Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 08-31-2013, 06:45 PM   #2116
sinuhexavier
sinuhexavier's Avatar
Oddometer: 66
Has anybody used Supersprox?
Sinuhe Xavier ---- www.themightymotor.com
Twitter: sinuhexavier Instagram: sinuhe xavier
2010 Triumph Scrambler - 2012 Triumph 800xc
sinuhexavier is offline   Reply With Quote
Old 08-31-2013, 09:39 PM   #2117
BryanCO
CO Rider
Oddometer: 496
Did on my Multistrada. Very happy with their products.
BryanCO is offline   Reply With Quote
Old 09-01-2013, 07:04 AM   #2118
ducatirdr
Re-entry Noob
ducatirdr's Avatar
Oddometer: 132
Originally Posted by BryanCO View Post
I installed the sprocket this morning -- fits.
I ordered one. I tend to do a bunch of hard core powerline rocky trails so the lower gearing will be helpful. I hope it can lift the front without so much clutch slipping as well
I'm curious if you ran into any uniqueness or oddness when doing the swap. Did it install like any other motorcycles front sprocket?
04 Buell XB12R - Feels fast but isn't = Good street sport bike
12 KTM 350EXC-F - Enduro machine with plate so I can ride to the trails near my house
13 Triumph Tiger 800XC - Sold after clutch stranded me at 4K miles in Berkshires
2000 Ducati 996S - Madness
2014 H-D Breakout - Nothing like a big scooter to relax a bit
ducatirdr is offline   Reply With Quote
Old 09-01-2013, 08:01 AM   #2119
BryanCO
CO Rider
Oddometer: 496
Simple install. No issues. I needed to adjust the chain anyway...
Old 09-01-2013, 12:54 PM   #2120
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,485
+1 just like any other sprocket change... yesterday, I even managed to lift front wheel in second (with a slight hump in the road) with no clutch!!!
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 09-04-2013, 09:23 AM   #2121
btao
RIP Lilolita
Oddometer: 1,011
Planning to order the Holan Crash Bars soon.
Does anyone have any "experience" with these bars? Pictures & feedback after some trail time? From the crash bars thread they seem to be the best designed set out there and more visually appealing than the Happy Trails and better engine case coverage, yet nobody had them because they aren't sold by the major distributors out there.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 09-04-2013, 01:39 PM   #2122
rkclm
Oddometer: 31
I have the Holan Crash bars. They went on with out a problem and are holding up well. But I have not had "opportunity" to give them a real test yet. But I do think they will do well if and when that happens.
rkclm is offline   Reply With Quote
Old 09-04-2013, 03:57 PM   #2123
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,220
Question Sprocket Removal
What did you use to break the nut free and re-tighten? 36mm socket? Impact or ratchet?
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 09-04-2013, 07:30 PM   #2124
GtiKyle
GtiKyle's Avatar
Oddometer: 234
1/2" drive ratchet, 36mm socket. Stand on the rear brake.
GtiKyle is offline   Reply With Quote
Old 09-04-2013, 08:09 PM   #2125
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,220
Excellent, I don't have an impact gun. Ordered a 36mm from Grainger for $11, it will be in Friday morning
Lord John Whorfin
Old 09-04-2013, 09:35 PM   #2126
BryanCO
CO Rider
Oddometer: 496
1/2 in drive breaker bar. Already had the socket. Was actually easy. Front sprocket on my Multi was a bitch!
Old 09-04-2013, 10:00 PM   #2127
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 477
Originally Posted by Mercury264 View Post
Are these good for the Uni Filter - I assume yes but, well, you know how that goes...
Careful with the NoToil and uni filters...
The regular red label NoToil is alcohol based and does not play nice with the glue Uni Filter uses - see the separation of the filter material from the base material in the pic.
The green label stuff is not alcohol based and supposed top be safe. I haven't tried it yet.
jackanory is offline   Reply With Quote
Old 09-05-2013, 03:54 AM   #2128
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,220
I did first cleaning with Notoil Eco on unifilter. I had to clean the petroleum based oil off first, ten used ecocleaner and oil. Hard to tell if it was completely saturated but I went by the look of the inside and by using enough to squeeze excess out along the whole filter. The gasket grease sure helps with reinstall. Only 2K on it so i won't know for a bit on how well it catches dirt.
Lord John Whorfin
Old 09-05-2013, 06:12 AM   #2129
btao
RIP Lilolita
Oddometer: 1,011
Should have asked, I could have brought mine for later.... Pretty sure I have the 36 for changing either the sprocket or the axle on the bandit.
I do have the spacer... You still haven't told me what it's for....
Old 09-05-2013, 06:23 AM   #2130
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,220
Ordered 36mm from Grainger, gotta have it...
Need to machine chain side spacer. I have the bearing and seal. Going to do rear wheel, raising links and sprocket this weekend.
Also thinking of machining 30mm risers for the bars. Ben wanting to do that for a while. I'll let you know rough stock OD, maybe the shim stock will work?
That or I can pony up and buy my own stock
Lord John Whorfin
Times are GMT -7.   It's 06:09 PM.
