Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 09-11-2013, 03:51 PM   #2161
bross
Where we riding to?
bross's Avatar
Oddometer: 4,602
Originally Posted by some call me...tim View Post
Not sure if it applies to your issue, but I had to keep everything plenty loose on both sides before it would all mount up properly. IIRC, I had one side mounted up, slightly more than hand tight, before I started on the other side, but it just wasn't going to work that way. Once I backed out the bolts so that there was plenty of free play, I was able to get both sides on and joined together, then tightened everything down.
That should be SOP when mounting any brackets.
Old 09-11-2013, 06:54 PM   #2162
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 906
Correct, mine was the same. Put both sides on as loose as possible, and you may still have to pull on it while you line up the bolts.
2013 Triumph Tiger 800 XC
2013 Husky TE 449
XCRider803 is offline   Reply With Quote
Old 09-11-2013, 07:43 PM   #2163
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Stepper motor maintenance
Found this area pretty dusty, not much elsewhere. Cleaned then dry lubed. May pay to move the rubber boot to clean where the action is...
Cleaned, closer look
Dubl-A is offline   Reply With Quote
Old 09-13-2013, 09:17 AM   #2164
BryanCO
CO Rider
Oddometer: 503
Hand guards
Thoughts on hand guards? Specifically plastic vs. plastic/metal.
I've been running the stock units and they have hit the ground a few times. Just incurring some scratches. No damage to the levers or anything else.
I run the plastic/metal units on my dirt bikes When the bike is dropped, there is a lot less weight hitting the guards but they can still be a pain as they can bend and move around.
I'm looking for function first but I don't care for the look of most of the plastic/metal set ups.
BryanCO is offline   Reply With Quote
Old 09-13-2013, 09:29 AM   #2165
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I've been impressed with the stock plastics. I found the wind protection was better than my Barkbusters
Old 09-13-2013, 09:32 AM   #2166
btao
RIP Lilolita
Oddometer: 1,024
Yea, I certainly did, I had everything as loose as it would get, followed the sequence of instructions, and still nothing. Had to beat the tab on the bottom down because the top was too strong.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 09-13-2013, 09:36 AM   #2167
btao
RIP Lilolita
Oddometer: 1,024
I found that once I rotated the bars down for good alignment when standing, the stock ones were useless for wind. They are pointy and the levers fit right up in there. The levers were at risk during a crash as those plastic ones are flimsy and bend and spin if it's not taking the hit right from the front. No adjustability as they mount to the lever assby.
After throwing the Barkbuster Storm guards on there, the Aluminum bar is in the right crash position and the deflector comes up into the right wind protection position. Looks like they are ideal versus stock.
Old 09-13-2013, 04:59 PM   #2168
helotaxi
Oddometer: 380
Doesn't take much to shatter the stock ones either. The Barkbusters leave the chance that they could rotate if they take a hit. They're better than stock but still not the best option.
helotaxi is offline   Reply With Quote
Old 09-14-2013, 12:47 AM   #2169
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,824
You're very easily impressed. Those standard guards are the worst I've ever come across.
They move too easily and leave the levers exposed ready to snap off. And yes, I've seen it happen on someone elses bike. I changed mine almost as soon as I got the bike home after buying it.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 09-14-2013, 12:58 AM   #2170
fluff34567
fluff34567's Avatar
Oddometer: 1,094
My friend has a 800xc its convinced me to never buy one.
Constant recalls for ecu updates, stepper motor fuel pump oil lines etc.
We did a fair bit of gravel roads in last days and it died....again. died last time we went for a trip also.
All the engine mounting bolts came loose, 1 was hanging in by a few threads, as the engine was moving the rad cracked as there is a solid link between the rad and engine so the weld cracked. :what::what:
Check your bolts and look to remove or replace the link with a rubber based unit.
Sent from my GT-I9300 using Tapatalk 2
fluff34567 is offline   Reply With Quote
Old 09-14-2013, 01:20 AM   #2171
outsidein
outsidein's Avatar
Oddometer: 437
Originally Posted by CA Stu View Post
Anyone can ride a light dirt bike in the dirt.
I don't see using the Tiger XC off-road as "thrashing", it's ostensibly designed for that purpose.
I'd be more apt to criticize someone for buying an 800XC and riding it exclusively on the street.
CA Stu
As an Adventure bike owner I feel Adventure bikes in general are bikes designed mainly for the pavement that can handle mild off road use like dirt or gravel roads. Driving down a deeply rutted path would seem to be stretching their off road capability and bumping against their design limitations like higher weight, agility (compared to a dirt bike) and high power band. Not saying you can't do it as the poster obviously can but it seems like a bit of a stretch to their suitability. To me it seems a bit like using a new BMW or Porsche SUV for the mud bogs.
outsidein screwed with this post 09-14-2013 at 01:40 AM
outsidein is offline   Reply With Quote
Old 09-14-2013, 06:31 AM   #2172
ducnut
Oddometer: 3,320
This forum has convinced me to never buy anything with a roundel on it.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 09-14-2013, 07:15 AM   #2173
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,079
^^ This.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 09-14-2013, 07:27 AM   #2174
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,824
Yeah. Constant recalls for software updates and final drive bearings and telelever ball joints, canbus problems etc etc.
Old 09-14-2013, 07:39 AM   #2175
ducnut
Oddometer: 3,320
D-U-C-A-T-I, anyone?
Like people, I don't think any bike is perfect.
'96 Ducati 900SS
Times are GMT -7.   It's 12:01 AM.
