused by a defect timing valve jackshaft which KTM claims is caused by poor maintenace (done every single maintance on the same certified garage from brand new), my bill for overhauling the waterpump twice (which reminds me it probably due for a new one, just passed 20000km on the last one). On top of that my paint is falling of when washed (no highpressaure washer, just normal gardenhose). But as of now there is no other bike to choose from soo this one is my first, last and ever KTM but she is a keeper (for a while).
'09 250 EXC-F SixDays - 175h '05 950 Adv S - 72000km '98 XL600V Transalp - 86000km - SOLD |
07-08-2011, 06:06 AM
#45 |
Fart Letter
Oddometer: 3,859
500
BigDog would like a bike very similar to the 950 adventure except with a 500--600cc V-twin motor.
Then everything else could be made lighter because it's not having to handle the horsepower of the 950 which I find totally useless offroad. About the only time I can pull full throttle is passing a line of RV's on the highway---which I rarely even get on. The rest of the time the horsepower of the 950 is useless for me. BigDog
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" |
